Question about Refrigerators
The door on my Sub Zero Model 532 fridge/freezer doesn't close properly. When you think you are pushing it closed, it swings back open.
  • 1 more comment
  • thomasrj179 Jun 25, 2009
    OK, so where are the magnetic strips located and how can they loose their magnetism. If they are broken/faulty, where do I find new ones and how do I replace them?
    I found the magnetic strips and took them out. They seem to be working OK, but I don't know how strong the magnetism should be. What is the maximum angle the open door should be closing on it's own. The way it is at the moment, I have to almost completely close the door before the magnets start working. Before, I seem to remember that you just had to lightly push the door shut and it would close on its own.
    Another thought, could it be related to the door hinge?
    The door opens fine, but when you open it more than say 10% (0%=closed, 90-120%=fully open), it swings open. Whereas before at 10% open, it would close automatically if left. However, when I take the magnetic strips out, the strips will stick to each other metal to metal.
  • 749 Answers
It seems like the magnetic strips along the door need replacing, make shure there is nothing covering them and they come in contact with the metal of the fridge.
Posted on Jun 25, 2009
  • 1 more comment
  • Muzzammil Ishfaq
    Muzzammil Ishfaq Jun 25, 2009
    the magnetic strips are around the inner side of the fridge freezer, have a look if you can remove them, any screws ect Link
  • Muzzammil Ishfaq
    does the door open freely or do you have to apply force once its opened? if not then the hinges are fine, the magnet strip's are designed to close the fridge so if they seem a little weak that's fine, they normally are.
  • Muzzammil Ishfaq
    this could be a combination of problems including the magnetic strip and the door hinge, replacing the door will solve your problem because that would replace the door and magnetic strip however this will be expensive as the replacemnt part will cost 1/2 the price of the fridge, so i recommend you to keep it how it is to test the strength of the closed door simply (carfully) tilt it at a angle and see how strong it is, if it holds you will be shure that it wont open itself at night.
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Closing and opening a sub zero door
Maybe I'm not understanding your question completely.. You can open the doors whenever you want - as often as you like. The doors are no different than any other fridge as far as how often you can open and close them. Please clarify if I missed your intent. Thanks!
Jun 17, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub zero refrigerator model 532 problem the freeze is warm on the top but the ice & items below the ice are OK. i suspect that the light may be always on. also the freezer door does not make its...
I suspect a bad fan motor, door switch, or not defrosting.The suction when door closes is caused by the low temperature created when working properly.
Feb 14, 2010 | Freezers
Sub-Zero 642 ice maker
When the drawer is opened, trhe "full arm" swings up and out of the way. When the drawer is pushed back closed, the arm should swing back down. If it is unobstructed, the icemaker should make ice.
One thing to try is with the ice tray removed, push the plate (that holds the ice tray) back into the freezer. Lift the full arm up and down. It should easily move and you should be able to hear a slight "click" when moving up/down. If not, you might have a bad switch in the ice maker unit...replacement time.
Mar 25, 2009 | Sub-Zero 642
My freezer opens by itself after we close the fridge what can cause this
Is the refrigerator sitting on a level floor?
Are the freezer door or racks overloaded with food/packages such that the packages push the door back out?
Are any roll out drawers to full to fully close, including if something has fallen down behind them?
Jan 15, 2009 | Refrigerators
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
Sub-Zero 532 (About 18 years old)
First do the simple things like cleaning the condensor coils and turning the defrost timer a few times, also check the evaporator motor or just listen to the fan by opening the freezer door. Also check the light switch, make sure it turns the light off every time you close the door.
Jun 26, 2008 | Sub-Zero 632 / S
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
