Question about Cameras
I can only turn on my Cybershot DSC-N2 while the camera is in playback mode. I can look at the pictures and videos and change settings with no problem.. but when I try to switch to camera or video record mode the camera turns off by itself. Sometimes the lens will come out and then the camera powers down with the lens stuck out. Other times it just shuts off before the lens even has a chance to come out. The camera has never been dropped or damaged.
  • 4 more comments
  • kai686 Jun 25, 2009
    If I press the reset button will my cameras internal memory be wiped?
    Any other ideas?
  • kai686 Jun 26, 2009
    Why did this happen to the camera? Did the gear block zoom just go bad? Does that mean that it will happen again and again?
    Can you send me a larger picture of the exploded view of the lens please?
  • kai686 Jul 01, 2009
    I replaced the Gear Block Zoom (1100) and still the same thing is happening... The camera will turn on and the lens will move but then it turns off.
    What else could be the problem? I am not going to send my camera in for repairs and end up spending $170 if I can fix it myself.
    Please help.
    Hello, I have a Sony Cybershot DSC-N2 and it has been giving me problems lately. Ive had the camera for about 3 years now and just a few months ago it started acting up.
    I can turn the camera on in playback mode with no problems most of the time, but the real problems start when I try to switch to picture mode or video record mode.
    When I switch to those modes the camera shuts off by itself. Sometimes the lens will come out and sometimes it wont, but it always turns off within a few seconds.
    I have replaced the Gear Block Zoom (1100), on another experts advice but Ive still have the same problem.
    Please help me out. Thanks.
    Sergeant:
  • 173 Answers
First press power button for 15 seconds .
Then remove memory card from it may be your memory card has some issue.
also press reeset button on camera some camera has reset button.
start your camera without memory card.
Posted on Jun 25, 2009
  • Amit Jun 25, 2009
    no it not wiped. But reset button reset all settings to factory defaults.
    so your problem isd fixed then .
    Please dont forgetr to rate this solution if i help full to you.
    Many
    Thanks
    President:
  • 1,383 Answers
First reset all settings to factory defaults.
Check without memory card may it has virus so start and check without memory card.
Posted on Jul 02, 2009
  • 10,594 Answers
Any other ideas?
I'm Sony camera tech and have DSC-N2 technical info.
This camera behave like power shut off when it got problem in loading motor in lens mechanism.
Below are 2 images, first page of service manual and optical lens exploded view, that will give you an idea about how to apart camera and to get access to lens mechanism.
You need to replace "Gear Block Zoom 1100" (that is marked in image)
It is available in Part Store.
Let me know further query.
NOTE: If you have no expertise, do not apart camera to avoid further damage.
Thanks.
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Jul 01, 2009
    Clean flexible wire connecting points coming from lens and plug back it in circuit board and check lens is working now?
    Zoom gear part is solution to your problem of Turn Off camera. "
    When I switch to those modes the camera shuts off by itself "
    [When I switch to those modes the camera shuts off by itself. Sometimes
    within a few seconds.]
    [but when I try to switch to camera or video record mode the camera
    has a chance to come out.]
    For above said problem, zoom gear is replaced.
    You can not say camera is in same condition. I have fixed many DSC-N2 and know what I'm talking about.
    Please rate assistance accordingly and follow my previous instructions about flexible wire of lens assembly.
    Thanks.
    Did you get my response?
  • 583 Answers
I have had this problem for one of my local clent long back.we tried all possible things but couldnot find the problem initially.but finally we found out that it was due to mistracking on the main circuit board.the board was bit rusted inside and causing mistracking while using some functions and was going off.
you can open the unit and check the internal circuit if its rusted a bit then just clean it off and also resolder the whole board to get it function properly.it will get solved once board thing is solved.
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
Posted on Jul 01, 2009
    Sergeant:
    Champion:
  • 235 Answers
Some of these cams have more than one battery compartment. Make sure all batteries are alkaline because regular batteries don't stand a chance.
  • 378 Answers
Try to reformat it. I think virus or unwanted programmed is in there. follow the instruction manual for formatting.
  • 555 Answers
Hello my friend regarding on your problem I really would say that the best idea is to send it back to canon if it is under warranty or being it to a camera service shop if the warranty has expired. I would many to suggest anything that would possibly damage the camera more or void your warranty. But if you decided to fix it by your self then you can visit this link i provided you. This link demonstrating on how to open your camera without destroying of damaging the parts of your camera. Kindly click this link: Fix Camera this link has similar problem with your camera bout lens. So after you can open your camera you can clean and check the parts of your camera that might be the possibilities of making your camera not fully functional. Kindly check the lens connection if it is properly connected or the censors and also you can try and test your camera by turning it on and observe if their something not good activity going on in your camera inside.
But i strongly suggest/recommend that to prevent your camera from damaging further, please find a camera service shop in your place to fix it for you or you can return it to your supplier to fix and maybe replace new one.
Hope this suggestion/Recommendation or solution helps answer your problem/concern regrading on your problem.
If you need more assistance just reply to this post or contact me as soon as possible and i am very much willing and eager to provide your with answers that helps your problem as best as i can.
If you find this solution/Recommendation/Suggestion useful please rate this one. Thank you and god bless my friend.
Posted on Jun 26, 2009
  • Jonas Awayan
    Jonas Awayan Jul 10, 2009
    My friend did you try my solution? So how's the progress? you can contact me to geo_jonas@yahoo.com or reply to this post.
    Thanks
I NEED TO KNOW HOW TO ADJUST VOLUME ON PLAYBACK MODE FOR MY CYBER SHOT DIGITAL CAMERA MODEL DSC 2100
When I had a Sony Cybershot, during playback mode the volume was controlled with either the Up, Down or Left, Right buttons (the circle with the little pictures on it; it's been like 3 yrs since I had my Sony) & I could adjust while it was playing. Hope this helps.
Sep 01, 2011 | Sony Cyber-shot DSC-S730 Digital Camera
My Sony Cybershot DSC-N2 touchscreen will not work.
if the initialize and calibration settings cannot be accessed if the touch screen is not responding, try to power reset the camera: turn cam off, remove the battery, make sure the cam is not connected to an optional ac adaptor, set mode switch to play, press and hold down the power button for a minute, let go and turn cam mode back to off, reinsert battery and turn cam on. if touch screen is still not working, unit may require service. hope this helps. thanks:)
Aug 25, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
I have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing...
i have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing its takin pictures as normal just without the flash it wont let me change the settings of the flash at all
Jun 14, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cybershot DSC W70 Will not take picture it will only take video on still picture mode? How do I reset the settings
Did you ever remove the dial and put it back on?
Turn the dial to a different location and try to take pictures. try all the settings untill you get the correct one. Good luck
Jun 09, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
No view on screen of what is showing in front of lens. Menu and playback shows but nothing when i turn to camera mode or video mode.help!
CCD Failure !
Lucky u can get it repaired Free just call Sony in ur region see link
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
May 05, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
How do I playback video on sony cybershot on the camera itself
Near Mode Dial, there is Playback button, press it to view pictures.
Jan 11, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Sony CyberShot DSC-N2 - Unable to read memory card
Before anything else.... you must examine first if your card is not damage, How? Try to test it in the memory card readers or other camera that fit the same memory cards.
Some other cards do have lock option in the jacket of the card. Try to unlock it. After doing so reformat the memory card in to your cam.
Other option...... Some other cam do have internal memory, if you have the same, configured it out.
Oct 29, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Cybershot dsc-w50 records movies instead of pictures
I had the same problem with my camera.  I found that changing the mode from Multi Burst to Normal allows the camera to take normal pictures.  Go to Menu and scroll over to Mode, then select Normal.
Jul 10, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Cameras Logo
593 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
