Just bought a house with a Thermal zone heater/ air conditioner G(M,N)(-) K - Series 80 upflow horizontal, need a filter for it. Were do I get one??? Last owner left no paper work on unit. I'm from the Philadelphia, Pa area. Thanks
  • 3,600 Answers
Any AC shop will carry it also lows, Wal Mart Diamond and any hardware store will have it and you should be able to find the filter as a drawer inside closet it most likely will be a 24x24x1 inch filter but could be bigger.
Posted on Jun 25, 2009
Are the filters for my Ruud 80 plus furnace supposed to be installed vertically or horizontally?
Hello Donna Haslam
What ever EFECTIVELY BLOCKS all air
BEFORE it enters your heater...
Check out your air intake...
If this is the DESIGN EXERCISE it feels like...
Consider buying an INTAKE HOUSING
that takes a STANARD SIZE air filter.
FILTER...
AT THE INTAKE is a superior location
because it prevent dust & "stuff" from
EVER ENTERING your DUCT work.
Carnac
Carnac the Magnificent
Mar 19, 2017 | Ruud Heating & Cooling
What airflow does RHEEM RGLN 07eamer Furnance have? Is it downflow or upflow?
looks like Downflow
Rheem Classic Series Downflow Gas Furnace cdn.globalimageserver.com/fetchdocument-rh.aspx?name=rgln... · PDF file Rheem Classic® Series Downflow Gas Furnace FORM NO. G11-519 REV. 1 RGLN- Series ... RGLN- SERIES 05EAUER 05NAUER 07EAMER 07NAMER Standard Filter ...
Feb 18, 2016 | Filter Heating & Cooling
How do I get the flame to start?
better call your gas company and get it checked .
Nov 30, 2015 | Rheem RGPN07EAMER 75,000 BTU 80%...
Does Malm Day and Night furnace have a filter in the main unit?
Assuming this is a upflow unit? Disconnect power,remove panels should be 2 . Look in blower housing opening bottom of unit where air enters. Units come with filter new.
Oct 16, 2014 | Heating & Cooling
What could cause carrier fault code 42 besides bad inducer
Could be several causes.
1. Blockage on piping
2. Water in inducer housing slowing down inducer impeller
3. Condensate trap for furnace clogged up.
4. Inducer motor going bad.
5. Leak in vacuum hoses or not connected.
Welcome To the Best HVAC
Oct 09, 2014 | Carrier Comfort 13 Series 1.5 ton 14.5...
Where are the filters located
THIS MODEL NUMBER IS FOR THE CONDENSOR ONLY. THERE A COIL CABINET INSIDE YOUR HOUSE. IT IS NORMALLY MOUNTED ON THE TOP OR BOTTOM OF YOUR FURNACE. LOOK FOR THE INSULATED PIPES CONNECTED TO IT. THE FILTER WOULD BE DIRECTLY BELOW OR DIRECTLY ABOVE THIS DEPENDING ON YOUR SYSTEM BEING UPFLOW OR DOWNFLOW.
Jul 14, 2014 | Goodman Manufacturing GSC130301 Central...
Change air filter
it would be on return air side of unit.
Apr 15, 2014 | Ruud RGPS10EBRGR Zephyr 100K BTU 80%...
CANNOT LOCATE FILTERS ON AC UNIT
Usually the filter is inside the heater housing. You remove the heater access door which should have a safety switch that opens when you remove the panel, thereby removing power from the electrical system on your unit. The filter, if there is one will be below the fan motor on an upflow heater.You should be able to see the filter when you open the heater access panel.
There should also be a filter in your return air duct or at the grille. The sizes of the filters are usually on the side of the filters.
If this helped you please take the time to write a short testimonial.
Aug 04, 2011 | Ruud UAKA018 Air Conditioner
Rheem rbha-21a00nfaa unit is losing water into updraft area
if it is a horizontal it needs a drip sheild. if it is an upflow the cfm might be set to high on the blower
Aug 16, 2009 | Heating & Cooling
I need to find out what this furnaces tonnage is. Model #UGAB075BUH
Here is what I have
Evcon furnace
Gas
Single stage
80% efficiant
Upflow/horizontal
75,000 btu/h or 6.25 Ton heating capacity
3 Ton blower package
Jun 26, 2008 | Heating & Cooling
Heating & Cooling Logo
159 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
