Question about Singer CE-100 Futura Computerized Sewing Machine
Singer ce350 bobbin thread on top
I embroidered something I had digitized and it turned out perfect on the test fabric. The next morning, I tried to embroider on the actual fabric and the thread kept breaking, then the needle. The bobbin thread was showing some and the thread was bunching up on the bottom. I replaced the needle and tried to go on. There is more bobbin thread showing than the upper thread which is all underneath. It was working fine the night before!! I have tried different needles, turned off the machine and restarted. I have threaded and rethreaded both threads a dozen times - following the instructions to a T. Tried a different pattern. Tried the "tension test" mentioned on this site - it passed. I am just learning to use this machine. What am I missing?
  • lsc2 Jun 25, 2009
    Please disregard this question as I realized I put it under the wrong sewing machine. I relisted under futura ce350
  • Singer Master
  • 12,643 Answers
Be sure when you are threading the top thread that you ALWAYS RAISE the presser foot. This releases the tension disk and allows the thread to seat properly.
Have you gone back and re-tested on your test fabric? Does it work okay on the test fabric? If so, then there's a suspicion that it has something to do with the fabric, needle & thread of your project. Is your project fabric very dense, heavy... Are you using a stabilizer? A hoop--is it taut, not stretched? Make sure the fabric is not trampolining. Could be an incompatibility. The needle & thread may be having difficulty piercing the fabric. Try a different weight needle, perhaps a microtex or embroidery needle.
Posted on Mar 23, 2017
SOURCE: Upper Thread Error
there could be thread caught in the tension disc in the top of the machine you can get the cover off to clear the thread but it is a bit tricky to get back on
Posted on Dec 06, 2007
  • 46 Answers
SOURCE: singer ultralock 14 sh654 I was
Have you checked the bobbin?
Posted on Oct 24, 2008
Mimito7
  • 128 Answers
SOURCE: thread bunches up under the fabric
For normal everyday fabric, tension should be 3-5.
If it is looping on the bottom, the problem is the threading of the machine. If it loops on the top then the problem is with the bobbin.
Posted on Apr 19, 2009
sew dutch
  • 25 Answers
SOURCE: keeps "birdnesting", besides rethreading, how do I fix?
when you have bunching on the bottom, you have a problem with the top thread: no tension. (and visa versa) Make sure the thread runs through the tension discs, these discs are activated when you put the presser foot down, so you want to thread the machine with the foot up, also feel if there no burrs, hooks, or whatever, so your top thread comes smooth off the spool, no jerking.
Posted on May 26, 2009
  • 51 Answers
SOURCE: Hi, I'm trying to embroider
The plastic drop-in bobbin case, is the worst I have ever seen. The thread will get jammed in it or it hops while the machine is sewing. It is not staying in place. In front of the case, on the right there is a tiny, rectangle spring. It is the only thing I can find that keeps it in place. It is attached with a tiny screw and can be moved forward.
Posted on Sep 06, 2009
Threads bunching up on singer 7256 when i start sewing
1. I believe that your bobbin tension is too tight.
2. Your top tension should be at about four.
3. When you do your top threading check the tension before threading the needle. It should have some tension but it can't be too loose. Do this with the foot down.
4. If you have adjusted the bobbin more loosely replace it and turn the hand wheel with some fabric in place. It should come out with a nice stitch. You may have to do very small adjustments to the top tension to make the stitch perfect.
Nov 04, 2016 | Singer 7256 Sewing Machine
Why is the fabric bunching into the bobbin when embroidering with the Singer Futura
bobbin thread is too high pressure or too low pressure on teh top adjustment!
remove bobbin and turn tension screw about 1/8turn left (anticlockwise) check if still grabbing, if so - top thread turn about 1/4 turn (at embroidery ir should do automatically, but sometimes need kick...).
check if it is still grabbing on the bottom, do it grab during straight? zigzag? double zigzag? if do not - setting on the pattern need to be look at. if it tangle as well on these three - need definitely servicing...
follow manual how to adjust.
Jan 09, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
How to fix singer 1022 sewing machine
Wife had a lot of thread UNDER the material. I pulled out the bobbin holder and tightened the inward screw. The machine works wonderful now. So IT CAN BE THE BOBBIN HOLDER. Cleaned machine with compressed air and oiled. Singer 1022. She says the stiches are perfect now.
Mar 23, 2012 | Sewing Machines
My Singer Futura keeps beeping and stopping every few seconds.
There are a few problems this could be. Your top thread could be broken or about to break; your bobbin thread could be broken, about to break or empty/about to become empty and is loose around the bobbin; you could have a birds' nest (a mass of thread just under the fabric/presser foot and/or within the feed dog and bobbin) forming and causing a jam; or it could be your Futura having a little bit of a hissy fit. Obviously, if you've checked for broken thread you need to move on. Check for a birds' nest by removing the fabric and clip your threads. If you find one, clear it, rethread your bobbin and begin sewing again. If there's no birds' nest, then place the fabric back in and try sewing/embroidering again. If the machine acts up again, I recommend removing the fabric/hoop, rethreading your top and bobbin threads, replacing fabric/hoop and resuming where you left off. If the machine still gives you trouble, try hitting the start button for a couple of times and seeing if the problem doesn't simply resolve itself. When you're embroidering areas that have a few small, short stitches only, the machine seems to act up a little and then behaves fine once you bypass the area. Be sure to take all of the other steps first, though, because a birds' nest will RUIN a beautiful seam or embroidery.
Feb 06, 2011 | Singer CE-100 Futura Computerized Sewing...
I have a Singer CE-100 and I would like to know why it keeps beeping and stopping?
Nov 11, 2010 | Singer CE-100 Futura Computerized Sewing...
My bobbin thread keeps coming to the top of my fabric during embroidering on my Singer Futura CE350, I've tried bobbin embroidery thread, regular embroidery thread and clear nylon thread, I've tried...
With the embroidering, some of the bobbin thread is SUPPOSED to show on the top of your embroidery-the machine isn't doing anything incorrectly. You'll need to thread your bobbin with the same thread as you are using with the top. I had the same "problem" when I first got the machine and took it to a wonderful local technician whose helped me with a lot of things who informed me that this is perfectly normal on embroidery machines.
Oct 23, 2010 | Singer CE350
I have the futura ce-100. When embroidering it
This annoys the heck out of me, cause it happens a lot more than it should. There can be some valid reasons as to why it happens, though.
Mar 22, 2010 | Singer CE-100 Futura Computerized Sewing...
I had to replace a bobbin case because either a design ( I made) was too dense or my thread caught on something and the machine needed to be timed. When I did the test stitching in sew mode it stitched...
Being simple minded as i am, if your singer ce100 works the stitch looks good just be glad you are not having the problems so many are, if you want to see bobbin thread on bottom tighten top tension
Sep 23, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer Futura 350 bogus thread breaking error
I had the same problem for a LONG time. Yesterday I finally removed the top and the cover for the upper tension and found thread fragments under one of the discs. I removed it and used compressed air for dust clean out and it is working wonderfully. Good Luck
Aug 24, 2009 | Singer CE350
Bobbin Thread
I have had the same problem. I always just used the same color of bobbin thread as on the top. It is a pain to change inbetween each block, but the designs usually look perfect. I will have to try playing with the tension.
Sep 24, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-100 Futura Computerized Sewing Machine Logo
347 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
