Question about Samsung RS2630SH Side by Side Refrigerator
Frozen ice tray Samsung noit making ice
My Samsung not making ice. Opened up the ice making section----all FROZEN up. How do I break this free and get back on line.
I had a similar problem. It had to do with water pressure. When I put in a new water line tap, it increased the pressure and has made ice perfectly since. I had to use a blow dryer to thaw
Posted on Jun 28, 2009
My Samsung Refrigerator, RF263BEAESR/AA ice maker has white ice surrounding the ice maker and won't dispense the ice. The long narrow tray in the refrigerator is locked and I can't pull it forward.
Before finally curing all the problems I've had with MY Samsung Ice Master ice maker I experienced the same problem you have just described. For a number of different reasons water has leaked down to the bottom of the icemaker compartment and actually frozen the ice tray to the bottom of the housing. In my case, a number of sharp blows from the edge of my hand was able to break the seal that ice has made between the tray and the compartment. Sharp blows, not brute force. After removing the ice tray you need to wipe out the remaining ice with a wash cloth soaked in hot water. Until the available kit is installed this problem will re-occurr with great regularity..
Oct 31, 2017 | Samsung Refrigerators
Managemylife com sears
check that the ice maker is not jammed with frozen ice
dont force the tines on the tray to turn . lightly geared clock.
can you hear the little clock motor running quietly wirrs
is the water running out the front ok
is the water frozen before the tray ,defroster issue then
hit it with a hair dryier for a few mins an see what it does when u close it .
Jul 25, 2014 | Samsung RSG307AARS - 30 cu. ft. Side by...
G16farxxqo7 ref wont make ice where is water valve
So you want it to make ice water. And it comes out not frozen.
Is the water cold? if it is cold then it is making ice water ok.
Ice water is never frozen, only ice is frozen.
Dec 21, 2013 | managemylife.com
I have an LG LFC21770 refrigerator and have noticed a build up of ice on the back wall of the freezer section. Yesterday, when I opened it to get some ice - the ice was frozen but had obviously melted...
If the freezer fails to defrost you get ice building up at the back of the freezer.
The defrost cycle relies in a thermistor transducer to detect the ice build up and to turn on the defrost cycle. The water usually then drips down to a tray under te fridge and then gets evaporated away.
Hopefully you only have a problem with the thermistor and not the defrost circuitry,
This is hard for a repair man to diagnose as when you call them out to your fridge it will be impossible to diagnose if the freezer is totally packed with ice.
And if you let it defrost totally it will be hard to diagnose as they may not be allowed to use freon to cool the transducer.'
So if you call someone in to check this you need to know if the ice build up will be a problem for them .
Youtube has several videos on this situation .
Apr 21, 2017 | LG LFC21760 Bottom Freezer French Door...
Frozen solid cube tray
Unplug the frig. Take a hair dryer and melt the ice tray. Then get a paper towel and soak up the left over water. hope this helped
Mar 30, 2010 | Refrigerators
My ice maker has quit working. The water is not filling the tray.
Pour 1/2 cup of water into icemaker . If it dumps the cubes when frozen , then check the fill tube going into the icemaker , to see if it is frozen solid . If it is , remove and clean and replace water valve ( drip seeping ) . If not frozen , replace the wqter valve anyway . If the icemaker doesn't dump the cubes , and holds the frozen ice , replace the icemaker , after making sure the coils under fridge are free of dust , lint , pet hair etc.The icemaker needs to be 5 degrees to operate , and , dirty coils could bring the temp up to 6 or higher in the freezer section .
Aug 27, 2009 | Whirlpool Refrigerators
NO WATER DISPENSING FOR ICE
did you clear out the fill tube in the freezer section that lets the water enter the ice maker, it could be frozen
it the line and the tube are clear then replace the water valve
May 11, 2008 | Kenmore 26.0 cu. ft. Side-By-Side...
Ice accumulating in freezer
There should be a tube that brings water to your icemaker from the back of the fridge into the icemaker. This tube is frozen with water, or the inlet where this tube feed the icemaker tray is frozen. The result is that water cannot go to the ice maker, and instead, goes over the top of the inlet area.
Verify that this is indeed what is going on.
The fix is to remove the blockage/buildup of ice at the inlet. You may have to detach the icemaker to get to it. Be carefull with electricity! Also be carefull as plastic can break under stress!
The tube may be frozen to the inlet, channel locks can be used to gently twist the tube to break it free.
Good Luck!
Jan 01, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
348 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
