Question about Dell Dimension 8300 PC Desktop
My dell desktop screen says AutoAdjust and then
My dell desktop screen says AutoAdjust and then goes black. If you turn the monitor off and then right back on again you can see everything clear as day for about three seconds and then it goes black again. The computer works fine during this. I can get on the internet, inot all of my documents, log off, log on etc. I have to keep turning the monitor off and then on to see what i am doing. I did that to make sure the computer was working fine.
    Sergeant:
  • 173 Answers
Install graphic drivers from following link
then cherck ,.
If you still face problem then when you power up the computer pressF8 key then enter in enable vga mode. then change screen resolution to 1024*768
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8300&os=WW1&osl=en&catid=&impid=
Posted on Jun 25, 2009
Dell 1905FP powers up but screen goes black after a few minutes
The monitors inverter seems to be failing. If you look up close, can you see a very faint image of the desktop?
You should think about getting a new monitor it might be cheaper than repairing.
Feb 14, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
I turn on my computer and my monitor is black. I
try to check your V.G.A port it might be loose or check link chord or else remove your Ram and rub it with eraser the down portion of ram and clean it insert it again your work is done...
Jan 20, 2010 | Dell Precision 380 P4 Dual Core 3 GHz...
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
My dell computer screen goes black after a while after windows xp second up grade went on. what should i do without taking upgradee off or changing screens?
Right click on your desktop go down list to properties and left click under the screensaver tab click the power tab and turn off the power saver in other words change settings to always on and no hibernation
Nov 06, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Delll flat screen moniter goes black.
Assuming you are running XP.  Right click on the desktop, select Properties, select the Screen saver tap.
Click on "Power"
See adjust the time out so that it is  "Never"
May 18, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
UltraSharp 19' Screen will not autoadjust.
Start in SAFE mode (press F8 wile booting) and choose Last Known Good to see if it works in Windows DEFAULT setting.
My guess is that MSoft pushed a patch or SP to your box and IT replaced the dll your monitor was using.
Goto www.support.dell.com and DL the correct drivers again
Good Luck!
Let me know what you discover ;-)
Let me know if this fixes it
Mar 26, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Monitor goes blank less than a second after turning on.
Monitor is bad for sure. Try another known good monitor on your computer and if the problem stops then you know for sure the original monitor is bad. Hope this helps.
Feb 01, 2009 | Dell Dimension 3000® Pentium® 4...
Dell desktop running windows XP
You should be left-clicking when the option for safe mode comes up...
Dec 15, 2008 | Dell Inspiron 8500 Notebook
Dell monitor
Sounds like there is a heat related problem. Probably a bad solder joint somewhere. Could be hard to track and would probably cost you more money to repair and it does to purchase a replacement monitor. 17" LCDs go for around $150 these days.
Oct 28, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 8300 PC Desktop Logo
148 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
