Question about Kenmore Dryers
My dryer runs but no heat . model 110.68932792 . Kenmore 90 plus series type DDOT ELE2406028 EH54
  • 351 Answers
You either have a bad element or thermal cut out is bad check for 220 volts at the element if you dont have 220 then the thermal is bad if you do have it the element is bad i can get you them parts.... whirlpoolpartssurplus.com
Posted on Jun 25, 2009
My Kenmore Dryer 90 Plus Type DDOTELE2406028-EH54 Mod 11068942892 runs but does not heat.
The common problem in this case is in the high-limit thermostat and the thermal cut-off located on the heater housing. Verify this condition by bypassing the said components. Disconnect power then access the thermal cut-off (cut-out) and the high-limit thermostat by removing the bottom front panel.
Removing Bottom Front Panel
Disconnect the wires of each component then connect them together and insulate it properly. Reconnect the power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make. Let us know should you need further assistance.
Dec 21, 2010 | Dryers
I have a Kenmore dryer, mod 110 60956990, ser MJ4102370, type DDOT-ELE-2406028-EH54. When I push the button to start the dryer, nothing. If you wait several minutes, it sounds like it is trying to come on...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 28, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer has power, motor runs, Won't heat. Kenmore Dryer Mod# 118 C68932792 Serial # MJ 3787524 Type - C007 ELE 2386824 EH54
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 10, 2010 | Kenmore Dryers
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
Dryer wont stay on... it appears to have intermittent heat.
You have a broken belt. This dryer is complimacated but here goes.Remove the console screwsand flip the control panel upwards simular to what they do on washers. Remove the 3 screw in the rear that hold the top and get the top off. Pop the bottom panel and back off the screws holding the front on then remove the screws from inside the top. You can get the front off now. Get the drum out and clean out the dryer. Oil all 4 wheels and idler. You will note the micro switch below the idler. that stops the drum from turning when the belt breaks. You will be a pro if you can fix this one.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 21, 2008 | Kenmore 63942 Dryer
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Jun 13, 2008 | Kenmore Dryers
Dryers Logo
271 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
