Question about Brother SX-4000 Typewriter
When I'm typing it's not typing the correct letters they look Greek or something, I've tried holding down the reset and code button at the same time to make the wheel spin and it's still not working
  • 239 Answers
Not seeing this typewriter is hard to troubleshoot.
First, if the black platen roller has many indentations due to a lot of use, these platen has to be dressed.
To dress it, this means it has to be removed and buffed. To do this one needs a "Wet-Dry" sand paper, "Fine Grit" 320 or 400. Wet the paper, and sand it like a piece of board. You may not get all the indetations out but it will be much better.
Clean it with water only, and Dry.
Before inserting the roller check the plastic guide or metal if they have it, for gummy edges. The ribbon and correcting tape goes up and down and they rub against these edges. They have build up of gummy stuff, if you can clean it completley off, you will get much reliablilty on the typewriter. Less ribbon snagging.
Most people think the supplies are the issue, but in reality, most problems are the ribbons and correcting tapes are snaging on this card guide.
Other problems with ribbons not advacing can be competitive supplies, but not seeing the machine it is difficult to isolate the problem.
Mechanical linkages (binding or broken)in the ribbon assembley can cause these types of problems, ribbons not advancing.
Also, a circuit board can cause these types of problems irratict printing images. Not an easy problem to isolate.
These types of solutions need to be applied then see how the end result works out. If it does not correct the problem, then the next area has to be isolated, due to lack of information provided about the problem.
Good luck.
Posted on Oct 20, 2009
We are purchased medicine from English Company as on 17.04.09 Rs.34688.some items are returned to supplier as per bill (around Rs.7000).they are not issuing credit note to till yet. As per your request the full amount will paid to Supplier Rs.34688 on 27.07.09.Several times supplier called to accounts dept for the August payment ..After getting the credit note the payment will made. So Plz follow –Up the credit note
Posted on Sep 23, 2009
  • 43 Answers
Change Cassette daisy wheel.one with the letter
Posted on Jul 30, 2009
What do I do when my typewriter types different letters and symbols than the keys being hit
Turn the machine off then on or hold down the "code" key and hit Q "reset" key to get the machine to type the correct keys. This usually happens because something interferes with the free rotation of the printwheel. Check to be sure the ribbon and corredtion tape are installed correctly and check to be sure none of the "fingers" on the printwheel are bent outward. If a finger is bent, bend it back. If everything looks okay, the board or power supply is going bad.
Feb 23, 2015 | Brother GX-6750 Typewriter
How do i get my Brother A X 250 Eletric Type writer to type the correct letters ?
"If your unit is not printing properly:
1.Ensure the ribbon cartridge has not run out of ribbon. If your ribbon appears silver or gray, install a new cartridge.
2.Ensure the black lever in the center of the carriage is pressed to therear towards the paper. If not, press it to the rear to lock the Daisy Wheel into place.
3.Reset the unit by holding down the [CODE] Key and pressing the [SHIFT]Key and the [WORD OUT] Key.
4.Release all three keys.
5.Try typing.
If the problem continues, your unit will need servicing. You can locate a Brother Authorized Service Center in your area:
http://www.brother-usa.com
Feb 27, 2013 | Brother SX-4000 Typewriter
My Brother ML100 is not printing what I type
Hammer sticking and typing incorrect letters (and or skipping letters): 1) make sure daisy wheel installed correctly. 2) hold down CODE key & Q (RESET) to reset wheel...if still not corrected 3) WD40 the hammer at the base & joints where moving parts are, keep typing until oil seeps in (this last one fixed it for me)
Typing light and inconsistant-top part of letter okay but bottom too light or not there: to left of hammer (at base) are 2 screws, I losened them and adjusted hammer to different forward and backward spots..finally found the ideal location where full letter printed and had the correct force it needed to print correctly.
Feb 21, 2013 | Brother ML-100 Typewriter
I forgotted the code how can I reset the stereo
Many Kenwood radios are configured with the same security codes:
* KCAR - This seems to be a "backdoor" to some Kenwood models.
* 3051 - This is the security code which is printed in the manual of many Kenwood models.
* 1234 - This is a security code commonly chosen by Kenwood owners.
Entering your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
* During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
* Enter the security code using your Kenwood remote.
Type 2
* Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
* Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
* 5
* 5
* Track Up
* 2
* 2
* 2
* Track Up
* 2
* Track Up
* 7
* 7
* Track Up
Your Kenwood should then enter tuner mode.
Newer Kenwood models have the security information stored in non magnetic flash memory.
Once the code is set, it cannot be retrieved by a "backdoor method".
Proof of ownership is required. You can take the radio in to any AUTHORIZED Kenwood retailer - and in 10 minutes - they can have your radio reset for you.
If all else fails, you can send your stereo back to Kenwood to have the security code reset. They require proof of purchase.
This can be a receipt, or a used car invoice.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 30, 2010 | Kenwood KDC-MP4028 CD Player
The keys don't type the correct letter
Loosen the screws that hold the silver guide, one on each side of the carriage. Adjust to touch platen with 2 sheets of paper installed. When you reset next time it will reset to the right letters.
Jul 01, 2009 | Brother GX-6750 Typewriter
Typing in jibberish when i type a letter
Hold down the CODE key and the "L" key (says 'lang' underneath the "L")
Feb 16, 2009 | Brother SX-4000 Typewriter
HELP..BROTHER DAISY WHEEL TYPING RANDOM LETTERS AND SYMBOLS
Press the Code button and the Q/Reset button at the same time and the wheel will spin and go back to the correct place.
Feb 06, 2009 | Brother SX-4000 Typewriter
Cannot remember my security code after reset Kenwood kdc-mp435u
Try code KCAR entered from the remote. 3 entry methods are detailed below.
Common Kenwood Security Codes
Entering Your Kenwood Security Code
Type 1
Type 2
Press and hold the "Auto" button and "Track up" (next track button on the right) on the face of radio at the same time until the four dash lines disappear.
5
5
Track Up
Track Up
Track Up
7
7
Track Up
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
i hope this works for you.
Jan 09, 2009 | Kenwood KDC-MP435U CD Player
IPhone Touchscreen Partial Hypersensitivity
Have you fitted a screen protector, as this could be causing inadvertant screen touches. If not try a reset. Hold down the power key at the same time as the round home key until
phone powers down. Release buttons only when you see the apple logo,
then wait a min or two for phone to re-boot. You will not lose any data on the phone.
If this does not work, try an actual system reset. Sync iPhone to computer to back
up essential data ie contacts apps etc, then go to settings general and reset. Reset
all settings as a last resort. This will give you a fresh start and should sort out
the majority of any bugs the phone has. A resync with you computer will restore apps etc.
Hope this helps and if so please vote.
Thanks
Jim
Dec 21, 2008 | Apple iPhone 3G
Wong letters & numbers
I downloaded the manual from http://www.devicemanuals.com/downloadguide.php and then, following the instructions there, I removed then re-inserted the daisy wheel. This solved my problem. Perhaps it had somehow gotten out of adjustment. At least, it is something to try if you haven't tried it already.
Jul 15, 2008 | Brother GX-6750 Typewriter
Brother SX-4000 Typewriter Logo
329 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
