Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Shadow tv model kp-46wt500. ghost shadow in red in white
  • Sony Master
  • 8,617 Answers
The sony convergence Kit Type 1 available at the following link will usually repair that issue. The kit contains the parts plus a CD with detailed instructions to do the repair.
www.tvrepairkits.net
Posted on Jun 25, 2009
The picture is red ad green shadow and the word are also repeat red and green shhhhhhhhhhhhhhhhhhhhh bad sont tv
Blue Jet drive is blown. This will need replaced and the TV will need re-aligned. This may cost more than the set is worth.
Aug 27, 2011 | Sony KP-46WT500 46" Rear Projection...
3D image, ghost image, with shadows. how can I fix it?
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 05, 2010 | Sony KP-46WT500 46" Rear Projection...
Red ghosts in mod kp-46wt500 sony
Go into the customer menu and select CONVERGENCE and look to see if red or blue lines are skewed and or will not adjust in some direction.
If this is what you find--you have a convergence circuit problem.
Let me know if this is what you find and I can tell you what parts need to be looked at and replaced and I can give you general instructions about what you will need and the best place to find them.
Rate this solution if this information has helped you as I do this here for free.
SD TECH
Dec 09, 2009 | Sony KP-46WT500 46" Rear Projection...
I have a sony projection tv KP-46WT500 and have red/green shadows around the people plus some double word image that are red & green. On the tv guide the station #'s are double and green and red.The...
Replace Both of your convergence ICs STK392-??? they are big black ICs will have part number on them also CK pico fuses they look like resistors but are fuses they will be yellow or green will be around ICs.
Aug 08, 2009 | Sony KP-46WT500 46" Rear Projection...
Ghost shadows on the Sony KP-46WT500TV
you can get the KP46WT510 convergence repair kit at the following link under convergence repair kits category which will also work for your model.
http://servicemanuals.vstore.ca/
Apr 12, 2009 | Sony KP-46WT500 46" Rear Projection...
Kp-46wt500 shadow and slanted images with rainbow colors
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 04, 2009 | Sony KP-46WT500 46" Rear Projection...
Color alignment kpwt500 tv
i would have a shop reconverge it.thats going to be the easiest way to get the picture back the way it should be.
Jan 13, 2009 | Sony KP-46WT500 46" Rear Projection...
Red shadows of words on screen of projection TV
you have to go into the menue, and go under video settings, under advanced, then into convergence, when you get the white lines all over the screen, follow the directions and adjust the red so it lines back up, other wise , take the front bottom panel off the tv, look for the 6 little nobs, look at the ones on the left, they should agjust the red, thrn the top one untill the red is focused back in.
Nov 27, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony kp-46wt500 problem with picture
i'm having a problem keeping the timer from going off and shutting the whole tv off.
Mar 20, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
142 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
