Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Won't stay running
Replaced all three fuel lines on poulan model ppb250e trimmer. since then will crank but after a few seconds it quits. could you also describe where each fuel line connects?
  • 1,041 Answers
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
Jim
Posted on Jun 26, 2009
  • Jim Parker
    Jim Parker Jun 26, 2009
    The longest, and sometimes smaller in diameter of the two fuel lines, goes from
    the carburetor to the bottom of the tank. Leave enough slack in this
    line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
    The
    other
    fuel line goes from the primer bulb to just inside the tank,
    (about an inch). make sure that you get the right size fuel lines. The
    plastic coupling goes on the end of this line, inside the tank. This
    keeps the line from pulling out of the tank.
    (HINT): When feeding the lines through the tank holes, cut the lines at an
    angle. They will feed much easier into the holes. You can than cut them
    off square, once you know that you have enough to work with.
    If you need further assistance, just let me know.
    Jim
  • Jim Parker
    Jim Parker Jun 29, 2009
    Did this solution solve the problem?
    Jim
Poulan ym20cs won't stay running
Sounds like it needs carb adjusted and/or rebuilt.
Jun 24, 2014 | Poulan Garden
Will not stay running
Obvious fuel issue, adjust carb, rebuild or replace fuel lines or all.
Dec 11, 2013 | Poulan Garden
My PE550 weedeater edger that won't stay running. I have new carb, new fuel lines, new starter coil. any idea what could be the problem? I am now checking the gas cap, breather is good
check your fuel lines ensure you have them on correctly also check spark plug clean if necessary also when you change out fuel lines and carb it may take quite a few pulls to crank cause the little fuel system has to get primed up!
Aug 09, 2013 | Poulan Pe550 Gas Edger
My string trimmer ppb250E will not start and is leaking fuel. How do I remove the plastic shroud to get to the carburator?
The cover is held in place with probably 4 screws of the Torx head variety. Once you get that off, you will be able to access the carburetor. If the fuel leak is at the carb, you will need a gasket and diaghragm kit. If the hoses in the fuel tank are leaking, you will need new fuel lines. IF the fuel tank itself is leaking, you can seal it with a product called "Seal-All" that is quite resistant to oil and gasoline.
Oct 02, 2010 | Poulan Garden
Need a gas line diagram for a poulon pro ppb250E
i need a gas line diagram for a yamaha vmax it leaks gas all over
Sep 18, 2010 | Poulan Garden
Poulan Pro PPB250E trimmer won't idle
clean and repair carb, make sure the mounting gasket is ok. and does not have a vacuum leak.
May 28, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan GHT-22 Hedge Trimmer The Primer Button Will Not Inflate
When changing the fuel lines did you get them back in the correct location? This would prevent the bulb from working. Also, if the bulb is old and brittle or leaking, would also cause hard start or leaks around the handle.
Jun 18, 2017 | Poulan Garden
GHT-22 Hedge Trimmer Fuel Line Replaced and Still Won't Crank
to solve your problem i am sure you can solve your problem just visit at the link given http://toolsnyou.com/
Aug 09, 2017 | Poulan Garden
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
900 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
