Question about Marvel 61WC Wine Cooler
Marvel 61WC Wine Frige Won't Turn Off
Similar to other problems mentioned, my wine refrigerator won't turn off once it comes on. I replaced all three parts: thermistor, control box and potentiometer. The issue still remains. Any further advice?
  • 93 Answers
On that black control box, you have to set those small switches to match your 61 WC or you may connected the wires wrong, also make sure you install the thermistor at the correct area. Marvel # 800-428-6644
Posted on Mar 02, 2010
    Novelist:
  • 101 Answers
Check he frost pattern on your evaporator. That is a plate sensing control and if the system developes a freon leak you will have frost on the beginning of the cycle (middle bottom and travels to the left, then across the top middle, then to the right and back to the lower middle) but not at the end where the thermsitor senses temperature. This will cause the unit to run almost continously no-matter what setting you have it on. If this is so, you need to have the leaking component repaired/replaced. You will not want to let your unit run like this since the longer you do..the more components will get damaged. If you are still with-in your warranty period, contact your dealer to initiate service. If not, contact any appliance repair shop you trust in your area. I hope this helps.
Posted on Sep 15, 2009
How do I check the relay?
This video explains most of what you need.
Jul 31, 2015 | Marvel 61WC Wine Cooler
Why does my wine cooler run too cold?
If after adjusting your thermostat to desired temp and is still cooling. The thermostat is bad or your relay is bad
If you disconnect the thermostat and the compressor stops it most likely a bad thermostat
If you disconnect the relay from
The thermostat and it stay running it is the relay. It is sticking
If possible store you wine somewhere else and shut the unit down and unplug for 10 to 20 minutes this may cause some melt of condensation some water may be on the floor if is to cold
This may also reset the system.
Jul 26, 2015 | Marvel 61WC Wine Cooler
Marvel 6BAR6004 not cooling
check you themoistat it may be coated with sofa
Jul 04, 2014 | Marvel 61WC Wine Cooler
How to install incredible hulk pc game
1.the autoplay will appear automatically otherwise open it from my computer.
2.select install from the autoplay menu install it by step by step.
3.dont forget to copy the crack
have a nice game enjoy
May 24, 2010 | Marvel 61WC Wine Cooler
Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at www.lifeluxurymarvel.com
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
Jan 28, 2010 | Marvel 61WC Wine Cooler
My marvel wine cooler is 9 years old and no longer runs. The light works but nothing else runs. Might this be the thermostat? iif so where would I ge a replacement and would would it cost?
This could very well be the thermostat (pre-2000) or part of the temperature control system (2000 to 2009) which has three parts: The thermsitor (usually the culprit), the potentiometer (connected the the control dial) or the control board. Call the factory at 800-223-3900 with your serial number (to identify which control it uses) and you can buy the part direct from them. The control kit is about $150.00, the old style thermostat about $100,00 and if it is just the thermsistor, it's about $50.00 (I haven't checked their prices in awhile)
Jan 18, 2010 | Marvel 61WC Wine Cooler
EVAPORATOR LEAKING NEED PART, FOR MARVEL 61WC
You can order a replacement evaporator assembly directly from the factory at 800-223-3900. I believe (working on memory here) the part# is 42244047 (for black) and 42244046 (for white) It comes with the suction line and capillary tube already brazed to the evaporator plate and comes with a new filter drier. They can also recommend a service technician in your area if you need one, They accept all major credit cards.
Jan 07, 2010 | Marvel (6SBARBSG) Wine Cooler
Humidity and temp control not working.unit is 12yr old
The 61WC does not have humidity control in it unless it was added after the factory. The old style mechanical control is still available from the factory at 800-223-3900 PN 42241702 (ask them to double check my memory on the part number)
Jan 06, 2010 | Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Dec 02, 2007 | Marvel 61WC Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Marvel 61WC Wine Cooler Logo
518 people viewed this question
Top Marvel Furniture Experts
Sal De
Charles T Nevin
Charles T Nevin
Joseph Hoffmann
Are you a Marvel Furniture Expert? Answer questions, earn points and help others
