Question about Sharp Aquos LC-20E1U 20 in. LCD Television
I need to replace a cercuit board in a sharp Aquos TV. Where can I order the part ?
  • 261 Answers
I order lots of boards from Discount-Merchant.com, they have very cheap prices, the only bad thing is that the warranty is offer only to service centers
Posted on Jun 25, 2009
Sharp Aquos LC60LE632U 60" TV 1080p. LCD HDTV. Great picture. Except, there is one green line, running vertical down the far right of the screen. I'm suspecting that it may be the TCON Board.
I had a similar problem with my Sharp Aquos 60" LED and it was the T-Con Board. Simple to replace and can be purchased in the neighborhood of 40.00. If you have sound and a picture, T-Con Board replacement should be your fix. Great videos on youtube if you need assistance. I would highly recommend that you watch the videos prior to proceeding. I am NOT a TV repairman, just a do-it-your-selfer....
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Mar 31, 2016 | Sharp Televison & Video
My TV will connect to the network but is not connected to the internet.
Check the videos to understand how set up the network connection on sharp tv . Hope it would help you to set up your tv. If you go for manual connection the you have to have some information . you can get those information from your internet provider comcast.
http://electro-medical.blogspot.com/
Easy Sharp Aquos TV Setup wifi internet network connection for Netflix apps
Wireless setup for Sharp AQUOS TVs HSN How Setup WiFi On The Sharp Aquos 60 Smart TV
Nov 13, 2015 | Sharp Aquos Televison & Video
My name is glen
When you ordered you replacement board was it specific for your model or did you order by board number, if so it may not be compatible with your TV
Mar 09, 2015 | Sharp AQUOS LC-52E77UN 52" 1080p 120Hz LCD...
What is causing vertical colored lines on the left 25% of my Sharp Aquos display?
Bad TCON board or Damaged screen. You can try and replace the TCON "Timing Control Board" and see if that helps. Replacing the Screen itself is very expensive and normally about half of what the unit cost new. Here is a video to give you a clue on how to do so, it is pretty easy when you know which board to replace.
Jan 01, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Auquos TV randomly reboots itself
Had to put my 50 inch in shop after having it for only 6 weeks. Sharp's needs to replace the main board which is on back order from Sharp. I don't know when I will get my television back.
Oct 15, 2013 | Sharp LC-50LE650U 50" 1080p 120Hz AQUOS...
Hi, my 45" Sharp Aquos
PTS they rebuild boards at low cost 1-800-844-7871
Shopjimmy.com might have boards.
Encompass Parts Distribution 1-800-638-3328
May 31, 2011 | Televison & Video
52inch Sharp Aquos has a constant blue blinking power on light no picture at all.Tried the resets,still the same,installed new inverter boards,still the same.Now what?
This problems is not those 2 long LCD inverter boards problems,why did u replaced those 2 long LCD inverter boards?I fix this problems before for a 46" LCD Sharp Aquos L46D55U tv.This problems,it the Tuner signal board is dead.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Nov 08, 2010 | Sharp LC52D65U 52 in. LCD TV
We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Jan 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-46D64U need to replace broken tuner
actually you dont need the tuner you just need the rf connector itself which you can easly pick up at a radio shack for a few bucks. you can DIY it will take a bit of soldering and time. First take the broken connector to radio and look for a close match, longer leads better you can always cut to fit.
remove board from tv and un solder the tuner. if solder does not seam to melt apply some fresh solder and then unsolder. pop the tuner lid of carefully both top and bottom to gain access to the circuit. cearfully remove any remains of the old connector. Now find the hole where the last part was and insert new RF connector adjust and cut the lead if nessary and resolder to circuit. place both caps back on and resolder tuner to board.connect board to ther circuit and test.
Mar 17, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp Aquos LC-20E1U 20 in. LCD Television Logo
118 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
