Question about Epson Stylus CX5400 All-In-One InkJet Printer
Will print wont copy
My epson decided this morning not to make copies. It will print from the computer, just doesn't appear to scan to copy. Error message-see documentation? Unplugged unit, turned off and retried. Hit reset to default. No idea what else to try.
  • 210 Answers
Turn the Epson unit off. Now lift the scanner cover and look on the left-side for a toggle switch with the familiar lock/unlock symbols. Change the switch to unlock, turn the unit back on, and test for proper functionality.
The following picture should help in locating the toggle switch:
Posted on Dec 07, 2009
  • 170 Answers
Hello mtcurluv this is nichu ,i have a solution for this one.
try installing the drivers again if possible .plug out all the connectivities for your printer and reconnect again .
for direct online interactive support visit this site
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=25301&prodoid=36478881
good luck
Posted on Nov 05, 2007
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson stylus dx6000 only copy in color mode
Any ink in the black cartridge or can you use clean mode to clean it?
Mar 15, 2014 | Office Equipment & Supplies
Epson cx8400 stylus will not print from pc.it will copy and scan.dont know what happened
if you have the cd-rom
remove the program,reboot pc.
install the program back and wait whit connecting the cables,
untill the program ask for it.
Feb 02, 2014 | Epson Stylus CX8400 Series
Copy result is blurred
Does the printer scan OK?
Is the platen glass clean?
Dec 10, 2013 | Epson ME OFFICE 620F MULTIFUNCTION INKJET...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
My Epson RX650 scan software will not start up. The printer works and the copy feature works. When I double click on the Epson Scan icon on my desktop it appears that it wants to start up but then...
Install another scanning software, if you have photoshop or any imaging software, you can use the scanner by going to the menu, then choose File, Import, TWAIN, Acquire and the scanner control will appear.
Or just go to My Computer and double click the scanner icon (in XP) to start the scanning assistant.
Nov 09, 2010 | Epson Stylus RX650 All-In-One Printer
I want to copy a document
How often do you need to "copy" documents. Do you have a document scanner?  Your Epson is a printer.  You'll need a scanner to scan a document into your PC then you can print it out on your Epson.  If you only need a copy once in a blue moon, and you don't have a scanner, save yourself a few bucks and just go to Kinko's or maybe even your local grocery store or library and run your copies there.  They probably cost about 25 cents a page.  A new scanner will run you about $100 bucks.  If you decide that you need a scanner, you might even want to consider investing in a multi function printer which will scan-print-copy-fax.  Hope this helps.  If so, please remember to rate my solution.  Thanks.
Mar 14, 2009 | Epson Stylus Color 600 InkJet Printer
Epson V200 scanner
Epson V200 Copy Utility Problem with Incorrect Margin Output
I had the same problem forever and i just sat down today to fix it.
I have a Konica Minolta PagePro 1350w for my printer. The resolution
is set default at 600x1200 when in the Output Paper - Paper setting.
Change the resolution for your printer if you can to 1200x 1200 in the output paper - paper setting in the copy utility software, and
that should solve your problem with this half page copies. It might
still cut off some margins at the very edge, but most of the time they're just
plain paper margin. Hope this helps you out.
Jul 04, 2008 | Epson Perfection V200 Flatbed Scanner
Epson Stylus CX5400 All-In-One InkJet Printer Logo
70 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
