Question about Hand Tools
I need to know how to connect my catrieges to the power washer
There is a plastic or metal covering over the tip. Pull this covering down towards the trigger mechanisim. This releases the tip.
Posted on Aug 11, 2009
How do i install my soap dispenser into the 1600 all-power electric power washer
There should be a 1/4" hose nipple on the pump which will connect to the soap dispenser with a 1/4" line.
Sep 28, 2013 | All-Power America Garden
How to exit a game from Nintendo Game Boy Advance Sp
Step 1:
Hold down the "L" (shoulder) and tiny "Screen Light On/Off Switch" buttons of the Game Boy Advance simultaneously.
Step 2:
Options menu along with "exit" appear.
Step 3:
Select "exit" and press "A" button.
Dec 15, 2012 | Nintendo Game Boy Advance SP Console
I plugged in my washer maching after i moved. I wanted to check the wall outlet and the washer wont turn on. Water hoses are still not connected. Is it because of that? Do i need to hook up the water hoses...
The breaker may have tripped as some model washers draw significantly more power than others. you should check the breaker and make sure its rated for your washer. I would also not suggest running your washer with out hooking it up to the water line as this can damage the pump.
Jun 15, 2011 | Washing Machines
After refilling catriege any software is there to install in
You dont need any software to install after refilling your printer cartridge
Feb 22, 2011 | Office Equipment & Supplies
Please help me and let me know how turn on the machine I have a used washer machine kenmore elite 45081 but i try turn on an I can't. Thank you.
All you need to do is to connect the water line to the inlet and plug in the power plug to the power outlet.
Now switch on after loading the clothes, set to a convenient program.
The washer will start loading with water and then start the wash to go on for spin ,drain and dry.
If fucntions dont work then you have to start checking.
Sep 24, 2010 | Kenmore 45081 Front Load Washer / Dryer
My kEnmore front load he2 plus washer is flashing f-28 does anyone know what this means?
F-28 refers to Communication Error.
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
- Check connections of the CCU board within the housing.
- Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test
or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing
the MCU connectors.
Note - The cost of CCU and MCU is more than $200 each. You cannot replace a part of CCU and MCU. The complete Set needs to be changed. If the Washer is more than 4 years ( which i assume, as this Error is usually after 4-5 Years ), it is better to Invest in new one than Repair.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 06, 2009 | Washing Machines
Do not know how to work power washer
Dear Carrie688,
I cannot for sure understand your problem. You say, you do not know how to WORK power washer. Does WORK mean FIX...or USE???? I will assume that you wish to know how to use it.
First without water connected and without gun connected...switch on the machine. If it turns, then this means the electric motor is OK. Now connect the hose and gun. Connect water supply. Now always start the machine with gun open. This will help to remove air from system. When pressure builts up, close gun, and machine must stop instantly. If machine does not stop, open the gun again and switch off the machine. If the machine continues working when the the gun is closed, this will result in a lot of damage. I do not know what model you have, because also there are old models that when gun is closed, the machine keeps running. I assume your model is recent. So the machine will stop when gun is closed. Now when finished, switch off machine and electricity. And most important release pressure from gun. Do not store machine with pressure still in it. This will damage machine and it is not safe.
Now if you have detergent, this can only work on low pressure. There are bigger machines that detergent works on high pressure. But the normal system is that detergent works on low pressure. Also before storing, pass fresh water to remove all detergent from pump of machine. Never store a machine with detergent in its system.
Regards,
Fulltech.
May 13, 2009 | Karcher K2.26 Electric Power Washer
How do i know if my outside tap has a non - return valve i want to start using a pressure washer
Dear del_brenda_s,
I have been servicing Power Washers for the last 5 years. And I cannot understand why you need a non-return tap outside. I think "outside" you are refering to the main supply after the water meter.
Well if your power washer needs a non-return, you can fit a cheap garden hose non- return attachment.
Regarding the non-return at the outside tap,..this is most probably NON-RETURN. If you want to be sure you can contact the water works division of your country and city...and I am sure they know what sort of taps should be used. In my country it is a must that a non-return outside tap is used. This is important so that when there is a cut in the water supply, the water meter and the whole system will not have to be bled out of air when the water comes again.
Regards,
Fulltech.
Apr 19, 2009 | Karcher K2.26 Electric Power Washer
Electrical Plug
I guess the washer and dryer are somewhere that someone can get in to use them without permission. Where do you and they get electrical power from?If they are connected through circuit breakers then just throw the breakers when you're not using the machines.
Mar 17, 2008 | Frigidaire FEX831CS Top Load Stacked...
Hand Tools Logo
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
