Question about Ruud Heating & Cooling
What is the proper venting requirements for a Ruud gas furnace?
I c ould not wait so I contacted a HVAC contractor and he gave me the answer. "Thanks" anyway.
Posted on Jun 26, 2009
I have a Ruud Achiever 90 Plus Gas Furnace with Air Conditioner. I have a new Nest Thermostat. What is the correct wiring connections on the Furnace?
A Ruud Achiever gas furnace I believe came in a two stage model for heating. What this means is that you will have a high and a low setting. Your furnace should have two wires that control the heating cycle a W1 and W2. This should correspond with the terminals on the nest thermostat. You may run into issues if you do not have enough thermostat wires to control the furnace. If you are ever in the need for Ruud And Rheem Gas Furnaces we offer a great selection online. Shop Natural Gas Furnace. We also have a chat line which can provide technical support.
Dec 26, 2017 | Ruud Heating & Cooling
I need a Ruud 80 plus gas furnace manual
Request the manual directly from Ruud.
Mar 25, 2017 | Ruud Heating & Cooling
My Ruud furnace sometimes will blow up the exust vent when lighting
If the burners are inshot burners (look like little jets), Shut the furnace and gas off. Take a 5/16 nutdriver and remove the four screws that hold the gas manifold and the gas orifice's. This should pull back, and each of the inshot burners will also have the same size screws...one per burner. Remove each burner individually and look @ the front of the burners where the "wings" are. With a flat head screwdriver, slightly open the wings which act as flame runners. This will allow the gas to run across evenly so the flame will hit each burner and not build up gas and blow like you are experiencing. Reassemble and run test with gas & power on. Good luck
Jan 16, 2015 | Ruud Heating & Cooling
Is it ok to close vents in winter
Only a few...the furnace is rated @ a certain design static pressure, and when you close the vents...it could overheat the furnace, short cycling, etc.
Nov 24, 2013 | Ruud Rheem Weather King Furnace Fan...
Can I vent my ultra v tech 80 propane gas furnance with pvc so I can do away with chimney
Generally, the furnace must be at least 90+ efficiency to be able to use PVC pipe. In addition, high efficiency gas furnaces require a condensation pump, to pump excess moisture out of the furnace. If yours has always been venting up a vent pipe, then NO, you can't use PVC pipe.
Hope this helps you.
Mar 14, 2011 | Heating & Cooling
What is the efficiency rating on the Trane model BLU055E936B1 upflow furnace and what new furnaces are available to replace this old Trane furnace without having to change the venting system.
Chances are you need to replace both the condenser and furnace, then you you should get a varaible speed blower with the new furnace, get at least a 90% gas system with a 16 SEER condenser, save on energy cost as soon as it's installed. Go Get IT
Jan 28, 2010 | Ruud Central System Air Conditioner
Wher is the filter
filter should be beside or inside the furnace fan compartment....if you have an Electronic Air Cleaner (EAC) thyat's working . no other filter is required 29637bd.jpgd88e24f.jpg
Oct 31, 2009 | Ruud UBHC Air Conditioner
Ruud RKKA Series Split Unit
the pressure switch has to pull in for the gas valve to be powered so check switch and venting
Apr 02, 2008 | Ruud Handler Air Conditioner
Heating & Cooling Logo
63 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
