Question about Canon PIXMA iP8500 InkJet Photo Printer
Hello. My Canon ip8500 waste tank is full. How do I remove/ clean it? Many thanks for your help. George
  • theoldsailor Jun 25, 2009
    Many thanks for your attempt at a response.
    But please read my request again.
    I want to know how to remove/clean the waste tank; not the indicator.
    I know how to re set the indicator; that is in the manual. But it does not fix the cause, just the warning.
    So, here we go again: how do I remove and clean the waste tank. Starting with how to take the covers off.
    Thanks for your help.
    The Old Sailor
  • theoldsailor Jun 26, 2009
    Thanks again.
    We are getting closer, but . . .
    Both your responses were in the public domain and I have seen them before I wrote to you for specific iP8500 instructions.
    The ip8500 case is NOT like the s900, which I had before this.
    Would really appreciate it if you could find real ip8500 pictures or text for me.
    (The Maintenance Manual I saw has no instructions on how to remove the cover.)
    Thanks again,
    The Old Sailor
    President:
  • 1,197 Answers
U just need to reset the counter.....
First thing you need to do is print an EEPROM information page, step number 2 below.
Once you have an EEPROM print you can reset the waste ink counter, if needed, which is step number 4 below.
Service Mode: This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
With the printer powered off, hold down the resume button and press the power button.
While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button.
The indicator will blink in green and remain lit in green.
Select one of the following service mode functions by pressing the “RESUME Button” the specified number of times.
1 time = Service test print.
2 times = EEPROM information print.
3 times = EEPROM initialization
4 times = Waste ink counter resetting
5 times = Destination settings
6 times = Print head deep cleaning
Then press the “Power Button” one time to perform the function just selected.
if that doesn help..... get back to us.... we ll tell u what to do....
good luck
Posted on Jun 26, 2009
    Novelist:
  • 133 Answers
Dear Theoldsailor
Service Mode Operations:
Hope that helps. Please do not forget to rate the solution :)
Thanks and Regards,
Srinivas
Posted on Jun 25, 2009
  • Srinivas Dhulipala
    Srinivas Dhulipala Jun 25, 2009
    Although I don't have instructions for the exact model but here are the instructions for similar model.. hope these help :) ... follow these meanwhile I would try to get images if possible. Here are the instructions.
    1) Figure out how to open the printer by removing the side and inside top plastic panels. Just look at the thing, its all pressure clipped in place, no screws (at least on the S900 and similar models, probably still the same on this years models.) Look for slots and triangles on the 960.
    On the i960 you'll have to remove the power buttons assembly on the front- take out the two screws, unplug the internal white electro connector plug CAREFULLY, then you can undo the last clip that holds the top in place.
    2) No need to remove the ink cartridges in this process- so don't. The mechanism is held down in place in the case by two screws at the very bottom on the outside bottom of the metal chassis inside. Remove these screws then lift up the mechanism. It should lift out fairly easily, but remain attached by wires-- just place it on the top edge of the case.
    3) You'll see the blackened (from waste ink) felt pads on the bottom. WEAR GLOVES-- this is skin indelible ink, the only thing that will get it off your hands is CLOROX. Period. There are two skinny pads that sit on top of a larger pad. Note how they fit together.
    4) Lift the pads out and rinse out thorough in a sink until very little or no ink comes out. There's no need to use chemical or soap cleaners, just use plain water from the tap and the spray nozzle. Keep rinsing and squeezing the pads, but don't twist them like a towel, squeeze and fold in half however to really get the ink out.
    Lay flat in the sun for a few hours to dry. Use a hairdryer to get the last bit of moisture out then replace in the printer, and put everything back together.
    5) RESET the printer electronics, so you won't get the stupid "waste ink tank full" message any more. Do an online web search if this doesn't work for your model, although this works (or slight variations0 for many, including the 8200, the S800, and S900, and the i-series like the i869, i950, i960, etc.Two main buttons on the top of the printer- Power and the Resume:
    If you've reset the code first, then cleaned the pad, you're now ready to print again.
    If you've cleaned the pad first, go back and reset the printer, and then print away.
    Regards,
    Srinivas
    1) Figure out
    h
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
When I try to print on my Canon PIXMA ip8500 inkjet, I get a service error 5100. What does this mean?
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
for waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 19, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
Waste ink absorber almost full
Thanks for posting in FixYa.
It may be the problem arised due to installation.
You need to go for reinstall the printer.
Let me know if you need further assistance.
Have a Nice day. Dont forget to vote me.
Regards
Ellin
Sep 25, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Canon Multi pass F60 (waste tank near full)
Power off and on at button. If message continues it needs service.
Sep 19, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Canon S520 Won't Re-Set after installation of new Canon waste ink absorbers
plz check the website
http://www.fixyourownprinter.com/forums/inkjet/50418#1
Jun 30, 2008 | Canon S520 InkJet Photo Printer
My canon printer will not print - i get a waste ink reserve tank if full. where is the tank and what do i do to get my printer working again. thanks
Your waste tank is full. It is located at the bottom side of your unit. Actually, the tank is a flat sponge or foam like material about 1/4 inch thick. I have experience removing it and cleaning it by soaking it in water and soap, but I wouldn't suggest you do it cause it is hard to remove it and pretty messy to clean it. Take it to the service center.
May 18, 2008 | Canon Office Equipment & Supplies
Canon Pixma iP8500 Waste ink tank full.
Try searching this forum. The answer is usually here.
http://www.fixyourownprinter.com/forums/inkjet/15284#532
Cheers
Don't forget ' fixya' please!
Mar 30, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
PIXMA iP8500
Error 5100 on Canon Pixma iP8500. flashes orange 2 times. Sounds like the paper isn't being picked up. But I don't know how to fix it.
Jan 03, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Canon BJC 8500 WASTE INK FULL
How to Reset Waste Ink Protection Counter Canon Pixma IP8500 Printer
Instructions:
Resetting Waste Ink Counter Canon Pixma IP6000, Canon MP450, Canon Pixma IP8500
1. Turn off the printer.
2. Whilst pressing Resume button also press on POWER.
3. Then Press RESUME button and release POWER.
4. Then Press RESUME button again .
5. Then release all buttons.
6. Led Indicator should be green and stay green.
7. Click RESUME button 4 times if you wish to try again.
Then See Table Below:
Orange - Service test print ONCE - Orange - Service test print.
Green - EEPROM information TWICE - Green - EEPROM information print.
Orange - EEPROM initialization 3 TIMES - Orange - EEPROM initialization.
Green - Waste ink counter resetting 4 TIMES - Green - Waste ink counter resetting
Orange - Destination setting (Press Power then Press Resume 3x) 5 times - Orange - Destination setting (Press Power Press Resume 3x)
Green - Print head deep cleaning 6 TIMES - Green - Print head deep cleaning.
Orange - Green, Orange - Return to menu selection 11-13 TIMES - Orange, Green, Orange - Return to menu selection.
Green - Left margin correction 14 TIMES - Green - Left margin correction.
8. Turn off printer.
9. Restart Printer.
Good Luck!
Tinteiros - Magic Inkjet Flush (Ebay)
Nov 07, 2007 | Canon BJC 8500 InkJet Printer
Canon PIXMA iP8500 InkJet Photo Printer Logo
343 people viewed this question
old marine
old marine
