Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice maker not working
Hi I have a Kitchenaid side by side fridge modle..ksrs27cnwhoo.The ice maker is not working, I have checked the following solonide valve, filler tube, door switch and ice maker switch and they all checked out fine. For some reason its not getting the signald to open the solonide to let the water flow
Thanks
Shamza
  • 1 more comment
  • Dan B in TX May 26, 2008
    the ice maker cycles like it's trying to make ice there is a bit of ice in the filler tube
  • Anonymous May 28, 2008
  • Anonymous Jun 08, 2008
    ice maker not making ice. havn't tried anything yet
I have the same problem. All switches were good. No water going into the ice maker. I removed the ice maker from the freezer and removed the cover over the control module. I found that the control switch (white driven gear with copper on the back) broke. The control switch is plastic and it along with a plastic adapter broke. I hooked up the motor to 120V and it does turn so I think that replacing the control module is going to take care of my problems. I had the same symptoms a couple of years with no ice. The fridge was still under warranty though so I don't know what the service guy did to repair the problem. It sucks to have to repair this thing every coupld of years.
Posted on Jun 10, 2008
Wtf why aint this expensive **** working
Posted on Jun 01, 2008
    Problem Solver:
  • 19 Answers
Check to see if there is a bin switch one that checks for the amount of ice in the bin..replace or check that the nozzles arent blocked.
Posted on Nov 06, 2007
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Dec 31, 2013 | KitchenAid KSCS25FKSS Side by Side...
Frigidaire KSRA22 CNWHOO Side-by-Side refrigerator, Serial # SS1241434 I just changed the filter in my Frigidaire refrigerator. It had stopped making ice when the filter light came on. However, now...
Are you getting any water.
If you push the tab for water any you hear a buzzing or humming sound with no water then it could be you water pump which is located at the back of the fridge.
Just follow the water line and you will find it .
It's a small pump
May 26, 2017 | KitchenAid Superba Architect KSCS25INSS...
Our kitchenaid side by side refrigerator ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 06, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Have kitchen aide fridge ice maker stoped working, replaced ice maker still not working, red light blinks twice? Help
heatman101
hkhjkd
Jan 06, 2010 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Aug 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Mar 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
heatman101
ghdh
Jan 08, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid fridge (ksrw25crss02)icemaker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispencer.
hi kev215,
welcome to fixya.com.
Huuum at your service.
You said, the ice maker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispenser.
The first thing I would ask is when did you last change your water filter in the fridge?
Or if it's an older fridge with an inline filter behind the fridge!
check the shut off valve for the water line that leads to you ice maker. under the sink or in the basement or where ever the line comes from. I've seen where someone turned the valve a little clockwise unbeknown to the home owner and stopped or slowed the water flow.
The water line should be checked too, for any kinking that may be running behind the fridge or some unseen place!
How old is the fridge??
Let me know,
Thank you Huuum
Sep 23, 2008 | KitchenAid Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
238 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
