Question about Kenmore 76129 Air Conditioner
Kenmore air conditioner #25370156000 wont turn off
I cant turn this unit off. i have to unplug it. when i plug it back in, it is on again. i tried the timer mode... nope, keeps going?????
thanks, keith
  • 42 Answers
My educated guess is this would be a relay on the (or one of the) circuit boards. If you can access the internals parts try tapping on the boards which might allow the relay to release. A relay controls large amounts of current with small amounts of current (this means the controls can be small, working with small currents, also low voltages to control the relay on/off function.
Posted on Jun 05, 2010
Problem with ac window unit panel and remote will not work,pushed all bottons to work and just wont.Could it be the mother load panel?
Sounds like a control computer board problem. Some times unplugging and leaving it for about 30 seconds and plugging it back in can recover from the fault.
Jun 29, 2014 | Crosley CAE15ESR 15,000 BTU Window Air...
Getting an E1 error message..wont start
1. Unplug unit. 2. Hold down power button while plugging in unit. It will do a short self-test and then beep. leaving unit off. 3. Release power button and unplug. 4. Plug in again and turn on normally. This should last for about 720 hours, at which point the E1 error will come back and you need to follow the procedure again. (You might as well clean the air filter at this point just in case it really needed it...)
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 03, 2011 | Amana ACD106R Wall/Window Air Conditioner
Air conditioner was working great suddenly STOPPED working...cant turn it back on.
Hello
Is there a reset button located near the plug? If so reset it.
Check your circut breaker for the outlet its plugged into also.
If your using a remote to start this unit check that the battery is good in the remote,it may only work with a remote.
Jul 21, 2011 | Kenmore 76129 Air Conditioner
Hosed out ac to clean 8000 unit, put in window, reset plug, green light on plug is on, ac stayed on about 7 minutes and now will not come back on. I unplugged and reset but nothing...gen light is still on,...
With any luck, if you turn the unit OFF and unplug it for a day or so, it may dry out enough for the sensor that got soaked, when you hosed it out, will dry and the unit will work again. But, my instinct tells me, there's a very slim chance of that happening. As, it was probably still wet when you plugged it in and turned it ON.
Jul 21, 2011 | Kenmore Heating & Cooling
Air condition wont turn on
Do you have enough power to unit? Check plug for any loose wires on unit, with unit unplugged of course.
Jul 07, 2010 | Fedders A6Y18F7BCOM Air Conditioner
Kenmore AC Model 25370156000 keeps shutting off and on by itself
If you have just installed this unit in your window for the season, you may want to wait a day or so, for everything in the unit to settle, and try again. You make have shaken it up a bit too much. If not.....sounds to me like it is kicking out on high head pressure. This happens when refrigerant gets too low, or there is air in the refrigerant system. There is nothing you can do to solve this problem, except take it to a repair shop. If I am correct what happens is you turn the unit on, and the fan and compressor start simultaneously, then after a few seconds (maybe up to a minute) the compressor kicks off, and the air gets warm, then the compressor kicks on for a few seconds, and we repeat. This is actually a safety mechanism for the compressor motor so it does not run without refrigerant. (That would destroy the pump.)
Jun 04, 2009 | Kenmore 76129 Air Conditioner
Kenmore 110 ac model 25370156000
sounds like 1 of 2 problems. first, check the condensor coil for dust, dirt, lint on the inside of the unit. this is the coil thats on the back of the unit that is outside. it can be sprayed out with a garden hose. make sure the unit is unplugged and let it drain for a hour or so. if the coil is not dirty, then the unit has developed a freon leak and needs to be serviced.
Jun 03, 2009 | Kenmore 76129 Air Conditioner
Heater works after being off a while
If the unit is remote control try to unplug the supply of the unit(or off and on again circuit breaker) and operate the unit again. If it wont work then call a qualified technician to check the unit, maybe there is a problem with the unit control.
Dec 21, 2007 | Weather King 12AJA4801AH Air Conditioner
Sharp Air Conditioner
This is from Sharp's website...apparently an addendum to the instruction booklet. When you get E1:
Unplug. Press and keep pressing the On/Off button on the unit. Plug unit back in. Wait until unit beeps (about 5 seconds) then release On/Off button. Unplug unit. Plug unit back in.
You're good to go.
Sep 04, 2007 | Sharp AF-S120FX Air Conditioner
Haier wall-unit AC wont work
Try unplugging the machine, waiting a couple minutes, then holding down the power button as you plug it back in. Hopefully you will hear a "beep". Then unplug it again, wait a couple minutes, and plug it back in. This procedure works for clearing the "E1" code from some of the Sharp models, so maybe you will get lucky and the same manufacturer made the control board in your machine! Couldn't hurt to try it out. ;)
Jul 31, 2007 | Haier HWC08XC1 Wall/Window Air Conditioner
Kenmore 76129 Air Conditioner Logo
163 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
