Question about Acer Aspire One PC Notebook
Mic not working stilllll!
Even when i opened it up and unmuted it, opened up the control panel and went into it, nothing i do can make this thing work! help =(
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    have you tried another mic just to rule out the possibility that the current one i bad?
  • 484 Answers
I'm not certain about yours, but my Acer Aspire 5920 has an audio/volume turn button, just under the lip of the laptop, just to the right of center. Even if you un-mute it, if the volume is turned down all the way - the button revolves, so looking a the front, turning it counter-clockwise will turn the volume down to off, and you won't hear a thing, no matter how much you try to un-mute the thing.
So turn that rotating button to the right, to make it louder, after you have un-muted a control panel volume slider and moved it up, and that just might make it work for you.
Posted on Jun 26, 2009
I cannot unmute my microphone. I've looked in my control panel-sounds and everything is functional. When do a test message on Skype I hear nothing. Please help!
On your Skype menu go to "Tools" at the top of your menu.
Select "Options" and then select "Audio Settings".
There is a drop down menu for "Microphone".
Try selecting each option until you see the "Volume Bar" start indicating that your mic is working.
Jun 18, 2011 | Computers & Internet
The mic is on because I hear feedback, like a high pitched shrill when I turn the volume of the computer up... even when there's no music playing. How should I take care of this problem?
hi,
in the bottom right hand corner, there should be an icon that looks like a speaker. left click it and display the "mixer" style control panel. When opened there should be a series of faders (sliders) with titles either above or below each fader. Click on the box that says "mute". Your microphone should now be muted and the feedback problem cured. Don't forget to unmute the mic again if you use it.
Jan 16, 2011 | Toshiba Audio Players & Recorders
IM PLus # 3500 Series Mic works one day but not the next. Video is fine, but mic isn't. I've looked at all the settings but the mic doesn't pick up my voice.
Several possibilities:
1. You may have inadvertently muted your microphone.
2. You may have multiple devices identified as the microphone, so that might be causing a conflict.
Multiple ways these might be fixed:
1. If you have a media-controller keyboard, look for a mute / unmute button there to see if that helps.
2. Alternately, open the Control Panel and open up the Sounds category. Navigate to the Recording tab and ensure you have identified the proper device.
3. Ensure your volume control utility for Recording has not checked Mute on the microphone.
Guessing you are using Microsoft product. Open the Control Panel
Sep 01, 2009 | Logitech Quickcam IM 961361-0403 Webcam
Acer aspire 5735 mic problem
Go to control panel and sound devices and unmute the mic under record options. To avoid feed back use headphones or mute the mic in the play back option. Audacity is a good open source application to use to record on your PC.
Jul 25, 2009 | Acer Aspire 5735 Notebook
My laptop is not recognising my microphone. The mixer does not even have a ''mute/unmute'' option and the volume control my mic isnt even there. in my sound/audio devices, for voice recording the advanced...
make sure the mic jack is not in the speaker jack please try swap it. if it does not work, plug the mic and go to control panel select sound devices there u can set ur mic, if not reinstall ur sound driver, thanks, dont forget to vote me if it works
Jul 18, 2009 | Computers & Internet
Mic dont work
If you have one front panel and one back panel mic input port, Front panel is active by default on most systems. Try front first. if that is ok..or even if not, click on sound icon near clock (double click) select input/recording. unmute the mic or check it as input. thanks
Apr 03, 2009 | Acer (54.AA806.001) Sound Card
My microphone is muted how can i unmute it
Go to start then control panel you should see a tab called hardware and sound click on it and you should find your microphone there and you can unmute it from there. Hope this helps you
Jan 16, 2009 | Skype IM
Internal MIC not working
If you are using xp, try going to the control panel, sound and audio devices, click on audio tab.
to check the mic settings, click on the volume tab under the sound recording sections. Make sure that the mic is selected and the volume turned up. It may be working only to record, not to hearback without recording...so you may have to actually be recording or talking to someone to know if its workings.
To check the sound, check to see if your audio device is selected under "sound playback" section...and make sure that all channels are unmuted and turned up. you may also have to check the volume control on the laptop (actual buttons on the pc) if there are any, and make sure that the volume is up and unmuted there also.
Hope this helps.
Mar 30, 2008 | HP Compaq Presario V6000T Notebook
No Sound Coming out my Microphone
i know this might sound a little obvious and maybe irrelevant to the problem, but did you press the switch on the mic? it will turn the mic on and off. make sure sound and mic are unmuted in windows volume control. if both are these didnt solve the problem, test the mic on another computer. if the mic works, maybe its not the mic that has the problem. if the mic doesnt work, then your mic may be defective or damaged in some way or other.
Mar 28, 2008 | Philips PH62080 Uni-Directional Microphone...
Mic doesn work
same thing happened to me, it wouldn't even work when i went to control panel -> audio devices -> mic test   i think i'm just going to return it for a different model.
headphones worked well though
Sep 23, 2007 | Logitech Premium Headset
Acer Aspire One  PC Notebook Logo
152 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
