Question about Roper REX3614KW Electric Dryer
The belt broke drum won't turn - Roper REX3614KW Electric Dryer
  • 97 Answers
Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
Posted on Jun 25, 2009
Dryer heats but doesn't turn.
Most likely the belt broke on the drum. Less likely the motor died. When turn the dryer on do you hear the motor running? If so you probably broke the belt. You will have to unlock the top and pull the front off. The belt rides around the drum towards the back of the dryer.
Jul 21, 2015 | Dryers
Dryer turns on but drum won't turn
Remove the top to see if the belt is intact. If it is, you will need to replace the motor. Here is the motor to order.If the belt is broke, here is the belt to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 11, 2012 | Dryers
My dryer had a broken belt so I installed a new one. According to the directions I could find online, it said to install the belt with the smooth side against the drum. Now that the belt is installed the...
If you have the belt down in the groove on the tub it won't work. The belt slick side goes to the drum and goes back like this:
I recently worked on one of these and took photos of the repair:
http://appliancejunk.blogspot.com/2011/09/old-maytag-dryer-belt-replacement.html
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 04, 2011 | Maytag MDE308DAYW Electric Dryer
The drum on our Neptune Dryer has stopped turning. It still heats up, but the drum just won't turn.
If the heater and blower work then th eprblem is with the drum turning system
This includes the motor ( which we will presume works because the blower does),the belt (Item #25 in the Cylinder, heater and bulhead diagram) and a spring and idler pully (Items 20 and 21 in the Base, Motor, and blower diagram)
Most likely problem is the spring broke releasing tension that halds the belt to the motor pully and drum. Second most likely is the belt has stretched.
You need to open the unit to determine where the problem lies.
Here are diagrams and parts listing for that machine.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MCE8000AYQ/3048/0151200?searchedModel=MCE8000AY&blt=
May 24, 2011 | Maytag Neptune MCE8000AY Electric Dryer
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
Belt broke and drum will not turn
replace belt order belt using modle number,,,check tension pullys also for damage,,,,,,,,,www.myabcspace.com/washerwizzards
May 17, 2010 | Dryers
Dryer drum does not turn
Most likely the belt broke, replace the belt
Aug 14, 2009 | Dryers
Drum won't turn
it came off the tensioner or it is broke. pull the belt and see if it is not broke. if it is still loose around the drum, then it just came off the tensioner.
look at the manual on how to put back the belt with the tensioner.
tnx 4 using fixya,
drcool
Sep 16, 2008 | Whirlpool GGQ8831L Gas Dryer
Fixing a belt to a Zanussi Condenser Dryer
when you say "only one pulley...", are you counting the motor as one? there should also be a tensioner pulley...look for it somewhere near the motor.
Oct 31, 2007 | Amana ALW480DA Top Load Washer
Roper REX3614KW Electric Dryer Logo
211 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
