Question about Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190
Trane XE90 both ac unit and the furnace kick on at the same time
I have a XE90 trane, installed in 1995 and noticed this winter that the ac unit was kicking on everytime the furnace did. I unhooked the ac at the time and now need to hook this back up and want to verify the wiring schematics. This could have been happening all along and I never noticed. I hooked the ac back up the same way I thought that it was but now the furnace is kicking on with the ac and that did not happen last year. the product listed below is not the problem but I could not find my model number on the list
    President:
  • 1,723 Answers
How about the Heating/cooling thermostat. Sounds like you better check it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 26, 2009
My goodman GMVC95 furnace circuit board is flashing On 6 I replaced the flame sensor but it's still flashing. Does it have to be manually reset?
Alright, have you checked the low voltage fuse on the circuit board in the blower compartment? Make sure you check the roll out switches as well. If all of these issue appear to be fine then you may have a bad circuit board. There has been a bad batch of circuit boards going around many of the popular furnace brands this winter. Trane Gas Furnaces and Goodman Gas Furnaces have been effected. We sell both brands and have had to replace many circuit boards on new furnaces. Trane Gas Furnaces Installed Goodman Gas Furnace Installation Gaithersburg
Feb 03, 2018 | Goodman Heating & Cooling
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
New A/C Unit makes loud noise when it starts up
It shouldn't be too loud. You don't explain where the noise is coming from? The air handler/furnace or the outdoor unit.
Jun 13, 2013 | Heating & Cooling
How can I make the ac quieter inside the house?
If you have hard ducts, you can use some flex duct between the supply plenum and the hard ducts as a way to quiet the noise down.
May 10, 2017 | Goodman Heating & Cooling
Wiring diagram for trane g26f032sa furnace
Request the wiring diagram directly from Trane.
Nov 05, 2017 | Heating & Cooling
Trane XT300 thermostat reads HOLD-AC. Unit will
by simply turning power off to furnace or air handler may not work but there might be a reset button in the t-stat. remove the faceplate off of the t-stat it might be in their.
Aug 16, 2009 | Heating & Cooling
Loud AC unit outside trane high efficiency xb1000
The noise could be the fan trying to pull air through the condensor. Service cleaning should improve cooling and lower noise level.
May 21, 2009 | Heating & Cooling
Draft inducer blower going bad
I agree close enough. Only slightly slower. If it fits mechanically , useit.
Jan 17, 2009 | Omega Trane Furnace Draft Inducer Blower...
Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190 Logo
430 people viewed this question
Top Omega Tools & Hardware - Others Experts
yoopertech
Terry Hair
Are you an Omega Tool and Hardware - Other Expert? Answer questions, earn points and help others
