Question about Braun MPZ-22 Juicer
Screwdriver hi there i need fix my juicer but i not know what kind or where buy the screww driver that i need coz i never seen before a screw of that kind gretings
0 characters
1 Points
Dash juicer wont turn on
Just fixed this problem!
Take bottom off juicer. The 4th screw is an "odd" one...I drilled the center out and used a flat head.
When you look up inside the juicer, you will see a silver lever arm. It touches the arm lock mechanism (so the juicer will only run when the arm is engaged).
The lever arm should be behind the black lever arm part on the side. When I opened mine up, the silver level arm was on top of the black post thingy. I took a screwdriver and pushed it off the black post thingy, so it the very bottom of the silver lever is behind it. (I can no longer see the entire silver lever easily when it is in the correct position.)
Totally fixed it.
I think it bounced out of the correct spot when I juiced some hard veggies or when I moved it, it hit the counter pretty hard.
Anyway, good luck....I am not a mechanic so sorry if the language is non-technical.
Oct 05, 2012 | Juicers
Broken plastic screw from motor shaft
According to Jack Lallanes Support you need to buy a new motor! No replacement part for that specific part!
I have the same problem and also do not want to buy a new motor! Scam!
Nov 21, 2009 | Jack Lalanne Power Juicer 250 Watts
No crescent tool included with purchase to remove the blade
Make sure the Juicer is unpluged. What you need is the cresent tool or two metal objects to place in the two holes opposite each other and press down the metal objects in the holes while turning counter clockwise. It kind of acts like a lock and key system.
Jul 28, 2009 | Jack Lalanne Power Juicer 250 Watts
Breville JE95XL juicer
I used needle nose pliers, it took a bit of patience but I got the screws out. I think I might replace them with regular screws. My juicer does not run either. Let me know if you find the problem with yours.
Dec 26, 2008 | Breville JE95XL Juicer
Jack lalane juicer thread goes bad killing the juicer
DO NOT BUY THIS PRODUCT!!!! unless the plastic drive srew is replaced with a metal one.
Nov 24, 2008 | Jack Lalanne Power Juicer (Stainless...
Jack LaLanne Power Juicer
Hi smer67 - This is what it says on the official site about spare parts: See the back inside cover of the instruction manual for the spare parts order form or call: 1-973-287-5150
(MON-FRI 9AM to 7PM EST & SAT 9AM - 5PM EST). If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Aug 17, 2008 | Jack Lalanne Power Juicer (Stainless...
Buying a replacement part
Visit the Jack lalane Juicer website where replacements parts are sold.
Aug 04, 2008 | Jack Lalanne Power Juicer 250 Watts
Braun MPZ-22 Juicer Logo
Top Braun Juicers Experts
David Payne
David Payne
Jay Plesset
Are you a Braun Juicer Expert? Answer questions, earn points and help others
