Question about Apple iPhone 3G
I cannot get my emerson em227 bluetooth to connect with my iPhone. It pairs and the bluetooth blinks blue but it will not connect. I use the ''0000'' passcode and it says invalid passcode.
This happened to me with my iPhone. I called Emerson and they are aware of the problem. I sent the headset back and they are going to replace it with one that works with the iphone. Their number is 877-768-8483 in NY.
Posted on Jul 14, 2009
Bluetooth paired but not connected?
There are several kinds of Bluetooth Profiles. If you're only looking to send and receive phone phone calls, A Bluetooth headset only needs a Hands Free Profile or HFP.
The EM227 cannot be used as a stereo headset because a different Bluetooth Profile is required. If this is what you're intending to use it for, You may want to invest in Bluetooth enable Studio Headphones.
Try these steps to Troubleshoot the issue:
1. Make sure that your EM227 has been fully charged. the User Guide suggests that you charge the Headset for at least 5 hours before you use it for the 1st time.
2. Go to your device's Bluetooth Settings and scan for nearby devices.
3. Turn ON your EM227 Bluetooth Headset and place it in pairing mode. The Bluetooth indicator light will flash RED and BLUE.
Don't Forget to keep your Bluetooth Headset and your device within 3 feet of each other.
4. If your device asks for a Pass Code, try entering "0000" ( Four Zeroes)
Once you've paired the device, the LED indicator should now blink as a steady Blue light. Try making a test call.
Remember, The EM227 was only designed for Hands free calling ONLY.
Mar 15, 2013 | Emerson Radio Communications
EM227 to Iphone
You must put you headset in pairing mode, prior to trying to pair it with your phone. In order to do it, starting with it turned off, press and hold the power button for some 10 seconds, until the indicator light is alternately flashing in red and blue. It is in pairing mode now. Then, bring your phone close to it, and make its bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (blue light flashing every few seconds).
By the way, If its user guide happens to be missing, or, rather, you need further informations on how to pair it with your phone, feel free to download it from this location.
Regards,
Carlos
Jan 21, 2011 | Emerson EM227 Bluetooth Headset
Hi I have an emerson em227 bluetooth and haver lost the direction. I need the instruction to start the paring process
You must put you headset in pairing mode, prior to trying to pair it with your phone. In order to do it, starting with it turned off, press and hold the power button for some 10 seconds, until the indicator light is alternately flashing in red and blue. It is in pairing mode now. Then, bring your phone close to it, and make its bluetooth application search for new devices. After a little while, your headset should appear on your phone' screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (blue light flashing every few seconds).
Regards, Carlos
Jan 13, 2011 | Emerson EM227 Bluetooth Headset
Em227 bluetooth wont pair up with my new droid Samsung Mesmerise have had the em227 working on other phones but wont pair with the code 0000
The pairing code for this headset is indeed '0000' (four zeros).. You must put it in pairing mode, prior to trying to pair it with your phone. To do it, starting with it turned off, press and hold the power button for some 10 seconds, until the indicator light is alternately flashing in red and blue. It is in pairing mode now. Then, bring your phone close to it, and make its bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (blue light flashing every few seconds). By the way, If its user guide happens to be missing, or, rather, you need further informations on how to pair it with your phone, feel free to download it from this location.
Regards,
Carlos
Dec 16, 2010 | Southern Telecom Emerson Bluetooth Headset...
I need the passkey for my EM227
Try turning the headset off. Then hold the power button in until the blue led comes on and doesnt blink. Then try pairing using 0000.
Aug 21, 2010 | Emerson EM227 Bluetooth Headset
My iPhone recognizes my Emerson 227 bluetooth but pin numbers will not connect using recomended codes 0000-1111-1234-9999 are there any other salutions my iPhone is 3g
Put the headset into pairing mode. First turn it off. Turn it on and hold the powerbutton down until the bluelight is not blinking then pair using 0000 as the pin.
Forgot pin to emerson em227 bluetooth
I have lost the manual so i cant add my bluetooth to my phone with the pass key
Apr 13, 2010 | Southern Telecom Emerson Bluetooth Headset...
Emerson em227 wont pair
With your phone closed press and hold the center button on the bluetooth until it starts blinking blue and red the open your phone and go to blue tooth> ad new device> then it will go to pairing then auto pairing and that should do it
Jul 09, 2009 | Southern Telecom Emerson Bluetooth Headset...
Apple iPhone 3G Logo
1,208 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
