Question about Philips 42PF9630A 42 in. Plasma Television
I have a 42 in philips tv that wont turn on green light comes on
I have 42 in philips plasma model 42pf5320179 when i go to use the remote it wont turn on , i then flick the mains power switch a few times and it comes on ,,,, this has degenerated to the point that i now have to do this for over half an hour .and i dont know how many hundreds of flicks turning the mains power on and off. when i flick the mains on i hear two clicks and then a few seconds later another two softer clicks ,, i have come to realise that when the two softer clicks sound that it wont turn on , but if the tv makes the initial two clicks and then no others it comes to life within seconds its only about 18 mths old i dont get it i thought philips was a good barnd in plasmas.
    Scholar:
  • 44 Answers
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
  • rogerh80 Sep 04, 2011
    Hi, i sent off for a repair kit in which there were 4 bag transistors that bolt to the heat sink in the middle of the power board. After undoing a bolt the transistor wobbled so i looked on the other side and a 'dry joint' was visible at the base of the transistor - i re-soldered it and all is now wonderful. I think the heat sink structure is maybe too rigid for the amount of heat movement - hope this is helpful
There may be a simpler solution but that depends. i had the same tv except when i tried to turn it on i got 7 red light blinks and it wouldnt turn on. wouldnt hurt you to try this first. find the 2 10v capasitors next to each other on the power board bottom leftish. if they are both bulging or bloated solder on a pair of new ones. they are like a buck a piece so maybe you'll save some money. hope you spend $2 instead of $100 :)
Posted on Oct 23, 2009
    Scholar:
  • 34 Answers
This is a common problem on these plasma TV's. The problem resides in the high voltage boards known as the X and Y Sustain boards.. You can purchase them here for a very reasonable price:
http://www.discount-merchant.com/Y-SUSTAIN-FOR-42-PLASMA-TV-PN-6871QYH036A-p/sku9510.htm
The above link is to a Y-SUS board. The X-Sus board is often the 2nd cause of failure and can be found here:
http://www.discount-merchant.com/X-SUSTAIN-6871QZH041B-6870QZE017D-6871QZH052D-p/sku9509.htm
To test which board is failing, you need to check voltage input to the YSUS board first... Input should be 120V from Power supply, output should be above 250V.. Do this test with XSUS disconnected. IF 250+V exists, then XSUS is damaged. If not, then the YSUS is the faulty part.
Posted on Oct 16, 2009
42" plasma wont turn on
A green raster to Plasma Display can occur to so many reasons. Check this to know more about the faults to Philips Plasmas. I can't give these details to you by this site, as the format of pictures shown there do not supported by this window.
Dec 31, 2012 | Philips Televison & Video
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips 42PF9631D 42 in. Plasma Television TV wont turn on..I get the initial green power light, but it quickly goes to a flashing red light (flashes a series of 4 times). Philips tech support is a joke....
Philip have alot power problems with their tv.Check power board for puff up parts like Capacitors,or rust in cracks or soldering.Changes parts or the whole power board.
Jan 08, 2010 | Philips 42PF9631D 42 in. Plasma Television
Just bought a philips 42 inch ambilight plasma t.v,and didnt know the plastic screening round the out side is supposed to light up, how do i go about setting this up?
Bottom left button on your remote should turn the light on and off. if this doesn't work sort through the options on remote and select ambiant light functions
Mar 12, 2009 | Philips 42PF9630A 42 in. Plasma Television
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42" Plasma TV
no se como instalar la cam en miportatil
Apr 03, 2008 | Philips J44414
Philips 42PF9630A 42 in. Plasma Television Logo
584 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
