Question about Casio EXILIM ZOOM EX-Z600 Digital Camera
I have a casio EX-2110 and the screen will not come on. What can I do?
I have the Casio EX-2110 that my daughter gave me . I have put new batteries into it but it wont turn on. Can you help me? I do get it to make a pip sound when pressing the buttons.
SOURCE:
  • 374 Answers
SOURCE: system error when turn on my CASIO EXILIM EX-Z3
A system error is a major error that needs to be sent in. There is nothing that we can do at home to fix that one. Sorry.
Posted on Sep 12, 2008
SOURCE: casio ex-p600 won't turn on
aaa
Posted on Oct 11, 2008
  • 12 Answers
SOURCE: Casio Exilim EX-Z3 not working (accidentally dropped on carpet)
http://casiorepairs.com/
The guy did a good job on our EX-Z3
Posted on Dec 22, 2008
  • 10 Answers
SOURCE: casio exilim ex-z40 camera lens will not close and on/off button
Try blow compressed air around the lens, this might help if something stuck in the lens causing it not to retract. you can also try other suggestions from the link below. it's not for the same camera but it might help.
http://www.msbin.com/camera/canon-e18-error.php
Posted on Mar 23, 2009
  • 395 Answers
SOURCE: My Casio Exilim EX-Z80 wont turn on
The lens barrels are jamming someplace. wen the camera moves the lens out immediately pop out the battery so that it stays and then turn the zoom from the outer most barrel in the direction it comes out side. Do not force it too much. If that works fine other wise take it to the service center
Posted on May 01, 2010
My mom gave my daughter Casio ctk551 keyboard adapter has power and we've tried batteries keyboard will not come on noticed a little rust on back plate took off clean with dry cloth nothing any sugges
Rust is an indication that the unit has water or moisture damage. The keyboard should power up using batteries or the adapter. Is the adapter is one supplied by Casio? Perhaps the batteries were/are put in the unit in the wrong direction or polarity? Take the batteries out completely and then try the power adapter. If this fails, I suggest returning the Casio for a replacement.
Dec 27, 2014 | Casio Music
My Casio Exilim EX-S880 wont turn on. Battery is dead but the camera wont charge on the charger. The red charger light is flashing when then camera is placed on it. This red light used to stay on...
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Aug 05, 2009 | Casio Exilim EX-S880 Digital Camera
How do i remove the battery from my camera exilim ex-z80?
Go to page 12 of manual. you need to hold the stopper down to remove battery. Here is the manual I looked at.
http://support.casio.com/pdf/001/EXZ80_e_na.pdf
Good luck and please rate fixya for the free answer
Apr 08, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Nothing shows on viewing screen
I had something like this occur with a minot mini video camera only it locked up in the "On" setting, meaning I could see a display on the screen but could not turn it off. I suggest you look very closely for a reset hole at the bottom somewhere, a place where a safety pin or the straightened end of a paper clip could be inserted. If no Reset can be found, then try holding in the Power On/Off for as long as 90 seconds. This may clear the problem. I would also suspect no power due to low charge or no charge on the battery, battery installed incorrectly, or battery not charged up.
Dec 10, 2008 | Casio Exilim EX-S600 Digital Camera
Casio Exilim battery won't charge
Casio batteries have a issue and are very weak you should not let it get below 5% when it is this low the camera will come on say battery is low and turn off. if it remains this or lower the battery can go out the good thing is you can get them really cheap off ebay.
Dec 02, 2008 | Casio Exilim EX-S880 Digital Camera
Casio EX-Z18
I have read on Amazon (in a customer review) that there is a known fault with Casio batteries. If the battery is fully discharged (i.e. when new!!!) it won't charge. The reviewer said a free replacement could be obtained from Casio? Either that or buy a new battery - about £6 I believe.
Nov 04, 2008 | Cameras
Battery not charging
I gave my wife also one of the Casio Exilim cameras. She doesn't take a lot of pictures. But so far the battery has not failed us. There might be a chance that your battery has died on you. I suggest you go to Casio and ask them to test the battery. I'm guessing it is the battery that has conked out. If it isn't then you need to have Casio check on your camera.
Jul 06, 2008 | Casio Exilim EX-S500 Digital Camera
Casio exilim digital camera 7.2 mp
I bought a non functioning camera like mine on ebay and put the new screen in. Not a project for the faint hearted. Requires magnification, a really good jewelers phillips and some soldering skills. The most practical solution, for what it will cost to have it done, is get another camera, there are some pretty good deals on ebay on demos and used cameras.
Mar 08, 2008 | Casio Exilim EX-S600 Digital Camera
Casio camera LCD screen broken?
I have used LCD's for your Casio Z75 at a reasonable price. [email protected]. Thanks papasgirl
Feb 12, 2008 | Casio Exilim EX-S600 Digital Camera
EXILIM Card EX-S770
call Casio Customer Support. They should be able to assist you.
Dec 27, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Casio EXILIM ZOOM EX-Z600 Digital Camera Logo
22 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
