Turned it off the previouos evening and this
Turned it off the previous evening and this morning there was no power to the unit and it will not turn on by remote or manual means. I have checked the outlets to assure there is power. All other components work.
    Scholar:
  • 44 Answers
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
My fan wonT shut off
Good Morning Judy,
I understand that the fan will not shut off on your Frigidaire air conditioning and heat, air conditioner, model# LRA18HMT2, even when you have turned your appliance completely off. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit break, for 3-5 minutes. When power is restored, turn your air conditioner to any cycle and let it run for 5 minutes before turning it off. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire Heating & Cooling
Hp pavillion a850y
It is unlikely to be the switch itself. Check that the memory is seated correctly on the motherboard, as it won't boot without it. Otherwise it sounds like the motherboard itself is shot. Sorry for the
Mar 28, 2014 | HP Computers & Internet
Bose AW-1 won't turn on
You have made an attempt to power up using both forms of energy. Generally, the indication is an internal power failure on the circuit board itself. If when previously used, a power surge damaged the 1st stage section, a shot may occur and render the unit useless. The only way to know for certain is a bench testing of the unit in question.
Jan 01, 2014 | Computers & Internet
Unit will not turn on.
Is power reaching the unit? Is it reaching terminals on compressor? If so, and compressor is not running, check the start relay/capacitor.. That could be it.
Sep 17, 2017 | Friedrich QuietMaster SL28L30 Air...
I have a Maytage electric slide in range with a ceran top. Model number MES5770ACW. I was cooking dinner last night on my stove and the elements on top stopped working. They will not turn on at all even...
Either control board bad, or there is more then one circuit breaker controlling the power, check the breakers on both the inside and outside breaker box...Stranger things have happened..
Sep 10, 2017 | Maytag MES5770 Electric Kitchen Range
I replaced the battery to honeywell RTH230B. Heat won't turn on.
I followed a comment from a previous source and reversed the polarity of the batteries. I then flipped them back to the correct position and the flashing battery indicator went away and the thermostat functions correctly.
Feb 04, 2010 | Honeywell Programmable Thermostat Heater
37MF321D/37 TV turned off last night. This morn, won't turn on
Please read these replies to the same problem. A new power board costs around $284.00..
http://www.fixya.com/support/t465280-magnavox_37mf321d_37
Jan 01, 2010 | Philips Magnavox 42MF521D/37 Television
Monitor will not turn on.
You might look at this link:
http://www.fixya.com/support/t797776-viewsonic_vp930b_3
It might be that some caps need replacing.
Feb 27, 2009 | ViewSonic VX2235WM Monitor
Dvd recorder - dvd+rw disc loaded - now stuck on load
turned off the dvd recorder at power outlet. Left overnight. Turned on again in morning and pressed open/close and managed to get the dvd drawer to open. No further problems
Jun 01, 2008 | Pioneer Televison & Video
Panasonic Cinemavision 53" Projection 2002
TV's have a circuit in them that monitors the high-voltage and shuts the set down if it senses something amiss. On a projection type set, figure on just replacing the entire board that has the flyback transformer on it.
Dec 29, 2007 | Toshiba 32AF43 32" TV
Televison & Video Logo
157 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
