I get a message in device mgr. comm3 disabled.
I get a message in device mgr comm3 disabled. I am using Windows XP Home. On device mgr I get RIM composite device with yellow question mark. Blackberry Tech worked with me 3hrs and nothing worked. Is there a way to turn on comm 3. I tried all USB Ports on the computer. I am trying to hook a Blackberry Pearl I just bought. Thanks
  • 14 Answers
Comm ports are changed in the BIOS. You'll have to look at your screen and it will tell you which key to hit for setup before the Windows splash screen appears.
Posted on Jun 25, 2009
Boot MGR IS MISSING
What actual operating system do you have?
Windows XP does not use the Boot Manager as this was introduced with Windows Vista or Windows 7 and higher versions.
If you are missing the Boot Mgr for Windows Vista or 7, then you will need to do a Startup Repair which you can do using either a Recovery CD if you have one, or else using the Vista or 7 installation disc.
See the following links:
Windows 7 recovery options
Windows Vista startup repair
Jan 11, 2012 | Microsoft Windows XP Home Edition
No sound in windows xp
Go into the Control Panel and open the Sounds and Audio Devices applet. Make sure the box marked Mute is not checked. If it is, uncheck it and click OK.
If it's not checked, open the Device Manager and make sure there are no conflicts between any of your audio devices (speakers, headphones, etc.). If a device has a conflict you will see an exclamation point on a yellow triangle next to its name. If an audio device has a red X next to its name, that device has been disabled -- open its properties and re-enable it.
If you still don't have any sound, you may need to reinstall your audio drivers. Go to your PC manufacturer's web page and download the correct drivers for your machine.
Oct 27, 2010 | Microsoft Windows XP Home Edition
After upgrading from windows 2000 to windows xp it won't let me get on the internet. No network adapter is the err message. In Device Mang. it shows a yellow ?.
The yellow question mark shows a device that windows does not recognize what it is. You may need to install an upgraded driver for whatever you are using to access the internet and then recheck Device Manager. Good luck!
Mar 17, 2010 | HP Compaq d530c PC Desktop
Windows Home XP system shutsdown abruptly.. just before that there was a message " device lost" what is the reason for the it and how resolve the issue?
I would first try to boot into safe mode, by pressing the F8 key while booting. A menu will come up, select "safe mode" after booting into windows from the control panel use the device manager to see if there is an exclamation mark next to a device. If so you can temporarily "disable" this device then try booting normally into XP.
Feb 21, 2010 | Microsoft Windows XP Professional Edition...
NO SOUND DESPITE AUDIO DEVICE WORKING PROPERLY
click start
then control panel
they hardware
then device manager
if there is a yellow !mark next to sound then use the properties tab to reinstall the the driver
even if there is no yellow !mark follow the steps and update or re-install the driver
Hope this helps
Dec 21, 2009 | Toshiba Satellite M55-S329: M55-S329...
My internal camera has turned itself off and i tried pressing crtl+alt+t whilst computer started up to get into start up, but it just turned on as usual and didnt let me go to start up to turn it on
Please try to check on the device manager if your internal camera device is disabled there or probably the driver is corrupted.
Windows XP
- click start
- click run
- click devmgmt.msc
- on the pop-up window, under imaging device, try to check if you see a red x mark or a yellow question mark. If it's a red x mark that means it's disabled, to enable it just right click it and click on enable. If it's a yellow question mark, you need to reinstall the driver of your webcam.
Windows Vista
- click pearl button (start)
- click start search box (run)
- click devmgmt.msc
hope this helps
Sep 30, 2009 | ASUS Eee PC 900 Netbook
Running windows XP home edition get message USB
Try reinstalling the motherboard drivers, maybe something is wrong with the USB controller.
Jun 07, 2009 | Computers & Internet
No sound. yellow (!) by audio driver in device mgr. error 10
Go to your device manager (windows key+break, device manager is on the left) and under "Sound, video and game controllers" will be "Realtek High Definition Audio" which has the yellow exclamation mark. Right click it and select uninstall. Reboot, and Windows should detect new hardware. If Windows doesn't automatically install the proper driver, the latest one can be downloaded from Realtek at the following link:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false#1
Apr 15, 2009 | Microsoft Windows Vista Home Premium with...
No sound device
Click on Start, settings, control panel, system icon, hardware tab and then click device mgr.
Do you have any yellow marks next to any of the sound devices? If so, right click on it or them and choose uninstall and say OK.
Close all windows and restart your computer
On startup, windows should find your sound device and install drivers for it. Check sound when back in windows.
Hope this works. Post back
Sep 19, 2008 | Computers & Internet
ERROR: code 28 -- Windows XP & USB 2.0
I'm unable to connect my western digital hard drive to my Windows XP computer via the USB port. When I check the USB 2.0 Controller in the Device Manager, there is a yellow exclamation mark (!) next to it. When I check on the status of the USB 2.0 Controller, the following message appears:
The drivers for this device are not installed (code 28).
What do I do now?
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Computers & Internet Logo
37 people viewed this question
Alun Cox
David Payne
David Payne
