Question about Frigidaire Ovens
Door will not unlock - Frigidaire Ovens
  • 6,784 Answers
The door lock mech has failed. This failed door lock mechanism will need to be replaced asap.
Posted on Jun 25, 2009
Door lock is on but door is not shut, how do I get it unlocked so door can go shut
Unplug the oven for 5 minutes and see if the lock resets.
Nov 22, 2016 | Ovens
Cannot unlock oven door
  • Here it is!
    Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    Nov 10, 2011 | Maytag Ovens
    How do i unlock after self cleaning my kenmore elite electric slide in 30"
    Hello,Give it time for the oven to cool if it has just completed the clean cycle. The door is not to unlock if the oven is still too hot. If the oven is cool and the door will not unlock,program and start another clean cycle and after about two minutes press cancel/clear/stop and wait for another minutes to see if the door will unlock.If the door doesn't unlock i recommend calling a service technician to diagnose and repair your range.
    Thanks
    May 29, 2010 | Kenmore Ovens
    How to unlock the hinge on an Ariston Oven Door with door off
    To Unlock the hinge on an Ariston Oven Door
    Lay the oven door flat on the worktop with the inner door upwards and the locked hinge facing you.
    With a pair of pliers and a good grip on the hinge, force the locked hinge towards you (by pulling it open towards you) and keep it in position by flipping the U piece over.
    Fitting the Oven Door
    Fit the door to the oven with the metal receivers in the slots on the oven.
    Once the receivers are in the slot, fully open the door (in a downward position).
    Flip the U shaped pieces over to lock the hinges.
    May 17, 2010 | Ovens
    The lock will not release after cleaning
    This is GE's trouble shooting advise:
    Range - Oven Door Won't Unlock After Self Clean
    The Oven Door has been Locked Accidentally:
    • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
    • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
    • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
    • Note: Do not force the latch at anytime!
    Door Will Not Unlock After Cleaning:
    On models with mechanical latches:
    • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
    Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
    If the above suggestions do not work try the following to unlock your door:
    1. Disconnect power to range for 30 seconds.
    2. Reconnect power and see if door will unlatch.
    3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
    4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
    5. Wait approximately 30 minutes and try to unlock the door.
    6. If the door unlocks, the control has reset itself and there should not be any other problems.
    7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
    Note: Under no circumstances should you ever force the door or latch open.
    May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
    Oven door won't unlock
    kenmore selfcleaning oven door will not unlock code f9 appears in window
    Jan 03, 2010 | Ovens
    Whirlpool range self cleaning oven door won't unlock after the cleaning cycle was done. gets error code -f5-
    I took the back off the stove and manually moved the door locking mechanism to unlock the door. Then started a cleaning cycle untill the door locked. Cancled that cycle and the door unlocked just fine.
    Seems OK now.
    Oct 15, 2009 | Ovens
    We have an Amana self cleaning oven and can't unlock the door. What do we do to unlock it?
    Just wait for the oven to cool off. The unlock is automatic....the door will unlock eventually. It might take a long time.
    Aug 27, 2009 | Amana AOCS3040SS Electric Single Oven
    HOW TO UNLOCK THE OVEN DOOR FOR THE DIETRICH OVEN MODEL DOP440BE1
    In order to unlock the oven you need to perform the following:
    Thank you for contacting Fixya.com
    Aug 07, 2009 | De Dietrich Ovens
    Ovens Logo
    64 people viewed this question
    Top Frigidaire Ovens Experts
    Oloyede Monsuru
    ashburton
    Starnley Johnwells
    Starnley Johnwells
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
