Question about Bunn Commercial Dual Coffee Brewer & Hot Water Tap w/ 2 Satelites
Three times this month, we come into the office and there is water all over the place from the coffee maker. It was turned off. Help!
    President:
  • 1,618 Answers
It may have been turned off but was it unplugged?
If yes then the problem is the solenoid has a slow leak.
If no then the water level probe needs to be cleaned.
Posted on Jun 25, 2009
The descale light keeps blinking, what should I do?
The 'Descale' light that turns on indicates that it is time to de-scale the machine.
Scale - or mineral deposits- form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water.
You will need :
  • Keurig coffee maker
  • 48 oz. white distilled vinegar
  • Water
  • Large ceramic cup
  • Sink
Instructions :
  • 1 Unplug the coffee machine and remove the cup.
  • 2 Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
  • 3 Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
  • 4 Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
  • 5 Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
  • Good luck ;)
    Dec 14, 2011 | Keurig Elite B40 Coffee Maker
    My Mr Coffee ADX20 coffee maker does not boil the water through any more. I would assume the main heating unit is bad. How do I replace the main heating unit?
    You might have scale that formed on the heating element. This happens to all heating elements due to impurities in the water. I would try cleaning it a couple times to see if it helps first! Clean the mineral deposits from your coffeemaker every 80 brew cycles if you have soft water and every 40 cycles if yours is hard water. About once a month is good for a coffee maker. Pour four cups of undiluted white vinegar in the water reservoir. Place a paper filter into the removable filter basket, close the lid. Go through a brew cycle with decanter in place. Turn the coffeemaker OFF after THREE cups of vinegar have entered the decanter. Let set 30 minutes. Turn machine on and let rest of vinegard run through. Discard filter and vinegar solution, rinse. If this doesn't help the element is probably bad and from everything I have heard Mr. Coffee doesn't have't replacement parts for consumers. They only sell to "Authorized" repair shops. With that being said I have heard if you call the Service number 1-800-672-6833, and talk to an human operator, not the machine, they have sent out new units because of this problem. If that doesn't help Coffee makers are usually throw away items, I have recently purchased a pretty nice Mr. Coffee one from Costco for $30. Kohl's had one the looked a little different but all the same features for $55. So for like $30 you can get a new one, where if you could find an heating element it would be probably around $20. Just saying!
    Mar 10, 2011 | Mr. Coffee ADX23 / ADX20 Coffee Maker
    Coffee maker never makes proper size, almost always have to run it 2-3 times to get even a small mug. Intermittently shuts off completely, have to turn it on in back. (B70)
    Sorry to read about your issue.
    The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
    Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
    Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
    If you taste vinegar..use more clean water, until the taste is ok.
    I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
    Jan 02, 2011 | Keurig Platinum B70 Coffee Maker
    Need to take machine apart to clean. Coffee maker was kept in an office that was infested with critters. One crawled inside... I would hate to throw it out.
    Sorry to read about your problem, I hope this helps you out.
    not really easy to take apart... i would do the descale
    Dec 15, 2010 | Keurig Special Edition B60 Coffee Maker
    The coffemaker won't brew and showed a descale message. What does that mean?
    Scale---or mineral deposits---form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water
    1.Unplug the coffee machine and remove the cup.
    2.Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
    3.Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
    4.Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
    5.Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
    6.Unplug the machine and dump the water into the sink.
    7.Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue
    Dec 10, 2010 | Keurig B70 Coffee Maker
    Excessive water poured through shot
    its possible someone held the buttons down to long enabling program mode.
    Go to your local market and purchase a 3 ounce measuring glass. Place it where you place your coffee cup and hold down the small button, it should enable program mode. Stop it once it reaches 1 ounce or your desired amount.
    Do the same for the large.
    Sep 03, 2009 | Saeco Royal Professional Espresso Machine
    De-scaling
    Try doing descaling with a descaling product , like the ones below:
    Urnex Cleancaf Coffee Maker Espresso Machine ...
    $9.99 - DBROTH
    Miele Coffee Machine & Steam Oven Descaling ... $20.55 - Totalvac.com
    Apr 19, 2009 | Keurig B60 Coffee Maker
    GE 169164 Coffee Pot Not Brewing
    Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
    Jan 07, 2009 | GE 106591 Coffee Maker
    Incomplete brew
    Sometimes you have to do the decalcification two or three times. Then, monthly after that.
    Cuisinart Coffeemaker Decalcification Process
    Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
    -Tha Mp3 Doctor
    Jan 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
    Blinking light
    SCALE REMOVAL
    The scale contained in the water, over time, will
    cause plugging up of some elements in the appliance
    and will thereby compromise its correct functioning.
    The result will be that more time is
    required to make coffee. The formation of scale
    depends on the hardness of the water and on how
    much the coffee maker has been used. To achieve
    the best performance, descaling must be carried
    out every so often. The coffee maker has a built-in
    system that counts the number of cups of coffee
    that have been made. The ON DRIP pilot light will
    begin to blink when it is time to carry out descaling.
    To do so, proceed as follows:
    • remove the anti-chlorine filter (if present) and the
    permanent filter from the coffee maker (so as not
    to bathe them with vinegar)
    • Dissolve 2 dessert spoons (about 30 grams) of
    citric acid (available in pharmacies) in the
    water;
    • Place the container on the heating plate;
    • Press the DRIP/AUTO button twice, allow
    the equivalent of two cups to percolate and then
    turn off the appliance;
    • Allow the solution to sit for an hour;
    • Turn the appliance back on and allow the rest of
    the solution to percolate;
    • Rinse by allowing the coffee maker to operate
    with only water at least three times (1 full container
    each time).
    • Press the PROG and DRIP/AUTO buttons
    simultaneously to reset the counter to zero.
    IMPORTANT: if the machine is left unconnected to
    the electrical mains for over two months, before
    using it again it is necessary to carry out the
    process of scale removal as described in the preceding
    section.
    10
    Aug 27, 2007 | DeLonghi BAR 6
    Coffee Makers & Espresso Machines Logo
    52 people viewed this question
    Top Bunn Coffee Makers & Espresso Machines Experts
    gbob59
    evans_lloyd
    Level 1 Expert
    Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
