Question about NorStar M2616 PBX Phone
We are using ericsson BP250,i am in south india,i
I need a solution ,we are using ericsson BP250,i am in south india,i dont get incoming caller id for analog trunk but i get pri caller id in digital key phone ,how to geting a caller id both analog and pri lines,i need both analog and digital extensions
thanking you
prabahar.B
finecons pvt ltd
chennai
cnavarro
  • 2460 Answers
SOURCE: Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Carl
Posted on Jan 08, 2009
  • 4 Answers
SOURCE: How do you set up caller ID on a Norstar M7208
There are a few other things you need before it will just work on your phones. You need to get Caller-Id activated by your carrier on each of the 4 lines. You also need to make sure your system has a Trunk card capable of Caller-Id. The card in your systems should be labeled CID.
After this you still need to program the lines for Caller-Id in the configuration section of programming.
Posted on Jul 30, 2009
MNfisherman
  • 11896 Answers
SOURCE: Caller ID not working on my t7316 phone
You can copy and paste this link below to go to a site where you can download your entire manual:
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
Posted on Sep 16, 2009
consultel1
  • 860 Answers
SOURCE: Incoming calls sound only on reception desk.
Programming2.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Posted on Nov 02, 2009
Testimonial: "Great! Very specific and easy to follow instructions. Thanks for your fast response. RO"
  • 3 Answers
SOURCE: nortel norstar m7310 phone caller id problems
@relax536
to find out your phone's extension dial
Feature *0 Intercom
Posted on Mar 15, 2010
Incoming caller ID on a Option 11 Meridian - can you recieve the incoming caller ID?
I believe so. You will need to know the construction of the caller ID string sent by the telco through PRI and then the ICS needs to be programmed to display the portion(s) of the string desired by the customer.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Dec 19, 2012 | Nortel Meridian Option 11 PRI/T1, NTAK09...
I have a callpilot 100/150 we acquired an add-on
First thing, the Call Pilot is your voicemail, not your telephone system. Your telephone system is most likely a Norstar CICs unit.
If the lines(trunks) are analog, it is the local telco provider that is handing out your caller ID.
Outgoing caller ID is not one of the features of the system for analog circuits. If you were running a PRI or BRI, then the system can hand out the caller ID. I would ask your telco provider to check the outgoing caller ID once again.
Jun 10, 2009 | NorStar CallPilot 100
Block incoming,outgoing numbers
Don't you attracted by such beautiful painting? It's not only a beautiful painting, but also a cell phone blocker.
May 31, 2009 | Sony Ericsson Walkman® W880i Cellular...
Configuring caller IDfor India
Were those other instruments purchased in India? The problem is that the U.S .uses a different"signal" to send caller ID than India.
May 28, 2009 | Panasonic KX-TG9331T Cordless Phone
Caller id not working
US phones use Bellcore FSK caller id. India uses DTMF caller id. Buy a DTMF- FSK converter at a telecom shop.
Jan 05, 2008 | Motorola Mobility 5.8 GHz Digital Cordless...
CALLER ID ONLY SHOWS "INCOMING CALL"
I was using this site while trouble shooting this in the US...
If the customer has DSL with filters in the same system go back to the NID and Isolate the DSL,
test the caller id and call waiting caller id. If this works you have Data Bleed coming from the DSL.
Make sure there are not two sets of filters on the line. Tjis customer had a filter with the DSL modem.
Doing this we just fixed an on going problem for a field tech who was the second callout on a customer issue.
Oct 27, 2007 | Uniden Cordless Phone
No caller ID information for GE Caller ID phone ( Model # 29385GE1)
I must have gotten your unit. Mine did work ONCE after it had been installed for about a week. But it never worked again and we pitched it. Buy something else.
Oct 21, 2007 | GE 29385GE1 Corded Phone
Avaya 5610 double display on incoming caller ID
Did you get this fixed. I would double check the firmware files of the phone. And maybe reset it.
Oct 10, 2007 | Avaya 5610 IP Phone
CALLER ID NOT WORKING
not only Panasonic, most other brand phones imported from other countries wont work in in India ( caller ID). Panasonic phones of Panasonic India, will work.I think panasonic has to explain this. if there are networks which does not support this equipment, atleast they should mention this is their booklets, to avoid users roam around telecom offices. To my understanding, all the land phones of BSNL through out India are caller ID enabled by default and is free!.
Aug 19, 2007 | Panasonic KX-TG2632W Phone
Lands Phones Logo
133 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
