Question about Ozaki DT-500 3-Piece Speaker System w/Subwoofer&Wired Remote (Silver) Computer Speakers
I have plugged in my speakers at right place but no sound is coming out of it. I also have a sound card of realtek nothing is helping. Please provide some solution.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Check your device manager and see if the sound drivers are installed.
    Scholar:
  • 136 Answers
Try changing the setting from the "Realtek HD Audio Manager" Select the correct input jack, double click it then "Which Device did you Plugin " window will pop up select the appropriate option and shall work. If this Does not work disconnect the speakers from the system, remove the sound drivers & reinstall it again, connect the speaker. This shall work now
Posted on Jun 25, 2009
  • Prashant Shinde
    Prashant Shinde Jun 25, 2009
    You can find realtek HD audio manager here :
    goto Start->Control Panel->Realtek HD Audio Manager
I have lost the disc for the speakers after getting computer back after formatting the speakers wont work
Posted on Aug 19, 2009
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
Jul 18, 2011 | Logitech X-530 Computer Speakers
My computer has no sound coming from cpu.
is the speaker power on? is the speaker cable plugged in the right place?
Jun 12, 2011 | Computers & Internet
Hi, In My Computer the Speakers are attached and they are Plugged in the right place But am not able to get the Sound out of them. I even have downloaded Winamp then also it is not Coming. Please...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 11, 2011 | Computers & Internet
Hi My speakers are acting up. Sometimes sound comes out sometimes it doesnt. Sometimes only sound comes out of the sub but theres no sound coming from the speakers. So i hear only bass. When i try...
if you are having problems with your sound
also
hope this helps
Apr 03, 2011 | Altec Lansing MX5021 Computer Speakers
My speakers won't make a sound.
Process of elimination... check your cable hookup first. then control panel and check sound, right click on properties tab and do a diagnostic.
Jun 02, 2010 | Creative Labs Inspire T3000 Computer...
Bx1121 no sound coming from speakers. hooked up and light is own
If the light comes on , this just means its getting power , make sure it is plugged in correctly to PC , also pluged correctly in right place's , also make sure your sound card has latest drivers.
Thanks
Dec 27, 2009 | Audio Players & Recorders
Sound coming from built in speakers instead of head phones
the socket that you are using, I assume headphone socket, has a "switch" inside that cuts off the speakers when you insert the plug. Perhaps this is broken/bent or shorted out.
May 03, 2009 | Acer Aspire One Netbook 8.9" Notebook
Sound Problem
check the conection again make sure the plug are in the right place white/white,yellow/yellow,red/red the problem is that the audio plug is not in the right place
Nov 27, 2007 | Nintendo Wii Console
Speaker installation
first see to that audio driver is installed in ur computer or not if not put motherboard cd, right click on my computer go to hardwre right click on sound manager with yello question mark and give update driver
Nov 13, 2007 | Audio Players & Recorders
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
1,039 people viewed this question
Top Ozaki Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Ozaki Audio Player and Recorder Expert? Answer questions, earn points and help others
