Question about Samsung PCN5425R 54" Rear Projection Television
My tv comes in like a 3-d movie. there is a "slope" in the red colors on the to left and bottom right of the tv. It sounds (from what I have read) lke the convergence board is bad. Anyone have any suggestions?
    Champion:
  • 205 Answers
Either the board or the magnets have come off the yoke of the tube.
Posted on Jun 28, 2009
MY onn dvd player is showing black and white
Check your warranty. Call for support.
*** The following is for information only.***
* If your player and TV set was working prior to this then it's probably playing a black and white movie or the TV color setting is off and needs to be reset.
* For TV go to menu, Picture, Color set up. (Best to restore to factory settings as a starting point.)
* For DVD try a known "color' movie (at least something later than 1965) if it plays in color then the older disk is B&W.
* If someone pulled out the cable (Yellow, Red, and White) this is the Video (Yellow) and Audio Left-White, Audio Right-Red.
* Check this cord for damage and reconnect into corisponding color coded jacks. Note; this cord will not affect the "color of the set other than not show up at all - Blank screen if wrong plug inserted.
* Call TV support line (or DVD support) for advice.
Aloha, ukeboy57
Jul 19, 2018 | Televison & Video
Dvd movies won't play in color, are my connections wrong?
in most cases its the tv not the player make sure the tv is set to nstc not pal
Dec 28, 2010 | Samsung HT-X50 System
Red color does not align
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Televison & Video
I'm trying to connect my dvd player to an AWA 47'' LCD tv but it doesnt have any sound although I can see the movie. I have a thick white lead coming from the rear of the dvd player but can't find where to...
On the back of your TV, you should have jacks with colors RED, YELLOW & WHITE. Yellow is Video IN. The other two are Left & Right audio IN. Usually they wire up color to color.
Jan 30, 2010 | Televison & Video
I have a dimmer switch where there is two balck wires and one red wire needing to go into it. I have out the red wire onto a screw on the bottom right side of the switch, a black onto a screw on the top...
It sounds like you have a 3-way dimmer for a single pole application. On the dimmer there should be two screws that are the same color and one screw that is a different color. This dimmer is designed to go on the power end of the 3-way so your power in (two black wires) should go on the one screw that is the different color. The red wire should go on one of the two similar colored screws. If you are already set up this way, change the red wire to the other screw that is currently not being used. The way a 3-way switch works is that the different colored screw (usually black) touches one of the similar colored screws (usually gold) in the down position, and the other similar colored screw in the up position.
Oct 17, 2009 | Lutron Almond 600w 120v 3-way Skylark...
Philips 23PF9966/37 color problem!
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Jun 15, 2009 | Philips 26PF9966 26 in. LCD Television
Hook up portable dvd to tv
Connect the phone jack sized end of the wire to the portable DVD player and then connect the 3 RCA's to your tv in the color coded spots. Yellow for Video, Red and White for Sound.
Dec 18, 2008 | Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready...
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Error with red color
i've never had to fix this problem before, but give this a try, it might work. remove the front bottom panel of the tv, their should be 2 to 4 screws then the panel should come off. it might need a little prying & sometimes they use velcro to hold it in place along with the screws. now remove the small plastic or wodden panel, another 2 to 4 screws. now in the upper right side you will find the screen/focus block ( 6 controls). i think the top 3 are screen & the bottom 3 are focus. you will need to adjust the screen control., use a flashlight to read it. now the center is the green tube, i do not remember if the red is to the right of left. the screen control is like the master brightness, which sould help with the low sensor output. if you turn up the red too high you will get small red lines on dark picture/or in a dark room. good luck.
Dec 27, 2006 | Sony KP61XBR200 TV
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
169 people viewed this question
Jerry Greenberg
Jerry Greenberg
