Question about Earthquake Sound PH-D2 Car Audio Amplifier
Orion 2100 hcca
I have a old school orion hcca .when i was playing it it would cut down like it was loosing power . well i found out that it was an the power caps we breaking down which normally happenes with a older amp like that .well with my smart thinking an not paying attention i went an put the amp on its side an was trying to see if something was getting abnormally warm or something totally forgetting about not being able to play those amps except for when its mounted or ready for mounting an i blew some resistors ......i think its for protection an i dont know the color bands on the resistors .....does anyone have a good pics of that board ???????
  • Derenzy Mar 30, 2008
    I have the orion 2100hcca competion amp,when bridge on 4 memphis 15s, two of the memphis is dual voice coil the other two is not. The amp dies down when the bass hits then picks back up. I have a 2 fared cap. I wonder if it is big enough
That AMP is a power pig you need some yellow caps and an MBR 70
Posted on Jan 10, 2009
  • splkgb Jan 10, 2009
    For pics of the board go to ampguts they are the best pics i could find
Orion hcca-25001 amp blue and yellow light stays on and still plays
i have a hcca25001 amp need to know if the blue light and the yellow light suposed to stay on when amp on
Jul 04, 2012 | Orion HCCA-25001 - Mono Amplifier
My orion hcca d2400 is shutting off and on at times when vol is loud why??
this may be called clipping.......not enough power to the amp, too small of a power wire, or the speakers may be too small
Apr 24, 2010 | Orion HCCA-D2400 Car Audio Amplifier
I need to know the wiring of the orion 2100 hcca amp?
well power to 12 volt power terminal, negative to negative, and rcas to input side of rca terminals... then go to www.the12volt.com and to the subwoofer wiring option to figure out if you can wire your subs to a 1 ohm load and how to do it... then go from there...
Nov 30, 2009 | Car Audio & Video
I have a d5000 amp and its wired up to a 15.2 hcca orion sub when i turn it up high volume,it cuts out anyone know why
make sure you have the frequency cuts right. if ur giving the sub anything lower then 30hz (assuming ur using 15's) the amp will cut out to protect the woofers from overload
Nov 18, 2009 | Orion HCCA-D5000 Car Audio Amplifier
My Orion d-5000 amp which is wired to an Orion hcca 12.2 sub cuts out at high volumes , it's wired with 0 guage wires
Your speaker is a dual 2ohm sub. If you have both voice coils wired Parallel that will drop the ohm load to 1, which the amp can not handle. You need to wire the voice coils in series. Treat each voice coil as a speaker.
Jun 30, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250 digital reference
if its hot its drawing to much current sound as if you have something improperly hooked up..if i could see your wiring i could help u out better steve
Feb 27, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250
i can make this relatively simple.
2 stages:
Stage (1) wiring the Sub inside the box;
Unscrew the SUB from the Box, (& undo the wires)
Connect both +Positive terminals on the SUB to the +Positive terminal on the inside of your BOX.
Connect both -Negative terminals on the SUB to the -Negative terminal on the inside of your Box,
Then screw the SUB back into the Box.
u Have just wired yr sub in parallel. any Amplifier will see it as 1woofer with 1OHMs resistance.
Stage (2) bridging your amp
(please check Amplifier instructions on which terminals to use)
generally you use "LEFT -Negative" and
"Right +Positive"
and connect to the corresponding terminals on the Sub Box.
Hope that helps someone.
Feb 25, 2009 | Orion HCCA-D5000 Car Audio Amplifier
China made against u.s. made orion products
of course they're horrible. The products China have come out with in the past and the present are always lower quality than American made goods.
Orion 2100 hcca
I have a few photos of the 2100hcca. Where are the burned resistors on the board?
Nov 05, 2007 | Orion 2500D Car Audio Amplifier
Earthquake Sound PH-D2 Car Audio Amplifier Logo
502 people viewed this question
Top Earthquake Sound Car Audio & Video Experts
hoyzee1
Tom Chichester
Are you an Earthquake Sound Car Audio and Video Expert? Answer questions, earn points and help others
