Question about IBM 4232 Matrix Printer
Error code 076 printer board failure see users guide
    Scholar:
  • 111 Answers
Bad logic bd. It needs to be replaced or fixed
Please contact me back i have some in stock or i can repair the one that you have at about half the price.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Posted on Jul 10, 2009
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Model 4225 shows error code only
'Ink System Failure,' or a '0x...' - HP Customer Support
support.hp.com/us-en/document/c03081973
Example: "Laserjet P1102w driver" or "HP Pavilion 17-f002na will not turn on" ... For example, 'Error 0xc18a0001' or 'B8000094' might display on the printer ... The error code or message is not 'Problem with Printhead,' 'Printer Failure,' or 'Ink ...
[PDF]hp officejet 4200 series all-in-one user guide
www.hp.com/ctg/Manual/c00095626.pdf
Hewlett?Packarduse the attached handset (hp officejet 4250 series only) . . . . . . . . . . . .50 answer incoming calls ..... Help button that appears on some error messages and in the. Troubleshooting .... a call waiting (handset model only). 9. Photo Fit to Page: ...
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
Dec 18, 2015 | HP Office Equipment & Supplies
Error code 6500
*Error Code - [6500]
*Conditions - The PCI bus error is detected by the ASIC.
*Solution (Replacement of listed parts, which are likely to be faulty) - Logic board ***'y
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much can user do instead of replacing the malfunctioning hardware. 6500 is generally logic board error code. If the printer is under warranty, you better ask for replacement.
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much a user can do except replacing the malfunctioning hardware.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 05, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
My canon mp830 printer is saying error 6500 and i cannot get it to do anything, i have un plugged and re plugged and nothing. what does this error code mean?
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much can user do instead of replacing the malfunctioning hardware. 6500 is generally logic board error code. If the printer is under warranty, you can ask for replacement
Abhilash
$7 is the charge for the service provided.
Oct 01, 2010 | Canon MP830 All-In-One Printer
Kenmore elite he3 dryer says PF
The PF and E2 (F02) error codes are related. The PF indicates that the dryer is experiencing a power failure. The F-02 error code indicates a Keypad/User Interface failure. The error codes for this dryer are shown in the third image below.
You could have a loose wire harness connection between the machine control board and the user interface control board that could cause there error messages and symptoms. The first image below shows how to access these components. I recommend that you unplug the dryer and then access these components. Check the wire harness connections on between the user interface control board and the machine control board. If the connections are okay then you will likely need to replace the user interface control board to correct this problem. The part number for the user interface control board is 8564396. You can order this part from the Sears PartsDirect website. It costs just over $100.
Sep 20, 2010 | Kenmore Dryers
Error 6500
The service error 6500 refers to "other hardware error”. This error results from printer hardware failure & nothing much can user do instead of replacing the malfuctioning hardware.
Mar 01, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Service 900 error message
900 Error Code service check
1 Printer POR
Turn the printer off and on several times. If Error Code 900 continues
to display, go to step 2.
2 System board
Make sure the system board is properly seated in connector J7 on
the interconnect board.
Turn the machine off and on several times, waiting a few minutes
between power on and power off.
If Error Code 900 continues to display, go to step 3.
3 Factory defaults
Restore factory defaults. See “Restore EP Factory Defaults” on
page 3-18. This resets the non-critical areas of the user NVRAM. If
Error Code 900 continues to display, go to step 4.
4 Sub error codes
With Error Code 900 displayed, press Select and Return. Record the
complete list of Sub Error Codes on the display. Check the “Base
printer sub error codes” on page 2-6. If none of the Sub Error
Codes are listed, then call your next level of support.
From page 2-41 of IBM's service Guide
Feb 15, 2010 | IBM Infoprint 1352 Laser Printer
I'm getting the error message Unable to print. check user guide on my brother mfc 210C all in one printer. I don't have my user guide. Please help. Tiare'
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 -defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 17, 2009 | Brother MFC 210C All-In-One InkJet Printer
Error Code FE6
It could be that the printer simply needs to be unplugged and powered off for 10-15 seconds then rebooted. If that error comes back then its quite possible the print board is bad.
FE6 PRINTER BOARD FAILURE
SEE USER'S GUIDE
Sep 24, 2008 | IBM 4232 Matrix Printer
IBM 4232 Matrix Printer Logo
196 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
