Question about Brookstone 538744 Remote Control
Cannot find manual. need to program menu - Brookstone 538744 Remote Control
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The user manual for a Brookstone 538744 is available here. It is in pdf form and would need Adobe Acrobat Reader to view the file.
Good luck and thank you for using FixYa.
Posted on Jun 25, 2009
  • Louie  Role
    Louie Role Jun 25, 2009
    For some reason, the initially posted link does not work. Apologies for any inconvenience. Pls click here instead. Download File " supersized-manual.zip "
  • 403 Answers
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OIHere you go. This will work with most all universal remote controls. If you don't have the code do the following:
Note:
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Posted on Sep 25, 2009
How do I program a Legrand 04761 timer?
Generally, the instructions are shown below: you will have to fiddle around to tweak the instructions since this model Legrand is discontinued, and replaced with the 412641
There are 4 programming buttons located on face of timer: menu, on, +, -
Press menu, use +- to scroll down to GCFEIL, Press on, select language
Press menu, use +- to scroll down to set, press on, set current time and date using same basic commands.
Press menu, use +- to scroll down to program, press on, select new, press on, select day-days of operation for program 1, select individual, set On and OFF times for program 1, save
Press menu, use +- to scroll to function, select auto to run programs.
http://waterheatertimer.org/pdf/legrand-412641-D22-manual.pdf
http://waterheatertimer.org/Din-rail-timers-and-manuals.html
Gene
Water Heater Timers Save Money
Mar 02, 2015 | Legrand Hardware & Accessories
How do I get into the programming menu?
Press the PROGRAM button in the row of buttons just above the number pad. If you need a manual, you may download a copy here. You'll probably also want a manual for whatever main unit your phone is connected to, since much of the programming is actually done on that.
Sep 27, 2012 | Lands Phones
HOW DO I REPROGRAM SHARP AQUOS TV
Clearly with the owner manual if needed but most programming for the consumer is done by with the remote hitting the menu button and looking for what you want---channels? look for antenna/cable in setup part of menu and select which you have---locate Auto program and engage and set searches for all available channels based on what is hooked up to it for signal.
If you need a owner manual GOOGLE works best with the model number of the set and "manual" or similar words.
Apr 02, 2012 | Sharp Televison & Video
MANUAL FOR AKAI TV
Done with a remote by using "menu" button first and then in setup selecting auto-program to program all available channnels.
There should be also there in that menu a way to add or delete single channels.
Mar 21, 2012 | Televison & Video
I can not change the menu keys to print out what I want them to read. I do not sell some items now and need to change hem
If you have raised keys on your keyboard, then you change the department programming, so go to the department programming section of the manual and edit the department name and department price (if you use fixed prices). If you have a flat keyboard with a paper sheet under it, you will have PLUs on the keyboard, so you need to use the PLU name and price programming section.If you have lost your manual, most can be found at C-tech:http://the-checkout-tech.com/
Dec 11, 2011 | Computers & Internet
I need a user manual .Can't find in Yahoo.com .Not
The Phoenix User Manual is available in electronic format from either of the two locations below:
• When Phoenix is not running from your Start Menu > Programs > PhoenixRC > User Manual folder
• From within Phoenix by clicking the Help > User Manual item on the Main Menu Bar
There are also many small green "?" help buttons on the top-right of the program menus. Clicking these will take you to the User Manual at the correct section for help on this item.
Jun 17, 2011 | Phoenix R/C Pro Flight Simulator V2.5 for...
Need to know how to use product
An Online manual in PDF (Portable Document Format) was installed along with your software. If you already have Adobe Acrobat Reader 3.0 or higher on your computer, your manual is ready to read and print immediately after you install the program:
1. Click Start
2. Select Programs (or All Programs)
3. Select the name of the program you just installed (you may have to Select Cosmi, then Select the program name)
4. From your program's sub-menu, you should see Manual or PDF Manual.
Apr 13, 2010 | Cosmi ROM07544 Perfect Photo Paint Studio
Need the manual for Mitsubishi CS13TX1... small counter-top model, perhaps 12-15 years old. Mitsubishi seems to have forgotten they ever made anything before huge screens, home theater, digital, etc., and...
use the menu button on the tv and look for the auto program mode. you will probably have to navigate the menu with the channel and or volume buttons.
Sep 13, 2009 | Mitsubishi Televison & Video
I need to Progam a Samsung Smooth cell phone.
To Program any Samsung Verizon Phone:
+Go to Menu > Settings (may be listed as settings & tools depending on software version)
+Press the * Key (to the left of zero / 0)
+Enter the Service Programming Code (a.k.a. SPC, MSL, SEC) This code is usually 000000 for most Verizon phones, but if it was purchased prepaid you may have to get it from Verizon. Try 000000 first though.
+Go to Network Settings
You will now be in the programming menu. Enter the information as it pertains to the field indicated.
+When you have entered all of the programming information, press END.
The device will now reset and save the programming information.
Jul 25, 2009 | Cell Phones
Brookstone 538744 Remote Control Logo
792 people viewed this question
Top Brookstone Televison & Video Experts
Tom Chichester
Mister Danger
Are you a Brookstone Televison and Video Expert? Answer questions, earn points and help others
