Question about HP Laserjet Cp2025n Printer
Ghosting when using HP CP2025N
Hi
We have a new CP 2025 N that is ghosting. I'm printing on 90gsm laser paper suitable for marketing collaterals. ghosting mostly around logo and colour graphics. many thanks for any help. Nikki
  • HP Expert
  • 398 Answers
Bad drum unit poor fusing or paper type try to print paper type cardstock as type, this increases fuser temp and slows printer for better quality.
-Carl, please let me know if this helps.
Posted on Jun 25, 2009
Hp 7000 won't print A3 paper size
mau nanya gan,printer ane hp k7000 gak mau print a3 tlng beri info gan ?
Feb 24, 2012 | HP Officejet 7000 Wide Format Printer...
What's your problem?HP Color Laserjet Cp2025n Printer -
hi my hp 2025 laser printer is reading low memory error.....
the printer is printing simple text .....but full colour graphics ...am getting memory error.....how can you help.......
Feb 17, 2012 | HP Laserjet Cp2025n Printer
HP colour laser jet CP2025. Prints colour on test sheet but not from pc. It was printing colour until wireless was installed - is there a connection?
Your driver is not sending color data. Either your driver is set to print in geayscale, or you are printing through a monochrome driver to the IP address of the CP 2025
Jun 30, 2011 | HP Laserjet Cp2025n Printer
Clening/mismatch printing for hp clj cp-2025 printer
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Jun 14, 2011 | HP Laserjet Cp2025n Printer
I have recently bought HP 2025dn, Magenta cartridge is not aligned. I am printing on 90gsm normal paper... help!!
If you are referring to a CPR (color plane registration) problem, where the magenta color plane is not aligned with the other color planes, you might first try forcing a color calibration. This can be done through the control panel menus by selecting System Setup-
Sep 21, 2010 | HP Laserjet Cp2025n Printer
Problem in hp cp 2025 color laser printer that printer is giving error message "used black cartridge is in use error
This error typically indicates that the cartridge was moved (e.g. previously installed) from another printer to your printer. The error should not affect your ability to print. If you want to clear the error, replace the affected cartridge with a genuine HP replacement.
Aug 10, 2010 | HP laserjet Cp2025dn color Card Printer
Hp printer cp 2025 erorr code 58.04
This error code indicates "Low voltage power supply error"
Jul 18, 2010 | HP Laserjet Cp2025n Printer
HP Color LAserjet CP 2025 printer fails to print. All necessary equipment has been secured. On startup the display screen does not show and never shows up, the rolls make the normal start up sounds but The...
Make sure the printer is connected directly to the outlet. If there is no display there is no use trying anything else as this is a formatter failure and the printer requires service.
Try a nvram:
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
If there is a display,
print out a configuration report
check network settings ipv4addr, check port under driver properties. and make sure the same ip address is selected.
if using usb download a universal print driver and try installing the driver and selecting the usb virtual port
Al
Eliteprintersolutions@gmail.com
Apr 21, 2010 | HP Laserjet Cp2025n Printer
New HP CP2025 printer prints "ghost" DVD circles between labels
hi, i work for a company who is the dealar of hp products.
you have to do a clean service of your hp printer.
after that the printer should not have ghost print any more.
Apr 17, 2009 | HP Laserjet Cp2025n Printer
Brand new HP Laserjet printer CP 2025 appears to be running a little hot, causing excessive paper curl
hi the chairman..
when do bought that printer..from my experiance the paper curl couse of fuser got problem...
need to bring to hp centre...
Nov 07, 2008 | Office Equipment & Supplies
HP Laserjet Cp2025n Printer Logo
927 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
