Question about Meade LX200GPS Telescope
GPS takes over 5 mins to start up
Scope is permanently mounted in an observatory but the GPS takes over 5 mins to find satellites. Can anything be done about this - such as turning off the GPS?
  • 3,186 Answers
No that's about normal---
Posted on Jun 28, 2009
The GPS seems stuck on acquiring satellite. Any fix?
Usually if you did not use the GPS for a long time, it would take quite a while to acquire the satellite. Be patient!. The other reason is to make sure that you are not in covered area, go to outside and try again, it may take as long as 5-10 mins. Good luck!
Sep 30, 2014 | Garmin nuvi GPS
My Garminis taking a really long time to acquire satellites( sometimes 5-10 min),especially when I flip the top up to turn it on and whenI flip the top down to turn it off ,it acquires the satellites...
are you inside when trying this ? Garmin has a very bad reputation in acquiring satelites when in coverered position.
Go outside and you will notice it goes much faster.
Aug 11, 2009 | Garmin nuvi 260W GPS Receiver
Loss of GPS signal when Details key pressed . Screen freezes at this point, sometimes for 5 mins, sometimes permanently.
u r GPS does not get connect with server it is overload at the time of connect so reinstall the software of show it in to a service center
Jul 25, 2009 | Tomtom GO GPS Receiver
Nuvi350 doesn't locate any satillites. What can I do?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
Jul 11, 2009 | Garmin nuvi 260W GPS Receiver
Why does my GPS system have a difficult time locating satellites?It says ''acquiring satellites'' for about 5 minutes. Then it says it can't locate satellites. Should it continue trying? Why does it do...
this is what my navigon says about gettting the gps to connect.
Initializing the GPS receiver
In the upper right-hand corner of the display, the GPS symbol appears. As soon as
data from at least 3 satellites is received, the symbol changes to (GPS Ready). Note: If possible, position the device with a clear line of sight to the sky to successfully
receive messages from the GPS satellites.
Note: GPS initialization requires data from at least three satellites. If GPS data is not
available, the receiver will not initialize.
Note: It can take up to 20 minutes to initialize the integrated GPS receiver for the first
time.
Note: Each time you turn on the device, GPS receiver initialization begins. When GPS
data is available, reception starts within one minute.
If the navigation device has been switched to standby for more than a week, the next initialization
can take up to 10 minutes.
Jun 19, 2009 | Garmin GPS
GPS takes a long time to receive satellite signal.
You probably are just in a bad location where satellites are not reachable. All these units work from the same satellites and recieve them the same so it wouldn't matter what brand you have. I highly doubt that the powerlines and cell towers are effecting the transmission.
May 19, 2009 | Navigon 2200T GPS Receiver
How do you use the dashboard disk to mount the GPS?
The idea behind the disk thing (assuming one side is flat and the other has double-sided tape) is for you to be able to mount the disk, with the tape, pretty much anywhere in your car. Once you've found a good spot, clean that area, then peel off the piece covering the sticky tape and stick the disc on to the spot. Once that's done (won't take more than a few seconds), you should now be able to use the suction-cup on the disc (instead of on the windshield).
Either way, that tape is permanent. When they say permanent, they mean permanent. I lived where the outdoor temp was 100+ degrees everyday, and that thing would not come off. Point is, just make sure you mount it where you want it. Just a heads up. :) Good luck!
Mar 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Unit locks out fine blue line appears have to remove batt and then turns on
Disable the WAAS on your unit. A new satellite was launched earlier this year and is causing a problem. This is why Garmin issued a new software update version 3.9.
Menu > Setup > System... scroll down to WAAS and disable it. This should get your unit working again but with less accuracy.
Update the software to version 3.9 and leave for about 20 minutes in open area (clear view of sky) so your unit can download the full almanac. This should permanently fix your problem. Once you finish upgrading, go back and enable the WAAS.
to mhotz: You can purchase serial2USB connectors at a computer store. You will have to install the drivers which come with it before it will work. That should solve your upgrade problem.
Oct 22, 2008 | Garmin eTrex Legend GPS Receiver
Locating satellites
This takes about 15 to 30+ min. Make sure you are in an open area and NO XM or serious receivers turned on!
Nov 27, 2007 | Garmin StreetPilot 2610 GPS Receiver
Meade LX200GPS Telescope Logo
100 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
