Question about Seagate Barracuda 7200.10 ST3160815A - 160GB - 7200rpm - 100MBps Ultra ATA/100 (ATA-6) - ... 160 GB EIDE Hard Drive
The hard drive is not a year old but has now started being noisy its like a nosiy fan motor, it is still working.
  • 477 Answers
Hello, I think it could be the writer head. backup your data and send it on warranty.
Posted on Jun 25, 2009
How do i fix a noisy indoor unit fan motor
I have a 40 year old Sears fractional HP dehumidifier that gets noisy from time to time and I solve this by applying some oil to the motor shaft next to the bearings on the motor. The other possibility is the fan blades may be slightly touching something.
Sep 20, 2016 | grunaire GSI091HXB / GSU091HXB 9,000 BTU...
Apricorn ext hd dvr noisy fan issue
Yes you can place the hard drive into an USB hard drive case.
Replacing the faulty fan is easier.
Jul 01, 2012 | Apricorn ADVRE-1000 DVR Expander - 1TB USB...
Got noise from fan told its fan on hard drive worn is this fault with them only 2 years old
The hard drive does not have a fan. There is a fan on tht CPU heatsink and a fan in the power supply. You may have a case fan for additional cooling, but this is not always installed.
Noisy fans are easy to replace, but not the one in the power supply.
Jan 13, 2011 | HP Pavilion dv9000z Notebook
Lincon LS 2006 5600 kl coolent fan runs in winter when the temp gage is normal the radeator is not hot.The fan is very noisy, the engin has ben bled of air. The car has ben looked at by Lincon dealer said...
the fan has a low and high speed or some have 2 fans. It comes on low speed when the temp starts to climb or when you turn the a/c, defrost, or mix mode (it turns on when the a/c compressor kicks on. If the temp of coolant gets to about 230 F, then the high speed kicks in.
What is your doing? Very nosiy sounds like high speed. Could be a defective ECT - engine coolant temp sensor.
Dec 07, 2010 | 2006 Lincoln LS
#GLHS35E4SB6 Frigidaire side by side. evaporator motor area becomes extremely noisy and eventually shuts off. The fan could be floating on the motor shaft and engaging the shroud. Apparently the...
be sure maybe the sound coming from evaporator fan some times it accumulate ice near it do not open for long time both doors or put hot things inside the fridge or freezer .
Sep 11, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a noisy Pro-Form Model 285T treadmill
Hey Richard Depending on the noise it could be one of several components failing. If loud clanking or clunking noises these components are Drive Motor, Front or Rear Rollers.
If it is a loud humming noise increasing and decreasing when planting yours feet then it is either the Inductor ( square object ) or the internal windings of the Drive Motor.
Unplug your unit remove the motor shroud with a long shaft flat tip screw driver you'll be able to pin point the problem with this tool.
Now locate front shaft and rear roller tension adjusting bolt ( refer to owners Manual) plug in unit, start unit and touch flat tip on the shaft and place your ear on the handle the noise will be amplified and you will be able to locate the noise repeat this procedure on the other above mentioned components if problem is not found. GOOD LUCK!
Jul 31, 2010 | Proform Exercise & Fitness
Noisy outside from the Unit
Could be compressor noise Improper charge bad fan motor hard to say. What is the brand name of your unit. Russ
Jul 20, 2009 | Ruud Handle Air Conditioner
Noise
That noise is due to your Power-Supply-Unit, Hard-Drive, Optical Drives, other spinning devices, and ventilation fans. You can reduce some of it but not all of it.
For example, your hard-drive could be rather old and producing a lot of noise when it spins up, reads, or writes data. You could replace it with a newer hard-drive which barely makes any noise. The same with your Power Supply Unit (PSU). It could be old and rather noisy. You could buy yourself a newer one such as the ones made by PC Power & Cooling which gets you a quieter product. However that's about it as you DO NOT want to reduce the amount of fans in your system.
Sorry if this was not the solution you were after. However most noise from a computer stems from ventilation fans which can be replaced but should not be removed.
Feb 02, 2009 | Abit NF7-S V2 Motherboard
Noisy Oven when heating up & fan spinning
Neth, Im not familiar with this oven but I thing someone is handing you a line. I've been doing this for 30 years now and never saw a oven cavity arch when heating. The fact is that there is something wrong with the fan motor or fan blades itself. Call this cat back and have them honor your warranty...Catriver..post back.
Sep 12, 2006 | Baumatic B180 Electric Single Oven
Seagate Barracuda 7200.10 ST3160815A - 160GB - 7200rpm - 100MBps Ultra ATA/100 (ATA-6) - ... 160 GB EIDE Hard Drive Logo
113 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
