Question about Panasonic CX-DP88 8-Disc CD Changer
Check Magazine That is the message that appears on my CD player. I cannot play any CD's. I do have the manual, but there's nothing written about this issue. I'm hoping this is something I can fix myself. Thank you!
    President:
  • Panasonic Master
  • 1,114 Answers
If you have a "Laser Lens Cleaner" preferrably one that has fluid, run it thru a couple times then test a clean cd. If you don't have one you can find them at just about any electronics retailer. CD/DVD/PC should be cleaned 3 or 4 times a year. If it still won't play, it needs service, they will replace the transport, on average you are looking at a 100-175 repair
Posted on Jun 25, 2009
My pioneer PD-M426 seems to only play disks 3 and 4 even when the magazine is full, sounds like its trying to spin the disk but failing..??
Please remove the magazine and check if there is warping within the magazine which can cause misalignment. In such a case you will need to replace the magazine . Also check all the CD's within for any damage, sometimes some spurious types can warp with heat.If so it will not load and play. Test in another cd player to confirm.Also clean the optical head within the player if this fails to read or else the optical head can be also weak.
Mar 11, 2012 | Pioneer Audio Players & Recorders
My nsm jukebox has error#73 . What is that? why wont it play?
malfunction of left side magazine check alignment and grip function
Oct 07, 2011 | Wurlitzer Jukebox CD Player
My original problem WAS that the magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame INSIDE the...
there are small drive belts that provide the power to operate the different parts to eject the CD magazine, i suggest you remove the covers and check these belts for slack/strech, it is a common reason for this problem
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
I can not get the Magazine to release. I see where it say's Manual Magazine realease, but can't tell what to do. Please help Darrell Mack
Hi
Thanks for using FixYa. First of all please check that the speaker cables are not damaged and the connections are secure. Reduce the output level from any external components connected to the music center. Make sure the audio input cable is firmly seated in the music center SPEAKER ZONE 1 jack and the multi-pin connector on the other end is firmly seated in the Accustoms module AUDIO INPUT jack. Check the cables connecting the Jewel Cube TM speakers to the Accustoms module. To restore communication between the music center and the speakers turn the music center off for ten seconds, then on again. Check the connections for any external components. Make sure to select the correct source for the desired input. Be sure the CD is placed correctly, label-side up, in the magazine, and the magazine is inserted properly in the music center. Increase the volume. Check to see if MUTE is lit on the display. If it is, press the MUTE button on the remote control to un-mute the sound. Disconnect any headphones. Connect the FM and AM antennae. Check to see if the play symbol in the display is lit. After pressing the CD key, wait a few seconds before pressing PLAY. Make sure the magazine is properly inserted. Check to see if there is a disc in the magazine, label-side up. Display shows a flashing box for a disc that is label-side down or cannot be read. There may be dirt or dust on the CD. If so, clean the CD. Eject the magazine and try loading the CD again. A display message “E01” indicates a mechanical error. Unplug the music center. Reconnect power and try again. If “E01” reappears, call customer service.
If the CD stuck again as you stated in your earlier comments, then you need to use a small and long screwdriver to reach the notch. Now turn the media center upside down so that the "Manual Magazine Release" is in your upper right hand. Locate the two small rectangular "Open Slots" on the side. You need to use the top slot. Use the screwdriver and push the little "U" or "Y" Shaped metal upward which is just below the manual release. The magazine will come out.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 16, 2009 | Bose Lifestyle 20 System
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 14, 2009 | iLO CA3000V CD Player
Display read "disc error" then "no magazine"
Most likely there is a CD jammed in transit between the player mechanism and the magazine. This is a common problem. You will have to remove the unit and disassemble it sufficiently to get the CD back in the magazine and, in turn, allow the magazine to be removed.
Jan 28, 2018 | Alpine Car Audio & Video
Bose Lifestyle CD not eject
There are some repair instructions available at www.AnyoneCanFixIt.com in the electronics section that will show you how to release the CD magazine and fix the problem where the unit will not play the CDs (you will hear a buzzing, buzzing, buzzing, and nothing will load or play).
Oct 11, 2008 | Bose Lifestyle 20 Shelf System
Motor runs continuously
hi there try to disconnect the power as it is doing this wait 10 seconds then hopefully the unit has reset itself as it might be a control board glitch. Have you recently installed in a new car if so check that you have the correct connection as if the pin outs are incorrect can also cause this problem.
Thanks J
Feb 16, 2008 | Sony CDP-C910 10-Disc CD Changer
Kenwood KDC-2025 won't play CDs
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ^^^^ ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. I suggest the lens needs a clean, or someone has dropped it and broken the delicate lens mech. Luck
Apr 30, 2007 | Kenwood KDC-2025 CD Player
Panasonic CX-DP88 8-Disc CD Changer Logo
135 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
