Question about Sony Ericsson K800i Cellular Phone
K800i wont hold charge
My k800i wont hold a charge .i have purchased a new batt but still wont hold charge..
  • ni1der Dec 20, 2007
    I have a samsung phone, it was purchased in June of 2007 (this year). It wont charge . The phone works with a charged battery, but it wont charge it up again. It's not the charger either ,The charger works fine because it worked on my Father's phone which is the same as mine. I went to the Cingular store in pittsburg Ca. and they said I need a new Battery, But that wont do any good once the Battery needs to be charged again. How can I get this fixed?. A new phone will cost around $246.00 plus tax. A new Battery is $59.95 plus tax (that's over $60.00). My Father bought me the phone and he is on a very fixed income. I feel so bad about it that now I have started to avoid his calls, I don't know what to say because it is not fixed yet. I don't want him to think it was my fault or that he has wasted a good deal of money. Please can someone help me?. I cannot afford much because due to illness I am not working and have just started to be able to walk more than the 5 steps at a time since the end of last june. thank you for any help
  • 32 Answers
There is only really three possible solutions to this:
Firstly replace the phone expensive so is it really worth it?
Sencondly again expensive, send the phone away for repair.
This will vary in cost greatly depending on who deals with it and what the problem is.
Lastly- You are going to need to try and clean the contacts on the phone. If the contacts are badly worn or oxidized etc, then the connection will not create a circuit. Use a pin or bent paper clip to gently remove dirt from around the contacts and to gently score the surface of the connectors to create clean metal between the charger and phone.
Good luck with this one as the last method is not that reliable.
Posted on Feb 05, 2008
Does anyone know why my Samsung galaxy lite will stop charging at 30%?
try to change the batt. sometime bad batt wont hold max power when we add charging into it.
Sep 21, 2015 | Samsung Cell Phones
New battery and charger wont charge over 45%
The battery needs to be calibrated from the setup. I this doesn't work, then ask for change of battery
Jan 27, 2013 | Dell Inspiron 1545 Notebook
97 checvy astro 4.3 6cyl. I replaced battery, Starter and the batt wont hold a charge. Is it possible to check the wiring from the alt to the starter without having to remove the alternator?
Yes, If you have a volt meter, jump and start engine, with engine running you should have approx 13.5 to 14.2volts that would tell me that batt is getting charged when engine is running. you said new batt would not hold a charge, I would be thinking about a parasitic draw(small amount of power) that in time will drain batt. things to look for are glove box lights, under hood lights that dont turn off. one easy way too see if you have a draw is to disconnect one batt cable, now use a regular (12volt non-self powered) test light and touch one end to batt cable and the other to empty batt terminal, with no light switches on and doors closed, this test light should not light and if it does then you have a drain on batt that will kill it say overnight.
Feb 12, 2011 | Chevrolet Astro Cars & Trucks
Not charging replaced alternater still wont charge
Be sure to charge the battery, otherwise you might smoke the new alternator(not made to charge a dead batt.). Have the batt. load tested. Check batt. cable ends for corrosion.
Nov 11, 2010 | 1994 Plymouth Voyager
Earlier this year, I purchased a new Ryobi P103 LI-ION 18 V/24 Wh battery powered blower. In the past week, the battery isn't holding a charge for more than 5 or so minutes. Any suggestions?
Try to discharge the batts to the full end.Then try charge them agian for at least 12 hrs.
Or contact them at
Nov 03, 2010 | Ryobi Multi-Volt Battery Charger
Batt wont hold charge
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service.
Aug 05, 2010 | Vector 1 Million Rechargeable Spotlight
Sony ericcson k800i, new battery and charger but wont charge up. any thoughts?
If it was not charging before and you replaced the battery and charger, then the charging circuit has most likely failed possibly a DC/DC converter. Probably terminal I'm afraid
Nov 10, 2009 | Sony Ericsson K800i Cellular Phone
97 civic new battery wont hold a charge alternator is fine....any ideas... thnks gf
remove pos batt cable from batt install test light in line. One end on batt other end batt cable. See if test light burn.s bright with car turnd off' Unplug fuses one at atime until you find on that makes the light go dimmer. then look in maual to see whats on that ckt'
Jun 24, 2009 | 1997 Honda Civic
Screen lights up when charging, but wont power on
Hi you have to hold the button down for few seconds if this dose not work leave to charge for longer,if you still have a problem your batt may not be holding charge
Jan 13, 2009 | LG KM500 Cellular Phone - Unlocked
My k800i wont turn on. just the infa red led flashes
when k800i is in battery low, infrared led will blink... try to charge your battery of buy another one.
Nov 16, 2008 | Sony Ericsson K800i Cellular Phone
Sony Ericsson K800i Cellular Phone Logo
114 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
