Hello Joanne, the Sony CDP-C225, is a 5 CD audio player
To listen to your Sony CDP-C225, on your Toshiba 46sl412u, you have to connect the LR audio output of the Sony to the LR ColorStream® HD / VIDEO audio input on the back panel of the Toshiba, then turn on the equipment, charge the CD on the Sony and you put in the Toshiba the Video input and there you can listen to the music of your Sony
I send you the links to download the manuals of Sony and Toshiba
I hope you can interconnect the equipment and enjoy the music
Greetings Franco Dosil
Hola Joanne, el Sony CDP-C225, es un reproductor de 5 CD de audio
Para escuchar tu Sony CDP-C225, en tu Toshiba 46sl412u, tienes que conectar la salida de audio L R del Sony a la entrada de audio L R ColorStream® HD/VIDEO en el panel posterior del Toshiba, luego prendes los equipos, cargas los CD en el Sony y pones en el Toshiba la entrada de V?deo y ah? puedes escuchar la m?sica de tu Sony
Te env?o los links para que descargues los manuales del Sony y del Toshiba
Espero que puedas interconectar los equipos y disfrutar de la m?sica
Saludos Franco Dosil
Those look like dead pixels. If there has been any impact to the screens surface recently, you can attribute them to that. If you want it fixed, is suggest that you'd be better off getting a new screen.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Check and replace damaged component/s at its backlight inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/
You hv bad capacetor on power board. Just open back of your tv and you will see couple capcetor swelen. They are only couple of dollar each. You just need to know to soder them
Hello You are talking about the Closed Caption function On problem I assumes. If the remote control to your tV has a "CC" button on it, press it once to eliminate it.
Power options is most likely where you need to look to fix this. Go to the Control Panel and search for Power Options then change plan settings.
On a laptop, you will see that there are different options when you are plugged in versus running on battery.
Check your settings for blanking the screen when you are plugged in, that's probably where you will find the problem, set it for at least an hour before it blanks the screen.
