Question about D-Link DCS-950G Network Camera
Won't connect with network share folder
I have previously had this camera working--and uploading saved files to a network location. Now, for some reason, no matter how I set it up, it will not connect to any network location using the Upload video to Network share folder options. I've tried anonymous/account, I've tried several different drives and computers. Ex: \\Weblaptop\ext_storage\dlink where Weblaptop is the computer, ext_storage is the drive, dlink the folder. Have tried with and without trailing slashes, various permutations of upper/lower case.
  • 298 Answers
Re: Won't connect with network share folder
It you can access the firewall program
try setting the network loacation
to the trusted zone
Posted on Nov 21, 2007
  • 306 Answers
Re: Won't connect with network share folder - D-Link DCS-950G Network Camera Webcams
Disable firewalls
Posted on Nov 15, 2007
  • 1,113 Answers
Go to the folder you are trying to share from
Right click on its folder icon, select properties, then sharing tab.
Enable - share this folder
Click permissions tab, allow everyone everything.
Posted on Nov 07, 2007
  • 363 Answers
  • Check that the camera is on the same subnet mask as the PC and that the ip address is not being used already
  • Web addresses should contain forward slashes
  • Dont forget you need to install ffdshow to view video
  • Try hard wiring it to a network port to get it working with the configuration utility.
Posted on Nov 06, 2007
0 characters
3 Points
Had to sykstem recover my computer and lost all my downloads including webcam installation and my disc drive no longer works how do i get mlyk; camera to work again
You sould be able to downlaod a driver from the Creative support site.
Download the file and save it in a location that you will remember (suggest you create a folder 'driver files')
Then go to control panel and 'add harware'. Follow instructions and when it asks for the driver location you should browse to where you saved it.
If you can't find the driver on the Creative site post here again.
You can do a similar thing for your disc drive - you need to find the driver on the manufacturer's website first.
Feb 21, 2010 | Creative Labs Creative Webcam
Need driver for Windows 7 Disk I have not compatible.
1. You will need administrator rights to your PC. If you do not have these rights, please consult with your network administrator or your parents (assuming that an adolescent may read this post)
2. Go online and search for the file CS630-XP.exe and then download it (if you don't have the install the disk. If you have the disk, proceed to step 3 but browse your disk for the setup.exe file and follow the program compatibility from there). I would share this file but copyright to Intel and Microsoft's Terms for posting on Windows Live forbid it, so you will have to search out the file. Sorry!
3. Once the file is downloaded, Extract the files then view the folder. Open up Control Panel, Programs, and go through the program compatibility steps to set the program to run as if your OS was still Windows XP SP3. Then, go back to where you downloaded the install file then right mouse click on the file and click "Run As Administrator"
4. Once the program completes, connect your Camera by plugging in the USB Cable into your PC.
5. If the "AutoPlay" Options do not appear, you will need a third-party program to retrieve your photos from your camera. I recommend Google's Picasa to handle this task. Go to Google and download Picasa,
To retrieve Pictures from Camera using Picasa:
1. Click Import
2. Click on the drop down menu till you see your device (e,g, Intel(r) PC Camera CS630 Image Storage)
3. You will then see all the photos stored on the camera
4. Select the ones you want then the rest is easy. Select where to import them to and then import!
Clearing Camera Memory
From time to time you may need to clear your camera's memory to make room for new photos. The only way to do this is through your OS (assuming you may not be running Windows). Go to Control Panel and in the search box on the top right type in "camera". Click the first button which says "View scanners and cameras". You should then see your device listed. Click on it then click Properties. Click the Camera Memory Tab then click Clear Camera Memory. Once cleared, click OK.
I sincerely hope this helps you!
Jan 06, 2010 | Intel Create And Share Camera Pack Webcam
I cannot set up my home network to share files and computers now
If you want to share a file on your network right click the file select properties, in the sharing tab check share this file. Make sure all you computers have the same workgroup name.
Dec 01, 2009 | Webcams
Cant save pictures
QuickCam Gallery
Your pictures and videos can be viewed in the QuickCam gallery. To view your pictures in the Gallery:
  1. Launch QuickCam (Start > Programs > Logitech > Logitech QuickCam)
  2. From the QuickCam menu, click the QuickCapture button as shown below:
  3. View your pictures and videos in the Gallery area located below the main QuickCapture window as shown below:
For the picture gallery, click in the picture icon:
For the video gallery, click on the film icon:
My Pictures / My Videos Picture Files:
You can also view your pictures and videos by opening the QuickCam folder in My Pictures or My Videos. To see your pictures this way, do the following:
  1. Open the My Pictures folder (Start > My Pictures) as shown below:
    NOTE: If you have Classic view in Windows XP, simply open the My Documents folder on your desktop and then open the My Pictures folder.
  2. Open the QuickCam folder.
  3. Your pictures will be shown as follows:
  4. To view your pictures, double-click and they will open in the Windows Picture and Fax Viewer or any other picture viewer you have set as your default picture viewer on your computer..
Video Files:
To view your video files:
  1. Open My Documents folder as shown below:
  2. Open the My Videos folder:
  3. Open the QuickCam folder:
  4. Double-click on the video file you wish to view and it will open in Windows Media Player or any other video player you have set as your default video player on your computer.
Jan 15, 2009 | Logitech QuickCam Communicate STX Personal...
Error with ezonics web cam
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 05, 2009 | Webcams
Saving pics i take
you have to create seperate photo albums and folder names. the the camera labels your pictures 1 2 3 and so on. so when those numbers come up again they are overwritten with the new info. so to avoid this...create one folder.(main)... then open that folder and create a new (sub)folders within the main folder for every download hopefully 10 or so more pictures at a time per sub the sub filders according to the content or, the current date which they were downloaded. what works well with myspace is your personal picture storage online for free. but til then the simple way is to keep this main folder in my pictures...most sites assume your pics are already there. it is the default directory with your msp,s(myspace pik's) ready to upload.
Jun 02, 2008 | Philips J44414
Can not get picture from quick capture
if you take a picture from your the upper left side, you will see the "File", click that file then save to any folder you want=.)...or right click your camera to explore your camera, then, on your left side you will a dialog box, click the "take new picture.. and then shot of your pic. is in the bottom, right click that pic. and then save to any folder you want.
Feb 24, 2008 | Logitech QuickCam Express Web Camera
Uploading photos to internet
Right wat ya gotta do is.. take ya photo(s).. then using your Software & Data Transfer Cable, usually USB, you then download the photos from ya camera to your PC's hard Drive, & then usually ya must convert the Photos to a smaller more suitable size.. However most sites explain how big the files should be... and how to "Upload" them to their site. To perform these actions one must install the camera's Data Transfer Software & Drivers, that came with the camera. OR locate and download the Drivers from the manufacturers web site. Install the software then reboot, THEN plug in ya USB cable connected to the camera, and then turn on.. it should be "Detected" and it may ask for "Drivers" if so, simply point it in the direction of the Driver Files, usually on ya CD. After the software and drivers are installed, you can manipulate the files as ya wish. Then you are ready to start using the Uploading Software, from the site required, like say Ebay etc. This software will ask you for the "Location" of the Photo(s) ya point it to the Photo's location and the Uploading Software will do it all for you from there on... The link below is for a Photo resizer, that may come in handy.. just download & install. powertoys/xppowertoys.mspx hope that helped...
Sep 03, 2007 | Webcams
D-Link DCS-950G Network Camera Logo
261 people viewed this question
Top D-Link Webcams Experts
micky dee
Are you a D-Link Webcam Expert? Answer questions, earn points and help others
