Question about Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117
Arc starter on sync 350 interferes with equipment
My turn table system driven by a dc motor accelerates when i attempt to stike my arc. If i shut off my arc starter system all works normally. this is an intermitant problem, I have good grounds, whats going on?
  • 24 Answers
It's the high frequency, ground the case of machine, work lead connection and work table, do not chain grounds together, this will cause a ground loop.
Posted on Sep 18, 2009
Lincoln electric ac/dc arc welder will not arc
Check the dial indicator. Sometimes if someone changes the amps while welding, there will be a break in the coil. It will work at a different setting as long as you are away from the break.
Jul 17, 2014 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Motor on philco turntable not working
Most of these motors run on about 9 to 12 volts DC. You can connect a 9 volt battery to the terminals of the motor. Make certain the rest of the system is off and the motor power leads are not connected to the main system. If the motor doesn't turn with the battery it's faulty. If it does then you are perhaps looking at some switch that has failed or the power to the motor itself!
May 04, 2014 | Philco (R) Classic Turntable CD Shelf...
Miller 300D I'm having issues striking an arc even when I have it turned up to 140. Or when welding the rod just sticks in the middle of a pass. Welding structural steel with 7018 1/8 Excalibur rod. Any...
The problem might be with your rods. It sometimes happen that the flux around te metal becomes soft if the rods were kept where there is a lot of moisture. If that is the case you can 'bake' the rods in the oven to dry it our. The flux must have a lower melting poit than the metal rod so that it can make a cup. The edges of the cup keep the rod away from the metal, allowing the arc to jump.
How do you 'strike' an arc? One method is to tick on the metal. A better method is to stike the rod over the metal like you stike a match. This action will give you the 'cup' that you need to start welding.
I hope it helps.
Oct 18, 2013 | Welding Tools
This little 1999 Chevy Metro, 4 cyl. 1.3L car has many problems that I'm trying to fix. At the moment, it will not start. I checked the battery (bought it 11/12), it is a good battery with 100% charge....
If you have coolant pouring out, that has to be resolved before you do anything. If this car was driven in that condition, you may have destroyed the engine already.
Aug 17, 2013 | 1999 Chevrolet Metro
The turn table is going round but its playing the record to fast the speed seems wrong
Hello!
are you sure, that your speed selector is on 33.3rpm, not 45?
assume, it's in correct speed settings. do you know, that across the ocean power grid AC frequency is 50hz, in US it's 60hz. Means: ac motor will spin faster, than it should. If you bought this unit abroad, that's where is your problem at. some expensive units have 50/60hz pulleys switch, some not. Especially, if it's DC or direct drive motor. Check your owner's manual for specifications. May be you find an answer. If not, there is a problem with motor's regulator, which is built in(DC motor). Turntable is a belt driven. If you won't find 50/60hz adjustments, take it to repair shop.
Good luck,
Alex.
Jan 11, 2012 | Aiwa PX-E860 Turntable
2002 Saturn SL1, 72K miles. Hasn't been driven in
Single click? More battery is needed. Id change the battery, or slow charge it.
Might also be the security system shutting down the starter. Common on GM vehicles. Heres a link on that. http://vatspasslockpasskeysecurityhelp.yolasite.com/
May 27, 2011 | 2002 Saturn S-Series
I have a 2003 isuzu rodeo, and the timing belt broke. its a 2.2l motor. I have no compresion and i think its the head. is there anything else besides the head that i need to be aware of when fixing my...
Don't condemn the head just yet.
When the timing belt breaks, the camshaft stops turning, so the relative position of valves doesn't' change if you try cranking the motor over. Any valves (intake or exhaust) that aren't fully seated will allow pressure to "blow by" that other wise would form the compression you say you no longer have.
What I'm not sure of is if you have an "interference" motor. An referenced motor is one in which the piston can strike a valve head when the timing belt breaks. The clearances are so close that all moving parts have to be in perfect sync in order to operate and not strike one another.
It is possible, with an interference engine, to break valves and / or crack a piston if attempting to crank and the piston comes in contact with an open valve.
If it isn't an interference engine, you shouldn't have any problems. Just get the cam and crank (and any other shaft(s) that may be belt driven) in proper timing, install a new belt, apply the correct tension and you're basically "good to go"
I'd suggest you purchase a vehicle specific repair manual at your auto parts store. It'll contain step by step instructions specific to your vehicle on how to perform this repair.
Feb 10, 2011 | 2003 Isuzu Rodeo
Lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Ran out of diesel 1.9 TDi 74kw. have refuelled and cranked engine for 15mins and still it won't start. there is fuel from tank to filter, to pump and return flow.
This is very important for Audi 1.9 TDI engine: IT IS FORBIDDEN TO RUN WITHOUT DIESEL FUEL IN RESERVOIR !!!
This type of engine is equipped with pump-nozzle injectors which develop up to 2050 bar injection pressure !
Remove the fuel filter, fill up with diesel fuel and put in place. After that try to start the engine with accelerator pedal to the floor. Heed of electric starter motor temperature and battery status! After 40 - 50 sec. of start attempting wait for 1 - 2 minutes for battery and electric starter motor revival. After few starting attemptions the engine must start.
Jan 13, 2010 | 2004 Audi A4
My Skil Saw 10 will not start now.
depends wether the saw is belt driven or gear. just because you cant hear the motor doesnt mean its not running.
Apr 25, 2009 | Skil 10" Table Saw 3400
Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117 Logo
176 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
