Question about JVC AV-27530 27" TV
TV viewing screen shrinks to picture in picture size
I have a 10+ year old JVC TV.  Have just recently upgraded to digital TV.  When turning channels, display will shrink to the size of picture in picture (it is the same exact size as the display screen you see when looking through the digital tv guide) I have turned the tv off, and turned off the digital/dvr box with no luck.  Not sure if the problem is related to the new service or if something in the tv is wrong.
5 Suggested Answers
  • 275 Answers
SOURCE: tv screen shrinks
Looks like some of the Electrolytic Capacitors in the Vertical Output stages have dried out and need to be replaced. If you are conversant with Solid State electronics servicing, then you can make an attempt. I generally do not waste time identifying the faulty capacitor, but replace the entire lot in thre Vertical stages. There are not more than 8-10 of them. Since you are changing them en masse, should not take you more than 30 - 45 mins to desolder the suspect ones, and solder the new ones. And it also saves you the bother of new problems cropping up in the near future, as all potential problems with old capacitors get removed.
Posted on Jun 20, 2007
Siliconchip
  • 52 Answers
SOURCE: vertical probs
yoyoy, check some leaky capacitor near the vertical chip. some of this caps may have gone out of their value.
Posted on Dec 29, 2007
  • 280 Answers
SOURCE: black screen on EVERY input/channel
Turn off the closed capition
Posted on Jun 19, 2009
SOURCE: Black box taking up over 1/2 the screen.
caption box selection is on. disable caption
Posted on Jun 29, 2009
50 INCHAdjust picture size to fit screen
Picture size depends on how the program is broadcast to the TV. You can use shrink, letterbox on some tv's to expand a picture but the aspect ratio will be wrong. There is no adjustments if a program is broadcast in standard definition and viewed on a HI definition TV.
Apr 03, 2015 | Televison & Video
Picture of the tv shrinks to half
Could be a failing power supply. Not surprising after 10 years of use
Mar 22, 2017 | Televison & Video
JVC picture turns into a single line in middle of screen.
This is caused due to random falure of vertical scan circuits. It generally is caused by dried out capacitors or bad driver IC. Unfortunately it will get worse. If you fail to turn the TV off quickly you will burn a permenant horizontal line on the tube. Trip to the repair shop I am afraid.
Nov 30, 2009 | Televison & Video
PLTV-32- Picture on screen is larger than TV screen.
if you have HD cable try shrinking the picture there. LCD's are not subject to 'bloom' like
analog tvs. try the aspect button on the remote.
wrong picture size on a digital tv is a result of the input signal.
Apr 05, 2009 | Protron PLTV-32 Television
46" screen with an <8 x 11 picture!
you should contact samsung and inquire as to poss.warranty defects of this item
Aug 23, 2008 | Samsung HLN467W 46" Rear Projection HDTV
JVC i art 32" flat screen
Does anyone know where can I buy a screen for a 27" LCD Insignia TV. Model is NS-27LCD? My screen creaked. I checked out e-bay and have not found a broken TV with a good screen. Does anyone know where I can buy a screen at.
Thank you all for you time.
JC
Jul 22, 2008 | Televison & Video
Picture partially cropped at bottom of screen
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Dec 24, 2007 | JVC AV-27230 27" TV
Horizontal Lines
The unit most likely has a short in the horizontal section and would require repair by a service center. Go here to find a JVC repair center in your area http://maps.jvc.com/cAscList/
Sep 18, 2006 | JVC AV-56WP74 56" Rear Projection...
JVC AV-27530 27" TV Logo
127 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
