Question about Epson STYLUS R230 InkJet Photo Printer
I have the same problem vertical line epsonr230
My problem is vertical line on my photo print out tiny but visible i try nozzel check all good, i clean it many time i think more than 10 times,and give me the same result.i also try to alignment check the first one is bad. then i realigned it then later i have Good result on it ten times also. But my photo print out in Photo mode have this tiny vertical lines.I try also try to print in best photo mode it gives me slight improvement but the print speed is low. Pls help me.. thank u in advance
  • edgarallan_l Jun 25, 2009
    my printer have ciss. it this means i need to replace my cis?
  • edgarallan_l Jun 27, 2009
    how should i know which of my cartage is leaking?
  • 400 Answers
Get your printer service and get new INK jets mean Cartage for your printer thank you it will get no vertical lines then .. it is caused when cartages are leaking..
Posted on Jun 25, 2009
  • Azum Saeed Jun 28, 2009
    take out the ciss shake it on an paper or toilet paper there you will know if ink flow on to paper then its leak...
When I print a photo, vertical lines appear throughout the photo. The ink cartridges are new. No error message appears on screen.
Please state the model of your printer.
Vertical lines appears on prints because the nozzles on your print head are blocked, it doesn't means all nozzles but some of your nozzles are blocked. A print head of an inkjet consists of many tiny little pores or nozzles, through which jets of inks are sprayed on the photo paper to create an image, if some of this tiny pores are blocked print outs deteriorates, so cleaning the print head is an option if your printer has print head inside the printer you can first clean it through the head cleaning option present in the maintainence tab of your printer software, for printers that have print head on the cartridges, you can add a few drops of isopropryl alcohol on the print head and leave it for a minute and put it back on the printer and run the head cleaning utility of your printer software.
Hope this helps you.
Apr 28, 2011 | Office Equipment & Supplies
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
Not printing - just replaced ink cartridges
Reseat the cartridges.
Do 3 consecutive head cleanings.
May 02, 2009 | Epson Stylus C84 InkJet Printer
Vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I have a casio exilim ex-z1080 and whenever i take a photo there are vertical lines on the screen, it has only just happened and even when we download the photos they are showing up with vertical lines on...
Are the vertical lines on the images when you view them on screen, or only after you print them on a laser printer of some kind.
If the lines are on screen, your issue is in the device sensor.
If the lines are on printed images, try aligning your print heads (use your printer utilities whenever you replace an ink cartridge), or take the images to a kiosk (Kodak and others have those at verious retail outlets).
DigiChick
Jun 05, 2008 | Cameras
Green tint on photos
perform deep cleaning and nozzel cleaning from the printer properties
May 16, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Photos they come with a yellow line through it
This kind of thing happens to me a lot when my cartridge is running out of ink, and if it has been doing it since you first used the cartridge it may just be a dodgy cartridge.
However, this printer doesn't print the clearest of pictures even at the best of times. If when you do the alignment check you find that in the selection with the least obvious lines, the lines are still pretty obvious, then your printer's just not very good.
Mar 20, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Printing light colors does not work
You RINSED the printhead???
I wouldn't do that again.
Try taking a damp cloth and dabbing it against the printhead nozzels until you get lines forming on the rage from the ink (the nozzels you're having trouble with specifically).
Erice
Oct 29, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Epson STYLUS R230 InkJet Photo Printer Logo
371 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
