Electronics - Others Logo
Posted on Nov 05, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Book320 GB Premium Edition
I am unable to access my My Book via VISTA computers. Each time I try to access the drive, it asks if I want to Format it. I have tried with XP and Vista computers.
Arnold G
Level 2:
Champion:
  • Expert 208 Answers
  • Posted on Nov 05, 2007
Arnold G
Expert
Level 2:
Champion:
Answers
208
Questions
0
Helped
123037
Points
334
Its probablyt a raid volume. or u need to do chkdsk /r in recovery console
My Western Digital keeps asking to be formatted. I am unable to open the drive or reformat. What can I do?? I have a lot of files on this drive.
Hi, If you format the drive you will erase everything on it including your files. I would run your ant-virus you may have a virus on it. Second save all your files on a back-up disc. Then format the drive if you can. good luck.
Problems access my My Book External Hard Drive
have you checked you usb connection? try unplugging it then plugging it back in see if computer recognises it then if not chances are your drive has failed
My Book Premium purchased 10/2007 suddenly not working; unable to see the data on the drive or get the drive to consistently get recognized.
frist of all you have recover your data before u do any thing with HDD try it with any recovery software after that try to change your case still not detading then u r HDD is gone
try to recover your data first
1helpful
My Book suddenly cannot access files, needs formating
If you are running Vista, You might be one of many people who are reporting an update that is causing some buggy behavior. Try this:
Connect the drive but do not Format the drive, right click 'my computer' then 'manage' go to 'storage/disk management' view the drives; your usb drive will not be allocated a drive letter. You can set one manually or leave it for about 2~5 minutes for one to be allocated auto. Each time you connect the drive you may have to do this.
2helpful
2answers
System requirements of vista
For Vista Home Basic >>>
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 512 MB of system memory
  • 20 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics and 32 MB of graphics memory
  • DVD-ROM drive
  • Audio Output
  • Internet access (fees may apply)
Additional requirements Actual requirements and product functionality may vary based on your system configuration. Windows Vista Upgrade Advisor can help you determine which features and edition of Windows Vista will run on your computer.
While all editions of Windows Vista can support multiple core CPUs, only Windows Vista Business, Ultimate, and Enterprise can support dual processors.
For Vista Home Premium, Business and Ultimate >>>>>>
  • 1 GB of system memory
  • 40 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics with:
    • WDDM Driver
    • 128 MB of graphics memory (minimum)
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • DVD-ROM drive
  • Audio Output
Home Premium / UltimateTV tuner card required for TV functionality (compatible remote control optional).
Home Premium / Business / UltimateWindows Tablet and Touch Technology requires a Tablet PC or a touch screen.
UltimateWindows BitLocker Drive Encryption requires a USB Flash Drive and a system with a TPM 1.2 chip.
Windows Vista minimum supported system requirements Home Basic / Home Premium / Business / Ultimate
  • 800 MHz processor and 512 MB of system memory
  • Support for Super VGA graphics
  • CD-ROM drive
Regards.
External usb hard drive wont format on windows vista
Download a free disk partition manager from somewhere and use that to format it. Western Digital used to have some disk utilities on their website which would do it so it's worth looking there.
Cant connect my 1TB WD world edition to my linksys router
Your My Book World should not be formatted or you will lose all ability to access it through the Network -- it will simply become a hard-drive at that point. There is software installed on the hard-drives that communicate with your Router in order to obtain an IP and be available as a Network Drive. If the drive and the Router are communicating, you should see an IP in the DHCP list of your Router. It is possible that the My Book World is not setup for DHCP, so if it is placed in an alternate environment with incompatible static IPs, it won't be able to access the Internet or be available locally. You can try a hardware reset on the drive and see if it pops up in your Router's DHCP/Client list, at which point it should also appear locally and over MioNet (MioNet will need to register the device to an account before it will appear in MioNet, but it must detect the drive locally in order to attach).
1. Turn off My Book World
2. Identify the reset button on the back of My Book World
3. Depress the reset button while restarting My Book World
4. Keep the reset button depressed for about 10 seconds after you see blue lights on My Book World
1helpful
Problems with Western Digital My Book 1000 GB Hard drive on Vista
download a free hard disc eraser program erase the disc space, you do not need wd`s software. then reformat the drive from vista choose ntfs format
My Book Premium Edition II
Try to scan it with R-Studio or GetDataBack.
Top Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
