Official Huawei IMEI Permanent Unlock Important Select the Current Network... Here is the process to get unlock code
Follow these steps:
go to above link
Select: Brand Name
Select: Model No and click unlock button
on the next page proceed the steps below:
1) select purchase country and network on which device is locked, your mail
id then make payment
2) We will send you login details(Username and Password) for unlockninja.com at the same moment in your mail to update IMEI No
3) Make login and Update IMEI, we will deliver you the code in The least possible time
hi,<br />i just want to share how to get your FREE unlock code in your Huawei USB Modem and Vodafone..some of the askers here are not given the right answer they want
,they are always giving a link for the network unlocker that costing
around 10 to 15 usd dollars..<br /><br />here is how,<br />1.post your Modem model ,IMEI number at the premium
question under the cellular phone category and i will CALCULATE your
unlock code for FREE..<br /><br /> EXAMPLE :Huawei E880<br /> IMEI :<span>356745867168790<br /> <br /><br />after i calculated the Unlocked Code ,here is the procedure to enter it..<br /><br /></span><span>
<p>To enter code in USB 3G Modem, just follow these instructions
:<br />
<p>1) Open Hyperterminal<br />2) You must set com port on modem
(Huawei Mobile Connect - 3G Modem)<br />3) Type following command :
AT^CARDLOCK="<your unlock code>"<br />4) Validate by pressing Enter.<br />
<p><br />
<p>i hope it will help you ..i am now waiting for your post to calculate your FREE unlock code..<br /></span><br /><span><br /></span>
Do you want unlock code Calculator for your Huawei E1762 modem?
Unlock code Calculator always won't generate accurate code.So it is advisable to get correct and accurate code for your Huawei phone from any any online commercial vendors like Mobile-Unlocker.com here you need to specify your country,Network name to which it is locked,IMEI number of your phone.
What's your Exact Huawei modem model?you can get your Huawei E173 modem unlocked from network lock using unlock code.Unlock code is the best and safest way to unlock.you can get such codes from your Network service provider or any third party online vendors like Unlock-Zone.com You can also have a lookup at this free guide MobileUnlockGuide.com which gives free unlocking instructions for modem and phones.Using this you can unlock your modem from Network lock easily.
You can get the unlock code for your Huawei E160G phone from TheUnlockSpot.com And you can get free unlocking instructions from MobileUnlockGuide.com using this you can unlock your modem from Network lock easily.
Unplug all usb devices and restart your computer. If problem perursist re start your pc and press the f8 key and select HD. no boot device means that your pc is not recognizing the hard drive and is trying to read the CD or your USB Device...tekgods
idea uses huawei eg162g data card to unlock this you need to edit the deviceinfo.xml file go through it and where ever it is written "<item
name="WCDMA" Alias="" SMMode="PDU" ProductNet="WCDMA"
SimUnlock="Y">" change it to <item
SimUnlock="N"> and save the file remember it is right protected file. to overwrite this save the edited file to some other location and then copy and paste in the program files/idea net setter/
close your idea net setter and restart net setter now you can use any sim cards
