Question about Olympus Camedia C-770 Digital Camera
To much light exposure when taking photos
Whenever I take a photo now I somehow seem to have to much light getting through and causing a glazed ( almost like glaucoma vision ) image to appear on the lcd when I check it. It has randomly not had this problem when I have tried taking night shots before. But I cannot take any photos in daylight anymore and most night shots dont work now either.
  • rachel_elmes Jun 25, 2009
    I cant seem to find where the return factory setting option is on the menu. Thanks anyway
  • 86 Answers
Go to menu and try to setup the factory settings it may be a setting that is doing that.
Hope it helps
Posted on Jun 25, 2009
Whenever I take close up photos with a white cloth background it comes out blue, even in natural light. I use the auto feature as it works well for my jewellery it's just the colour balance I need
The exposure meter in your camera is underexposing due to the white background. Try adding up to two stops of positive exposure compensation. What you are seeing as blue is in fact grey - it may be an idea to calibrate your monitor as well.
Aug 10, 2017 | Canon PowerShot G11 Digital Camera
Whenever I take photos in shutter priority mode, all the pictures seem to be UNDEREXPOSED not overexposed like most people say it is. It also says LO where the f-stop number should be. PLEASE HELP!
Your shutter speed is too fast. The correct exposure requires a lens aperture larger than physically possible on the lens. That's what the "LO" is telling you. Slow down the shutter speed until the "LO" goes away. Alternatively, increase the ISO sensitivity (or a combination of both).
Just because you can set the shutter speed to whatever you want doesn't mean you can get a properly exposed photo at that shutter speed. There may be too little light (as in your case) or too much light. You have to use a shutter speed appropriate for the subject and the light conditions.
Dec 20, 2010 | Nikon D3100 Digital Camera
All my recent photos are pink. Light sensitivity has gone wrong!
I think I'm having the same problem. If I take a fairly close up photo of someone, they appear very pink. If I take the same photo from further away and instead zoom in, it looks much better. This is a new problem. Never had anything like this before. I tried checking all of the same settings as anouska did. If I manually set the ISO to a higher number, it seems to correct the problem, but auto ISO gives the pink photos. Any advice?
Jun 27, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
My D90's multiple exposure won't turn off !!
Have you tried going into the menu and finding "reset"?
Mar 01, 2010 | Nikon D90 Digital Camera with 18-105mm...
I want to know that how to adjust exposure level in sharp 1118 or how to make light copy with diganostics mode
l For manual copy density adjustment, press the AUTO/
MANUAL/PHOTO ( / / ) key to select
MANUAL ( ) and adjust with the LIGHT ( ) and
DARK ( ) keys as desired.
l For photographs, select PHOTO ( ) and then adjust with the
LIGHT ( ) and DARK ( ) keys as desired.
l There are 9 exposure steps indicated by 5 indicator lights. (The
indicators light up one or two at a time.)
Successive pushes of the LIGHT ( ) key will change the
indicator lights in the order (3) / (3•2) /(2) / (2•1) / (1).
Successive pushes of the DARK ( ) key will change the
indicator lights in the order (3) / (3•4) / (4) / (4•5)/ (5)
The automatic exposure level can be adjusted to suit your copying
needs.
1 Press the AUTO/MANUAL/PHOTO ( / / ) key
to select the PHOTO ( ) mode.
2 Press and hold the AUTO/MANUAL/PHOTO ( / /
) key for approximately 5 seconds.
l The PHOTO ( ) indicator will go out and the AUTO indicator
will begin to blink.
l One or two exposure indicators corresponding to the automatic
exposure level which has been selected will light up. The factory
default setting is level “3”.
3 Press the LIGHT ( ) or DARK ( ) key to lighten
or darken the automatic exposure level as desired.
4 Press the AUTO/MANUAL/PHOTO ( / / ) key.
l The AUTO indicator will stop blinking and will light up steadily.
l This automatic exposure level will remain in effect until you
change it again by this procedure.
Automatic exposure adjustment
AUTO
Jul 27, 2009 | Sharp Office Equipment & Supplies
Photos taken inside are fuzzy
i think the exposure settings have changed and set to hi if you can get the exposure setting to normal [+/-] to 0 or the shutter has been set to low or the iso has been set to low
but if u are skeptic about going to settings and changing those all important combinations then safest way is to restoring to factory defaults and from there u can keep experimenting again
if there is anything else that you would like to know u can mail me at mail2pvs@gmail.com
happy clicking
Jul 14, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Over exposure photos
Try change the exposure of the camera: start the camera, set the dial to 'I' (automatic iso), then press the 'up' menu near the display until 'exposure' settings appear. move the slider to the left/right, according to your preference.
I reccomend using the automatic iso for taking pictures, it automatically adjust exposure.
Apr 25, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Takes photo but no picture ( Very slightly exposed)
Have you mounted the lens correctly? Try cleaning the contacts of both the body and the lens using an eraser. Take care that no dust falls into the body.
Mar 02, 2009 | NetBotz Cameras
Wavy lines
I would suggest you to use the Manual settings. Play with the ISO and the shutter. You will get a better pic.
- Ranjit
Nov 08, 2007 | Canon Digital Rebel / EOS-300D Digital...
Copies are too light and nothing is working
Probably needs a good cleaning. The mirrors get dusty. I would suggest you call a tech. to do it. As you can nock something out of wack.
Jul 24, 2007 | Sharp AL 1631 Copier
Olympus Camedia C-770 Digital Camera Logo
76 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
