Question about Apple Computers & Internet
Code for findind the gretest no in an array .this code i want in applet programmes...........
Window vista serial key
Posted on Jun 25, 2009
I need help findind the MPE code for my blackberry 9300 IMEI CODE: 367123042874338 It is locked to koodo, Canada.
You can unlock your Blackberry 9300 from CANADA Koodo network lock easily.Visit the site
Theunlockspot.com
get the unlock code and unlock it easily.
Dec 24, 2012 | Cell Phones
Tip
Calculate more in Windows 7
At first glance the Windows 7 calculator looks just like Vista's version, but explore the Mode menu and you'll see powerful new Statistics and Programmer views. And if you're clueless about bitwise manipulation, then try the Options menu instead. This offers many different unit conversions (length, weight, volume and more), date calculations (how many days between two dates?), and spreadsheet-type templates to help you calculate vehicle mileage, mortgage rates and more.Don't take any Windows 7 applet at face value, then - there are some very powerful new features hidden in the background. Be sure to explore every option in all Windows applets to ensure you don't miss anything important
on Dec 11, 2009 | Computers & Internet
If we delete any picture from list do that picture gets saved in thrash or in bin or any other place in memory card ?
There is a portion of memory called The Array. It is designated to store deleted objects or files. While you device is being programmed, it is allocated a specific amount of space for the array. This is one of the reasons why if you purchase a 1Gb memory card, you are only able to use up about 969Mb. Some of its space have been located to act as the Array.
When you delete your files, the deleted files move to the Array section and they are heavily compressed to very small sizes and take up little space. Eventually, the Array might get filled up and you might need to format your device. Although it does take a long period of time for the Array to get filled up. In most cases, the device might even be damaged before it gets filled up.
It is also important to know that only a good hacker or programmer can bring up the items that have been deleted from the memory card.
Please comment if you require more information and thank you for using FixYa.
Jun 01, 2011 | Cameras
Hello sir, How do we link a java applet code to an oracle database..
The java applet code can only communicate with the server the applet was loaded from (unless it is signed and trusted by the browser).
Then, you need one of the following : Either
*) Your database server will need to be the same as your web server (and open to the world). This is not recommended at all, for security reasons mainly, but also performance reasons.
*) You will need some server side scripts (php and/or cgi) to handle specific requests from the applet and send the information back. (Give some thought to the fact that people might access these scripts without the applet, and will be able to see all the communication between applet and script)
Is there a specific reason for using an applet, rather than javascript/AJAX ? I ask because more browsers support the latter than the former.
May 13, 2010 | Sun Java Programming Language (cdj-275)
How to program calculator in java
If the question is : how to make a programmable calculator run a program written in Java, the amswer is : you cannot. Maybe the newer ones.
But if you are looking for the source code of a Java applet that simulates a calculator, then maybe you should launch a Google search with keywords Java calculator and see what you get. I do not want to spoil your fun by supplying a link to what my search returned.
Hope it helps.
Oct 09, 2009 | Canon Office Equipment & Supplies
C++ poker program
Hi.
I suggest creating an Array of Cards (cardOne,cardTwo,etc. to five)
If you can enter them in one at a time, after declaring the array, assign the values to the array.
cin < cardOne; (Psuedo code by the way, hope you don't mind)
Afterwards, you'll have an array with 5 cards.
Declare what full houses, flushes, etc would require.
Use an if statement (If you don't mind lots of code) to compare the entered Array against possible hands.
I didn't necessarily give you any specific C++ code. However, if you Google C++ user input, you should find plenty of commands that may help you.
Good Luck
(And not sure about Linear search to be honest, you can use a Linear search, but if you did it the way I explained, you just have to compare hand to a series of conditionals.)
Sep 23, 2009 | Computers & Internet
Dead PC, Pheonix Award Bios post code 2A, ASUS A7V400-MX SE Mothe
There is 3 reason for 2a error
Ram power supply mosfet open or short
bios programme currupt
Feb 02, 2009 | MSI Galaxy KT400 (MS-6596-20B) Motherboard
Unable to View Java Applet
"load: class JFI.class not found."
Based on the console output, it means that it cannot find the java applet class. In other words, the applet is missing on the server side. There is nothing that you can do about it, unless you know the person who created the applet. Good luck :)
Dec 23, 2008 | ArcMedia JavaScript Source Code 3000 Pro...
Java mini projects
Normaly using Searching Result moduls develop by OS
in this concept by using the own coding in JAVA Applet Programming with Swing using.
Apr 10, 2008 | Monte Carlo 5KC48JG Java Rattan / Grecian...
Myspace.com
on the myspace control panel click photos, then upload photos, then an applet called photo upload 1.03 appears, use that guy, press browse and choose the pic, press next three times and the rest will be explained by myspace itself
warning, you may need to have java installed
Dec 02, 2007 | Anthology Solutions Yellow Machine P400...
Computers & Internet Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
