Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon Pixma Error E 5
My Printer not Star, it always show E then 5 in the panel LCD. Hepl me pls. Thank you.
    President:
  • 2,306 Answers
E 5 says that the ink cartridge is not correct. or not installed properly. Sounds like you need a new ink cartridge.
Posted on Jun 26, 2009
Reset canon pixma mp258
Reset Canon MP258 error 5B00 or P07
Indications
When the printer is turned on will show an error MP258 P07 in LCD panels and monitor screen will pop up an error 5B00.
Resetter Canon MP258
1. The printer must be in SERVICE MODE, the way
2. MP258 printer is turned off and plugged the power cord.
3. Press the STOP / RESET and hold, then press and hold the POWER button.
4. The power button is pressed, release the button STOP / RESET, then press the STOP / RESET two times, then release both buttons simultaneously.
5. MP258 printer will process (rather long), then the LCD Panel will show the number zero (0)
6. The computer will detect NEW DEVICE, Ignore it .....
7. This situation indicates the printer is on and ready to reset SERVICE MODE.
8. Download ServiceTool_V1074 for MP258
9. Extract file ServiceTool_V1074
10. Prepare 2 paper in the printer (this is to print at the time the reset process)
11. Run the program ServiceTool_V1074
12. Click the "MAIN", then the printer will proceed, then MP258 will print one page with the words "D = 000.0"
13. Click " EEPROM Clear ".
14. Then click "EEPROM", and the printer will print the results MP258 Re-setter.
"TPAGE(TTL=00000 COPY=00000)"
15. Turn off the printer by pressing the POWER button or unplug the power cable
16. Turn on the printer, and the printer ready to use
I hope this information helps. Thank you for using FixYa!
Oct 16, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Problem with canon ip3300 orange light 5 time is blinking
Hello!
Orange light blinking show your printer has a problem and the error will display on your printer LCD. So check the error number on your LCD and send me the error number correctly. thanks
Sep 12, 2011 | Canon PIXMA iP3300 InkJet Photo Printer
My canon pixma mp145 keeps showing error 5, i need to use this printer urgently, what should i do?
my canon pixma mp145 keeps showing error 5, i need to use this printer urgently, what should i do?
Sep 28, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Error code U163 on cannon pixma mp220 printer
Those cartridges don't refill unless you have a way to reset the internal chip. Check online for refillable cartridges or a chip resetter. For priming you go into printer properties and choose maintenance and head cleaning, or choose cleaning from the front panel.
Feb 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
My canon pixma mp170 says check printer on the screen with error code 5200 and the alarm button is flashing
Canon MP170 (Ink Tank Full Error):
1 - power off.
2 - hold stop/reset ,hold ON/OFF
3 - release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4 - wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
5 - then push power twice, quickly
6 - power off and power on.
Dec 16, 2009 | Canon PIXMA MP170 All-In-One InkJet...
PIXMA iP1300 printer is showing an error 5100
nope try this --
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Dec 28, 2008 | Canon PIXMA iP1300 Printer
Canon Pixma iP1200 always reports "Paper is jammed"
You need to reset the printer!
for more details about software for your printer click HERE
Oct 19, 2007 | Compaq Armada M700 Notebook
Canon PIXMA MP150 All-In-One InkJet Printer Logo
209 people viewed this question
old marine
old marine
